-   Fabrication Shop (http://www.jeepforum.com/forum/f37/)
-   -   Tire Carrier/ Corner Armor build (http://www.jeepforum.com/forum/f37/tire-carrier-corner-armor-build-2072953/)
Nickp3d 02-04-2014 10:48 AM
I wanted to build a different tire carrier, that would be quieter than the single spindle carriers. I saw a few designs, but they were not as functional. So i set off to fab up my own!
These started as flat sheets of 3/16 coldroll
http://i1122.photobucket.com/albums/...B02F365866.jpg
A little plasma cutting later!
http://i1122.photobucket.com/albums/...D3147C7B92.jpg
http://i1122.photobucket.com/albums/...8070908442.jpg
Carrier all tacked in
http://i1122.photobucket.com/albums/...9089B5AB01.jpg
Nickp3d 02-04-2014 11:03 AM
6 Attachment(s)
Here is the rubber bushing, and mount
Attachment 1059609
Attachment 1059617
Mocking up, and measuring the carrier
Attachment 1059641
Tire mounted
Attachment 1059649
Drivers side pins
Attachment 1059649
Led light mount
Attachment 1059657
Here is where I am currently at
Attachment 1059665
jeepinhokie 02-05-2014 10:04 AM
glad i saw this...
i was contemplating doing something similar. now i know i want to keep the carrier closer to the tub and mount the tire on the outside like the Or-Fab one.
is that 2" tube?
looks like it'll do the job!
Nickp3d 02-05-2014 10:45 AM
Originally Posted by jeepinhokie (Post 20077201)
glad i saw this...
is that 2" tube?
It is 1.75" OD .120 Wall
lar308 02-06-2014 05:07 PM
I like the design, have you considered a couple of jerry can carriers? Nice job, Ron
TXST8tj 02-06-2014 07:42 PM
I have a similar build in the works, but my tubing runs flush along the back of the Jeep and the tire off of that.
What do you have planned for support behind the tub?
Nickp3d 02-07-2014 09:51 AM
I am going to make a hi-lift mount, and a mount for a ammo can. I have never needed extra fuel, i really don't go on long distance runs.
I am going to add 1/4 plates to support the top bolts, other them that I used some big washers to spread the load. It fells solid so far.
Nickp3d 02-07-2014 09:57 AM
5 Attachment(s)
More progress yesterday.
Both lights in
Attachment 1066993
Wired up
Attachment 1067001
Attachment 1067009
Supa bright
Attachment 1067017
Tires back on, and everything bolted in. Still needs flares, backup light, paint, and drop down tailgate.
Attachment 1067025
Gru98 02-09-2014 04:54 PM
Hey I'm just wondering how did you bend the plate perfectly around your corners! Im looking to do something like this
Nickp3d 02-10-2014 12:00 AM
A 6" steel pipe is the same radius as the corner of the jeep. I used a torch to heat it, and then bent it around the pipe
responder 02-10-2014 06:33 AM
I am wondering if you are planning on putting in any reverse lights? If so, what are you thinking of doing?
Nickp3d 02-10-2014 07:58 AM
I have the wiring all set up for a reverse light. I am looking at the led light pods, like a rigid dually
SonicR1 02-14-2014 06:22 PM
I had to cut out my side bars because they blocked the rear lights too much...
Nickp3d 02-16-2014 03:28 AM
got any pics? :)
rubidriver 02-16-2014 10:56 AM
Your carrier looks weird because you need to turn the tire around to face the back
The time now is 07:23 PM.
