Quantcast TJ Mini Boat side rockers - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > TJ Mini Boat side rockers
Old 11-05-2009, 06:22 PM   #1
cgmrdc
Figured id do a write up of this for anyone who wants to build a set...
I REALLY like the look of the Poison Spyder richochet rockers and the functionality of Genrights mini boatsides and since i cant afford either and love fabing my own stuff I thought id combine the two and make my own!
The rockers are made of 3/16 steel and the tubes are 1.25, .120 wall HREW
Started by cutting out the rockers
58 x 14.25
then cut where the bends go... leaving 6 1" gaps to hold it together
1st bend is 4.75
2nd bend is 3.5 from that
Next set up on a heavy table and clamp it down as much as possible. I used 2 large pipe wrenches to bend them
Top bend is 120* and the second bend is 150*
next you need to bend the pich seam under to gain the extra clearance of the boat side... this is the hard part if youre like me and had perfect rockers
you need to cut where the fender meets the tub so it can fold there... its just 1 inch up at a 45 deg angle... ill take a pic
cgmrdc is offline   Reply With Quote
Old 11-05-2009, 06:27 PM   #2
cgmrdc
once that is done you need to cut out the bottom to clear the body mounts... Ill get dems tom too
mount it up to see if the rockers needs to be messaged anymore...
repeat for the other side
Old 11-05-2009, 06:29 PM   #3
cgmrdc
Here is the shape of the tubes... ill get the autocad sketch and ad dems or you can bend whatever tube shape you want... or none...
Old 11-05-2009, 06:32 PM   #4
cgmrdc
Next is welding it together... alternating rockers and ends of the rockers with time too cool... i doubt theyll warp but better safe then sorry
after everything is welded up and you test to make sure they didnt warp or pull out grind the welds smooth. with the welder turned up you should be getting 100%+ penetration
Old 11-05-2009, 06:33 PM   #5
cgmrdc
Thats where im at as of today, ill keep updating and get the dems as I progress!
Old 11-05-2009, 06:33 PM   #6
JeSimmers
JeSimmers's Avatar
WOW! These are absolutely incredible...Good Job!
Red Jeep Club Member #454
1998 ZJ - The wife's
1997 TJ - Mine
JeSimmers is offline   Reply With Quote
Old 11-06-2009, 04:22 PM   #7
cgmrdc
Wow, thanks for the compliment. Thats the responce every fabricator strives for
Old 11-08-2009, 08:15 AM   #8
karlo
Looking good! I'm excited to see the final outcome.
karlo is offline   Reply With Quote
Old 11-11-2009, 06:36 PM   #9
funshootin1
looks great !
funshootin1 is offline   Reply With Quote
Old 11-12-2009, 11:47 AM   #10
Dogman
Nice job!!!
Dogman is offline   Reply With Quote
Old 11-12-2009, 11:56 AM   #11
Mike1084
1979 CJ7
If I may ask, cost of materials?
Mike1084 is offline   Reply With Quote
Old 11-12-2009, 02:41 PM   #12
cgmrdc
$120 4'x8' 3/16 steel plate... which will also make my front bumber and steering box skid
$20 20' 1-1/4 HREW
$25 stainless steel nuts and bolts
i used half the stick of tubing and between half and a third of the sheet... so def a lot less the $499...
Old 11-13-2009, 09:26 AM   #13
Mike1084
1979 CJ7
Nice! Definately worth it. I like some of the Poison stuff also but outta my price range. love to see the finished product, keep up the posts.
Old 11-15-2009, 09:03 PM   #14
cgmrdc
got the sliders on for a test run to flat nasty this weekend. The clearance difference between these and my old tube steps is unreal! i actually had to purposefully drive over a rock to get them to hit just so i could see how they held up, and that was the only time i touched them all weekend... but now the lowest point is the body mounts so im gonna fab up some skids for those too
backing plates on the sides are 2x1/4 stainless strips, floor is 2x1/4 mild...
10 stainless counter sunk bolts per side for a nice smooth surface.
now that wheelin season is over....... im gonna pull these off, stripem back down, weld the tubes on, clean up some of the grinder marks and ill paint it gunmetal to be the same color as the TJ
Old 11-16-2009, 11:51 PM   #15
NalinMFG
www.NalinMFG.com
NalinMFG's Avatar
awesome job, this will save alot of people some serious dough! i have been wondering how genright got theirs to fit without trimming the tub...yours made sense of it. Any more pics? How's it mount underneath?
NalinMFG is offline   Reply With Quote
Glock Forum
