TJ Front frame rust - JeepForum.com
post #1 of 3 Old 02-15-2011, 10:03 PM Thread Starter
mcb99
TJ Front frame rust
I have some rust issues in the front frame area, directly beneath the front OEM bumper.
Its the ends of the tubular crossmember, the piece the bumper bolts thru, and some rust in the square frame rail end areas.( Sorry I dont know the exact names of these parts).
This Jeep is used as my plow and i am wondering if this area can be repaired, or fabricated . The plow frame bolts onto the end of the frame in this area and i am worried about structural integrity and stuff.I saw at Autorust fabricators they had these parts avail for a 95 wrangler but nothing for 97 as yet. Anyone have any ideas or info they can pass along? thanks
mcb99 is offline
post #2 of 3 Old 02-16-2011, 03:20 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Buy some steel plate and weld it on as needed to reinforce the frame rails. Fabricating some steel tube as a front bumper and welding it on the frame rails will provide extra structure and rigidity for the front portion of the frame.
CJ7-Tim is offline
post #3 of 3 Old 02-16-2011, 07:09 AM
Ironworker709
Ironworker709's Avatar
Cut the rust out completely and buy some tube steel the same size as the frame rails and weld it in or use some plate to make you're own repair,as long as it is all in font of that tube crossmember in the frame you'll be fine as far as structural integrity.Just welding plate over top of a rusted area will cause more problems down the road ,plus it will be a real PITA to try and weld rust.
Just remember to use a "fish plate" as some call it if you cut the whole front tube off and tie in a new one,it is a diamond shaped plate to go over where you tied the new section of frame in to add strength to the newly welded area..
You also need to check with you're local DOT inspections,or DMV..i see you are in Illinois,if i remember correctly they are pretty strict on any frame rail repairs as to who does it,like a state certified weldor/fabricator certified for frame work in the state..not sure..but best to check n see what they're laws are on the issue
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
Bad rust on front of frame, driver's side near steering box HELP! Phrankoff Fabrication Shop 23 10-18-2010 06:55 AM
rust in your frame? herbiehind Fabrication Shop 1 12-01-2009 12:41 PM
Frame rust? itasor General Jeep & Off-Road Equipment 7 08-24-2008 08:58 AM
Frame rust JeeperAbe General Jeep & Off-Road Equipment 4 01-03-2007 11:25 AM
best tool to get rid of rust on frame rick95 General Jeep & Off-Road Equipment 4 09-11-2006 10:40 AM
