Tire carrier pivot question - JeepForum.com
post #1 of 12 Old 12-30-2011, 12:45 AM Thread Starter
aresfab
Hi I have been building tire carrier and bumpers for a while now. On my tire carrier I always use a spindle assembly with 2 tapered bearings rated for 1750 lbs. I have been noticing others use 2 hiem style rod ends. And I must admit I am thinking about using them in a new prototype bumper/carrier. I have never used these before. So here are my question. What do you think of them?
[CENTER]ARES FABRICATION
aresfab is offline
post #2 of 12 Old 12-30-2011, 07:39 AM
KnoxsTJ
they are perfectly fine, potentially better in the fatigue loading scenario than a spindle due to where everything requires welding.
However I think they make more sense for a tub mount style that ties into the roll bar rather than stacked on top of each other as a direct spindle replacement
all that said, you still need to make sure you've got them properly sized.
KnoxsTJ is offline
post #3 of 12 Old 12-30-2011, 11:49 PM
framanda
That's what I run and I have some pointers for you. I have ran this setup for over a year now.
The heims should be as far apart vertically as possible I have about 3.25" between mine and wish i had 5" at least. I also wouldn't use any heim smaller than 5/8. I used 1/2 the first time and they were not up to the task of holding my 31 so 5/8 minimum. its a great system and plenty of adjustment to counteract the added weight of larger tires fuel cans or jacks. My latch is a threaded bolt type so any change in weight makes the holes not line up, so the adjustibility was a must for me. hope that helped a little.
framanda is offline
post #4 of 12 Old 12-31-2011, 07:07 AM
jatepper
I personally think a spindle is tje way to go. Type 84 spindles specifically.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #5 of 12 Old 01-13-2012, 07:18 PM Thread Starter
aresfab
This is the bumper that made me start this thread.
aresfab is offline
post #6 of 12 Old 01-13-2012, 08:32 PM Thread Starter
aresfab
aresfab is offline
post #7 of 12 Old 01-13-2012, 08:44 PM
Bigbob
Bigbob's Avatar
In my mind's eye regardless if you run a spindle, Heim joints, Bronze bushings or whatever a rest for the swing at the opposite end is needed to get the weight off the pivot. There is a lot of leverage there.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #8 of 12 Old 01-17-2012, 12:18 PM Thread Starter
aresfab
I agree. The weight factor plus leverage like you said adds up.
aresfab is offline
post #9 of 12 Old 01-17-2012, 04:43 PM
monkers
2010 JK Wrangler
how do the tire carriers that swing with the tailgate seem to be holding up, being that they are using the tailgate to "hold up" the tire? Not sure if I explained that right?? I think the spindle with the bearings would be stronger no??
2010 Rescue Green 2 Door 6 Spd, 2.5" RK Max Travel, Fox 2.0 IFP Shocks, 37" Nitto Trail Grappler M/T, EVO Sleeves, Gussets, Mini Skids, Rock Stars, Poly Perf Long Travel Upper Shock Mounts, Poison Spyder Evap Skid, Diff Covers, Grab Handles, Cobra 75WXSt, Stern Cibie/Osram Light Upgrade, Mopar Heated Seats, Trimmed Flares & Bumpers
monkers is offline
post #10 of 12 Old 01-17-2012, 06:52 PM
Bigbob
Bigbob's Avatar
On mine (pics at bottom) the swing holds both the tire and the tailgate. I could in theory toss the tailgate and just run the swing. But that is goofy! But I have built a swing that is the typical bumper mounted spindle that the tailgate is linked to and the whole works opens as a unit.
That was for my brother in law's Rubi. To my knowledge he has had zero issues.
I've had mine over 4 years now and not one hiccup.
6 Speed, Hardtop
Bigbob is offline
post #11 of 12 Old 01-17-2012, 07:46 PM
monkers
2010 JK Wrangler
Bigbob, neat set up, both of them. Id like to make a bumper pivoted carrier that is tied to the gate. On the bottom pics, what did you do for the mounts the the tailgate hinges, to beef them up? Everyone says the stock tailgate setup cant handle the weight of a 35" tire, slick set up you got there.
monkers is offline
post #12 of 12 Old 01-18-2012, 07:39 AM
Bigbob
Bigbob's Avatar
If you look at the above picture close you will see the tailgate has zero of the weight on it. It makes no difference what size tire, the tailgate is not affected. The tailgate, just like the tire, mounts on the swing.
Here is a pic of the hinge.
They are welded to Rokmen corners.
1" pins
1" bronze bushings 2" square tube.
6 Speed, Hardtop
Bigbob is offline
Spare Tire Mount Parts? Where to get pivot bearing kit? profile Fabrication Shop 18 07-07-2010 03:34 PM
Another swingout tire carrier question? crazycollinz Fabrication Shop 4 03-12-2010 06:32 PM
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
1750lb Tire Carrier Pivot!! BESRK Fabrication Shop 20 02-01-2009 11:46 PM
Low(er) Profile Pivot Point for Tire Carrier? FitchVA Fabrication Shop 5 07-29-2008 05:07 PM
