TJ Belly up - JeepForum.com
post #1 of 21 Old 05-07-2010, 05:16 PM Thread Starter
TreverTJ
TJ Belly up
Heres my belly up mod....
So heres what I started out with,,,,"The shovel"
1" Engine lift
SYE
Broken bolts in frame
Cut them out!
Heres the fix,,Made up some inserts from 1/8" thick washers and 1/2" nuts to put in the frame.
Cut out a piece of 1/4" plate and a piece of channel for the trans mount.
New poly trans mount.
Before
After
TreverTJ is offline
post #2 of 21 Old 05-07-2010, 05:17 PM Thread Starter
TreverTJ
Custom built rear DS from a front DS.
Heres my completed underside.
TreverTJ is offline
post #3 of 21 Old 05-07-2010, 05:28 PM
Ironworker709
Ironworker709's Avatar
I likey...
I also have that in my plans when i do the 5.2 or 5.9 FI auto swap in mine
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #4 of 21 Old 05-07-2010, 05:35 PM
mg2000xj
People pay so much money for belly ups and skids and boom, here you go with a home brew one that is flatter than most aftermarket ones and this looks extremely simple to make. Props to you man, looks awesome. I wish it was this easy for us xj guys.
Ps, what suspension are you running? Looks like a possible 3 link front but in some pictures I see stock rear arms but also the joints and what looks to be rear long arms in others?
-Morgan
'00 Silverstone 2 Door XJ
Utah Jeep Crew Member #119
mg2000xj is offline
post #5 of 21 Old 05-07-2010, 05:42 PM
Imped
Imped's Avatar
Looks good. Did you add any extra support to the plate?
OlllllllO
IndyORV
Imped is offline
post #6 of 21 Old 05-07-2010, 05:50 PM Thread Starter
TreverTJ
I didnt add anything more then the channel for the transmission and the bracket thats bolts to my engine/trans skid. I have beat it off of some serious rocks and so far no problems!!
TreverTJ is offline
post #7 of 21 Old 05-07-2010, 06:19 PM Thread Starter
TreverTJ
lol...yeah...ive been posting these builds of mine not necessarily in order so I can see why your confused. Check out my long arm build and you will see what Im running.
Trever
TreverTJ is offline
post #8 of 21 Old 05-07-2010, 09:13 PM
Jeepinty
Does the poly trans mount transfer vibrations to the jeep? I had a motor mount lift with poly bushings and the damn jeep shook like a heroin addict while at a stop in gear (auto trans). I've since sold the motor mounts and put the stock ones back with a motor mount spacer. I'm just worried a short, poly trans mount will give me the same problem all over again.
Jeepinty is offline
post #9 of 21 Old 05-08-2010, 05:22 AM Thread Starter
TreverTJ
No doubt the poly mount transfers more vibrations then stock mounts. With that said I noticed a little more vibration but not bad enough for me to want to go back to stock. I like how tight my drivetrain feels when im on the skinny pedal. I dont get any drivetrain twist anymore. The poly mounts are a must with how I did my belly up due to the fact my transmission and T-case are within 1/2" away from my floor. Most belly up systems you see still use a 1" t-case drop. I put my belly up flat to the frame rails. I needed to eliminate as much drivetrain twist as possible so the trans/t-case wouldnt come in contact with the floor.
TreverTJ is offline
post #10 of 21 Old 05-19-2010, 06:50 PM
1stjeeprubi
Excuse the ignorance as I am very new to this forum and the whole "jeep thing" But how much of a bl are you running? And did you have any issues with linkage or exhaust binding?
1stjeeprubi is offline
post #11 of 21 Old 08-12-2010, 02:06 PM Thread Starter
TreverTJ
I am running a 1.5" body lift. I did have to modify my 4x4 linkage.
TreverTJ is offline
post #12 of 21 Old 08-13-2010, 07:54 PM
JJeeper09
what kind of mount is it?
JJeeper09 is offline
post #13 of 21 Old 08-13-2010, 08:01 PM Thread Starter
TreverTJ
Poly mount made by Energy suspension.
TreverTJ is offline
post #14 of 21 Old 08-15-2010, 07:48 PM
johnny9
made my own also a few months ago..then realized how much room i had and wish i had gone flat..but then added front la and glad i didnt go flat since it comes together good at the la brackets..
great work as always
didnt see your la build in your sig ?
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #15 of 21 Old 08-15-2010, 11:58 PM Thread Starter
TreverTJ
TreverTJ is offline
TJ Belly-up Skid cgmrdc Fabrication Shop 53 11-12-2011 12:24 AM
ZJ Belly Skid WickedZJ Fabrication Shop 2 05-13-2009 05:27 PM
Belly-Up Installation Help Maverick906 General Jeep & Off-Road Equipment 21 05-08-2008 08:56 PM
TJ belly Up ? Edward777 General Jeep & Off-Road Equipment 3 01-26-2008 07:53 PM
Belly-up w/o BL jonster Tires & Wheels 2 09-26-2006 02:19 PM
