Tire Carrier - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Tire Carrier
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 12-06-2015, 06:19 PM   #1
TechJeeper
I started this tire carrier recently for my tj. The mounts are getting welded to the corner armor and I may add a couple bolts near the mounts that bolt all the way through not just the nutserts that hold the armor on.
So here's the run down.
4 old heims recycled from my control arms
2 spare 7/8 tube inserts
2 7/8 machined fine thread castle nuts from ace
2 pieces of 1.75x.120 wall tubing from an old buggy that I cut up.
3/16 this plasma cut parts I designed myself including the main piece, 4 heim mounts, and a high lift jack mount not currently pictured yet.
All in all I'm about $10 in because all the parts of cut from scrap. I had to buy a couple 7/8 fine thread castle nuts to use for inserts. I had 4 spare 5/8 bolts I'm using for mock up but they are all too long so I will have to buy some bolts and other hardware to get it all right.
TechJeeper is online now   Reply With Quote Quick reply to this message
Unread 12-06-2015, 06:21 PM   #2
TechJeeper
Here's the main 2 cross bars. Everything slides on to them.
Unread 12-06-2015, 06:23 PM   #3
TechJeeper
Test fit on the bench.
Unread 12-07-2015, 05:37 PM   #4
TechJeeper
More progress
Unread 12-07-2015, 05:37 PM   #5
TechJeeper
More progress. 3 brackets mounted.
Unread 12-07-2015, 05:38 PM   #6
TechJeeper
I had to modify the side that will open. The box in plate came over to far so I trim it back and re tacked it.
Unread 12-07-2015, 08:58 PM   #7
TechJeeper
Here it's open on its own mounts for the first time. There is still tons of welding to do.
Unread 12-08-2015, 10:11 AM   #8
PhulesAu
I gotta ask, is it really a tire carrier or armor against a fracking truck? Seriously what did you use for backing/support for the mounts, inside the tub? that sheet metal is kinda thin on my LJ.
PhulesAu is offline   Reply With Quote Quick reply to this message
Unread 12-08-2015, 10:21 AM   #9
TechJeeper
The armor is currently bolted to the body and the mounts are welded to that. I am however working on a bracket that bolts through the armor to the rear cage mounts.
Right now nutserts are holding the armor on but all the spots I can they are getting drilled out and through bolted.
I do live in west Texas so a fracking truck rear ending me is a definite possibility.
Unread 12-08-2015, 04:23 PM   #10
dwilliams35
I'm really not sure I'd mount the thing like that: it's still basically a bunch of relatively small screws though sheet metal.. The metal itself isn't substantial enough to support that kind of weight without deforming or metal fatigue. Just vibration alone has to take its toll when it's all loaded with stresses like you're going to be looking at there. You're talking some pretty major leverage on that right side sheet metal.
dwilliams35 is offline   Reply With Quote Quick reply to this message
Unread 12-08-2015, 04:59 PM   #11
TechJeeper
It'll work fine. There are plenty of armor mounted tire carriers out the from good companies. I'm not reinventing the wheel here.
Unread 12-08-2015, 05:08 PM   #12
TechJeeper
It's 28, 1/4" counter sunk tapered head bolts. Some of which are through bolted and as stated above more are going to be through bolted. The whole back of the jeep would have to fall off. Also the back passenger corner is designed to take some load from the stock tailgate and tire. That's at least 60#. That has been removed so I'm not really adding as much weight to the corner when opened as it seems. I can figure the weight at some point but all together the tire and wheel are around 80# and the swing out is about 30-40#. So that's only 60 extra pounds to that corner when it's open. Which is spread across the entire piece of body armor.
Unread 12-09-2015, 12:43 PM   #13
TechJeeper
Did a little more today. Tire mount needs some tweaks.
Unread 12-09-2015, 12:48 PM   #14
TechJeeper
It holds the tire fine but fixing the gap will bring the tire against the carrier. It has a small gap now. Pictured is a 37" tire on the highest setting.
Unread 12-10-2015, 10:24 PM   #15
TechJeeper
New tire mount made and tacked together.
