tire carrier latch won't stay closed - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > tire carrier latch won't stay closed
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-23-2013, 02:48 PM   #1
mustangwarrior
i bought a detasco latch from comp4x4 and had my buddy weld it on this weekend, we put it on just like every other one i've ever seen but it rattles loose and today the arm swung open on me going down the road, its tight and takes some pressure to close it but pops right open with just the touch of a finger, anyone have this issue or know of a way to fix it?
this is the latch i bought
http://www.comp4x4.com/LATCH-KIT-De-...amp-Latch.html
now i think i may see my mistake, they also sell a latch with a locking mech. but its twice the cost
KCCO! -Nick
2001 Jeep WJ, I6, Select Trac, IRO 3", Cooper ST maxx 265-75, 16" Raceline Rockcrusher Wheels, Custom Tire carrier, 30" Seward LED Light bar, rear Aussie Locker
mustangwarrior is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 04:00 PM   #2
sherlocktk
I have the same latch you do without the "locking" option. Mine has never been an issue. you can play with the angles a little bit where it goes a little past center so the pressure actually holds the handle down. you will need to shim something to make this happen.
when I am doing some serious wheeling I put a tarp ball bungie on the handle for extra security. Ill try to take a picture of how mine is setup later today
sherlocktk is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 05:28 PM   #3
mustangwarrior
I think we welded it too far apart and i'm gonna look for a longer u bolt to replace that one but i think what i'm gonna do which will be the easiest and cheapest will be to weld a tab to the carrier arm so i can drop a pin thru the handle to lock it in
KCCO! -Nick
Unread 04-23-2013, 06:42 PM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
When it locks closed, it has to "overcenter" all the way. Otherwise, it'll pop open.
I'd look at the "height" of the hook. If it's not on the same mounting plane as the latch base, you're not overcentering enough.
You might consider swapping that regular 341 latch, for the 341-R latch. It has the "Toggle Plus" trigger to keep it closed.. preventing accidental opening. Costs about $10 more than the regular latch.
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 09:20 PM   #5
kjg26
Where do you see see it for 10 more. I'm seeing more like 40 more.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 12:05 PM   #6
mustangwarrior
Heres how i have mine on, the bungee is so if it pops open, you guys see anything wrong with how its on there?
KCCO! -Nick
Unread 04-24-2013, 05:17 PM   #7
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
McMasterCarr.. Part #5071A62 .... $44.63 plus shipping
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
