Tire carrier spindle - Page 2 - JeepForum.com
post #16 of 22 Old 02-03-2011, 09:55 PM
wushaw
Rockin jeep
wushaw's Avatar
Originally Posted by 00JGC00 View Post
I just bought a comp 4x4 HD spindle and man that thing is big. Can someone tell me in what order is best to install and assemble these things? I have two 2x2 bars for the top and bottom arms that the hinge will weld to. I'm thinking I take the bottom sleeve and weld that to the bottom arm with the spindle inside so that if the sleeve warps, I'm not screwed. Then take the top sleeve and weld that to the top arm and then try to assemble it after the top sleeve is welded and the bottom sleeve/spindle are welded? It'd be easier to have it all assembled when welding the top half, but I'm afraid the internals wouldn't handle the heat. Thoughts?
I tacked my sleeve into the bumper first with the spindle installed squared to the top of the bumper, removed spindle then burned sleeve in, I also drilled some holes into the each side of the bumper for some rosette welds prior to installing the sleeve.
I then put the spindle in and assembled the spindle and fitted the swing arm to it at the height I wanted then tacked it on and disassemble the spindle and burned it on.
I took my time and measured everything carefully, it works great.
wushaw is offline
post #17 of 22 Old 02-03-2011, 09:56 PM
timatoe
timatoe's Avatar
I cut the hole in the bumper, and welded in that sleeve, cut the swing arm and welded that sleeve. Pressed the spindle into the lower sleeve, assembled bearings etc. in upper sleeve on the swing, put everything together.
timatoe is offline
post #18 of 22 Old 02-04-2011, 10:26 AM
00JGC00
wushaw, I think you pretty much answered my question, but I want to be sure.
Here is the pic of the actual hinge and what I'm calling the top/upper and bottom/lower sleeves:
Here is what my hinge should look like when it's all done:
So if I'm understanding you all correctly, this is what I should do:
Comp 4x4 said that you should weld the lower sleeve with the spindle inside because that will pressure fit it in there. After welding, the spindle would be very difficult to remove...
So once it's in there, it's in there in other words.
Do I have that right? It seems kind of like common sense, but I wasn't sure if any of the internal assembly with the seals and stuff needed to be done in a certain order that would mandate installing the components in a certain order as well.
Thanks again for the help and sorry to threadjack!
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #19 of 22 Old 02-04-2011, 09:32 PM
wushaw
Rockin jeep
wushaw's Avatar
The steps are correct, just follow that and it will work just fine. Just one word of caution place your ground clamp on the arm side of the upper sleeve so current does not pass through the bearings when tacking the arm to the upper sleeve.
wushaw is offline
post #20 of 22 Old 02-06-2011, 08:24 PM
00JGC00
As opposed to hooking it on the upper sleeve? I would think putting the ground clamp on the arm would be easier and out of the way anyway, so cool. Thanks for the help! I hope it works out. I just have to weld on the hinge and the latch and it's all done!
00JGC00 is offline
post #21 of 22 Old 02-07-2011, 06:02 AM
wushaw
Rockin jeep
wushaw's Avatar
I think I said to put the ground clamp on the arm...didn't I
wushaw is offline
post #22 of 22 Old 02-07-2011, 09:43 PM
00JGC00
Yeah, sorry, that's what I meant to say - that putting it on the arm as you suggested makes sense.
00JGC00 is offline
My Hitch Swingout Tire Carrier. ( also need Spindle advice ) TwistedcaB- Fabrication Shop 13 08-28-2010 11:13 PM
Would you pay extra for a beefier tire carrier spindle kit?? zachv Fabrication Shop 45 05-15-2010 06:57 AM
weld area on tire carrier spindle...atoz? squigy123 Fabrication Shop 3 11-23-2009 08:53 AM
Machined hub for trailer spindle tire carrier mxg342 Fabrication Shop 4 03-30-2006 05:51 PM
