TJ frame repair welding questions. - JeepForum.com
post #1 of 4 Old 03-31-2013, 08:00 PM Thread Starter
SkippyPB13
So I have the typical rotted out frame rails where the trans skid plate mounts. I picked up some 3/16" x 3" angle and some 3/16" flat to box the frame rails. I've mocked up and cut out the angle to fit then drilled and mounted nuts to the inside of the angle. Then I dropped the skid plate and knocked out and cut out the rotted bottom of the rail. I've got the drivers side cleaned up and mounted the angle into place. I've begun the welds with a Miller 135-.025 wire- 75/25 argon/co2 mix-voltage 4-wire speed around 70? and feel I'm getting good penetration on both pieces of steel.
My question is for the welding pros on here. Would I be better off breaking out my dads AC/DC stick welder or am I good to go as long as I place another row of beads along these for added strength. If the stick is a better way to go what rods would you use?
Ask about my Custom Paracord Jeep Stuff!!
Door straps, rollbar grab handles, bracelets.
SkippyPB13 is offline
post #2 of 4 Old 04-01-2013, 03:01 PM
EZBillyBA
You should be good with what you have, I would go ahead and weld the angle in continuously though.
EZBillyBA is offline
post #3 of 4 Old 04-01-2013, 04:33 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Grind it all out and use the stick welder..... April Fools!!
Looks pretty good with the little Miller
BESRK is offline
post #4 of 4 Old 05-28-2014, 08:27 AM
Bobbyreb97
did you weld the other side of that angle iron? same problem. Sick beads though. I tried to weld the edges of the under side and i just blew through. Too much rust.
Bobbyreb97 is offline
