Tire Carrier/ Corner Armor build - JeepForum.com
post #1 of 18 Old 02-04-2014, 10:48 AM Thread Starter
Nickp3d
I wanted to build a different tire carrier, that would be quieter than the single spindle carriers. I saw a few designs, but they were not as functional. So i set off to fab up my own!
These started as flat sheets of 3/16 coldroll
A little plasma cutting later!
Carrier all tacked in
Nickp3d is offline
post #2 of 18 Old 02-04-2014, 11:03 AM Thread Starter
Nickp3d
Here is the rubber bushing, and mount
Mocking up, and measuring the carrier
Tire mounted
Drivers side pins
Led light mount
Here is where I am currently at
Nickp3d is offline
post #3 of 18 Old 02-05-2014, 10:04 AM
jeepinhokie
glad i saw this...
i was contemplating doing something similar. now i know i want to keep the carrier closer to the tub and mount the tire on the outside like the Or-Fab one.
is that 2" tube?
looks like it'll do the job!
HOKIES UNITED!
jeepinhokie is offline
post #4 of 18 Old 02-05-2014, 10:45 AM Thread Starter
Nickp3d
Originally Posted by jeepinhokie View Post
glad i saw this...
is that 2" tube?
It is 1.75" OD .120 Wall
Nickp3d is offline
post #5 of 18 Old 02-06-2014, 05:07 PM
lar308
I like the design, have you considered a couple of jerry can carriers? Nice job, Ron
"Snowball" 1990 YJ, 4.2, Weber, HEI, 3.5" springs, .5" boom shackles, dana 44's, 5.13's, Detroit locker's, 4340 axle shafts, 1 ton trod ends, Tom Woods SYE & rear shaft, 35" MTR's on V5 cragars, M8274
lar308 is offline
post #6 of 18 Old 02-06-2014, 07:42 PM
TXST8tj
TXST8tj's Avatar
I have a similar build in the works, but my tubing runs flush along the back of the Jeep and the tire off of that.
What do you have planned for support behind the tub?
Patrick
TXST8tj is offline
post #7 of 18 Old 02-07-2014, 09:51 AM Thread Starter
Nickp3d
I am going to make a hi-lift mount, and a mount for a ammo can. I have never needed extra fuel, i really don't go on long distance runs.
I am going to add 1/4 plates to support the top bolts, other them that I used some big washers to spread the load. It fells solid so far.
Nickp3d is offline
post #8 of 18 Old 02-07-2014, 09:57 AM Thread Starter
Nickp3d
More progress yesterday.
Both lights in
Wired up
Supa bright
Tires back on, and everything bolted in. Still needs flares, backup light, paint, and drop down tailgate.
Nickp3d is offline
post #9 of 18 Old 02-09-2014, 04:54 PM
Gru98
Hey I'm just wondering how did you bend the plate perfectly around your corners! Im looking to do something like this
Gru98 is offline
post #10 of 18 Old 02-10-2014, 12:00 AM Thread Starter
Nickp3d
A 6" steel pipe is the same radius as the corner of the jeep. I used a torch to heat it, and then bent it around the pipe
Nickp3d is offline
post #11 of 18 Old 02-10-2014, 06:33 AM
responder
I am wondering if you are planning on putting in any reverse lights? If so, what are you thinking of doing?
responder is offline
post #12 of 18 Old 02-10-2014, 07:58 AM Thread Starter
Nickp3d
I have the wiring all set up for a reverse light. I am looking at the led light pods, like a rigid dually
Nickp3d is offline
post #13 of 18 Old 02-14-2014, 06:22 PM
SonicR1
I had to cut out my side bars because they blocked the rear lights too much...
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #14 of 18 Old 02-16-2014, 03:28 AM Thread Starter
Nickp3d
got any pics?
Nickp3d is offline
post #15 of 18 Old 02-16-2014, 10:56 AM
rubidriver
Your carrier looks weird because you need to turn the tire around to face the back
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
