TJ custom bumper mounting ideas? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > TJ custom bumper mounting ideas?
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 05-24-2010, 02:24 PM   #1
D-Morg
I am currently building a rear bumper and tire carrier for my TJ. A 37” tire and a small 20”x36” gear rack will be mounted on the swing out portion of the bumper. I had a little mounting system built up that was based off of some of the other popular rear bumpers. On either side of the bumper I took a piece of 1”x5” steel and made a couple of pads that are to be welded to the bumper. I bored two holes in both of the pads that will be tapped for a ˝” stud that will run thru the stock mounting holes in the frame.
Then I was going to build some bracing that bolted to the stock frame to strengthen it up a little bit. I found a picture of the same basic design I was going to build. Mine would look a little different but it would be the same concept.
I would like to mount it different but the ideas aren’t coming to me very fast. I would like to have a little bit more than 4 half inch studs holding her on. I’m more worried about the weight of the spare and the gear rack with 100 lbs of junk on it than I am about the bumper holding up to recoveries. The recovery aspect still doesn’t sit well with me.
If anyone has any good ideas (pictures would be nice), please let me know!
"Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic."
D-Morg is offline   Reply With Quote
Unread 05-25-2010, 07:40 AM   #2
jpony645
There are also nutserts on the bottom of each frame rail to put bolts into.
jpony645 is offline   Reply With Quote
