TJ Long arm build - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > TJ Long arm build
Black Friday- Cyber Monday Deals at jeepHutIntroducing the CUPHOLSTER @ OCONEE OFF ROAD 706 534 9955Thanksgiving holiday sale in effect @ oconeeoffroad.com
Unread 05-07-2010, 06:40 PM   #1
TreverTJ
TJ Long arm build
Heres my Long arm build. It is a radius arm style with no rear triangulation. For now I will be keeping the rear track bar. May Triangulate in the future.
1" currie for frame end of lower arms.
Using these 1" Ubolt nuts for the inserts.
2"x2" with 1/4" wall for lower arms.
1.5"x1.5" 3/16" wall for upper arms.
Picked up these BDS rails. This made the work very easy and saved a lot of time!
Off with the old axle brackets.
Built some new ones.
TreverTJ is offline   Reply With Quote Quick reply to this message
Unread 05-07-2010, 06:41 PM   #2
TreverTJ
Short radius arm for front.
Some action shots of how it works.
Unread 05-07-2010, 06:48 PM   #3
Imped
Imped's Avatar
No vertical separation at the axle end in the rear? What are your thoughts on that?
Otherwise, GREAT work.
OlllllllO
Float Test Build
IndyORV
Imped is online now   Reply With Quote Quick reply to this message
Unread 05-07-2010, 06:52 PM   #4
TreverTJ
What do you mean by verticle separation at the rear axle?
Unread 05-07-2010, 06:54 PM   #5
Imped
Imped's Avatar
The frame ends of the upper and lower rear arms are in the same plane, ie no vertical separation. This is generally an invitation for poor anti-squat numbers.
OlllllllO
Float Test Build
IndyORV
Unread 05-07-2010, 06:58 PM   #6
TreverTJ
ahh,,I getcha. I guess im not up on my "4 link lingo" lol. These frame rails are BDS and is what BDS uses in most of there long arm systems so I would presume it should be ok. Jeep seems to work very well and road manners are far superior then they were with the short arms.
However I will be changing this when I triangulate.
Unread 05-07-2010, 07:07 PM   #7
Imped
Imped's Avatar
Oh ok, didn't realize the BDS mounts incorporated the mounts for both uppers and lowers.
BTW, this is a good read: Multi-Link Suspension System Technology - Roll Center and Anti Squat - Off-Road Magazine
OlllllllO
Float Test Build
IndyORV
Unread 05-07-2010, 07:08 PM   #8
TreverTJ
Thanks for the link! One more to add to my favourites!
Unread 05-07-2010, 07:37 PM   #9
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
wow very nice work!
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2010, 08:47 PM   #10
TheSherp
How much do you have into the entire set up. I'm all about building what I can. Ive read where its not that much cheaper to build a long arm kit. I want to stay with short arms but........ building short arms this way seems not to difficult.
TheSherp is offline   Reply With Quote Quick reply to this message
Unread 05-07-2010, 08:52 PM   #11
TreverTJ
This cost me about $800 to build,,,thats from cost of steel to paint. The curry joints alone where $300 for the six of them. One thing tho,,most aftermarket long arms arent 1/4" wall. Ive seen a lot of my buddies bend their aftermarket arms. Ive went everywhere they have and have no worries EVER of bending my arms!
Trever
Unread 05-07-2010, 08:56 PM   #12
jeep4alex
Nice stuff Trever
jeep4alex is offline   Reply With Quote Quick reply to this message
Unread 05-07-2010, 09:17 PM   #13
XJoutlaw
Any strength gain buy using square to round or was this just what you had or what? just curious.
XJoutlaw is offline   Reply With Quote Quick reply to this message
Unread 05-07-2010, 09:31 PM   #14
TreverTJ
Ive read a few things that imply square is better then round and vise versa. Heres my theory :
When a round arm comes down on a rock the load to the impact point to the arm is very small. When a square arm comes down on that same rock it has a flat bottom which in theory will have more surface area in contact with the rock which spreads the load of impact. With that said you could say square is stronger but really,,there is sooo many variables. Grade of steel, wall thickness, length of arms, etc..
The biggest reason why I choose square was because it was different then what everybody runs around here. I like to be different! lol
Unread 05-07-2010, 11:15 PM   #15
XJoutlaw
awesome well they look top notch man
