Tig welding question - JeepForum.com
post #1 of 12 Old 03-17-2014, 08:10 PM Thread Starter
Machinist
I am new to tig welding so bear with me,being so new I will need a ton of practice and I know that.What I am wondering is say I make tac welds with a mig can I go through and TIG weld them after or will the area e "contaminated" to much to tig weld it after?
Machinist is offline
post #2 of 12 Old 03-17-2014, 08:21 PM
meatlord
Maximum Disaster
meatlord's Avatar
What type of mig? Flux will interfere with your TIG setup. I pretty much TIG everything we do at work. I would go for it and see, personally I prefer the TIG to all other welding processes anyways.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" SOLD. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 12 Altima 3.5 SR CVT / 00 Suzuki DR650.
meatlord is offline
post #3 of 12 Old 03-17-2014, 09:01 PM Thread Starter
Machinist
Miller 211 running mix gas.I will do a few tests tomorrow and post up some pics.Just started tig welding so don't laugh to hard!!lOL
post #4 of 12 Old 03-20-2014, 06:23 PM
Kenbo-Slice
You can tack with a mig and then tig over top of it when you go to finish the weld with no issues. Flux core welding isn't mig welding meatlord. Not trying to be an ***, I just don't want any confusion for the OP.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #5 of 12 Old 03-20-2014, 06:26 PM
meatlord
Maximum Disaster
meatlord's Avatar
I have used many wire feed setups with flux core wire on the same machine without the gas. Guess I did not specify that.
meatlord is offline
post #6 of 12 Old 03-20-2014, 07:36 PM Thread Starter
Machinist
Yea I did it the other day and didn't see any problems.I actually took some .045 mig wire and ran a tig weld with it tonight just to see.Worked decent enough for me right now
post #7 of 12 Old 03-21-2014, 04:59 PM
danielbuck
1946 CJ2
I've TIGed over MIG tacks, doesn't seem to be a problem. I imagine you could probably TIG over a flux core tack as well, so long as you chip off all of the slag and wire wheel/brush it good? I've not tried it though.
danielbuck is offline
post #8 of 12 Old 03-23-2014, 08:30 AM
AtTheHelm
Here's a trick I've seen before: if you're out of tig rods, take a length of mig wire, fold it in half and twist it up tight with a drill. Bam tig rod in a pinch.
AtTheHelm is offline
post #9 of 12 Old 03-23-2014, 09:38 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice!
BESRK is offline
post #10 of 12 Old 03-26-2014, 05:59 PM
Kenbo-Slice
Wire hangers work shockingly well too. They are made out of such a mishmash of metals that they work on damn-near anything in a pinch. I personally wouldn't do any critical welding with one but for an at-home repair or an emergency they are great. Try running a few beads with one for S+G's.
post #11 of 12 Old 03-31-2014, 09:53 PM
RenoF250
They are pretty hard and usually have that nasty coating on them. Why not bailing wire instead? Crappy steel also but no coating and softer.
RenoF250 is offline
post #12 of 12 Old 04-02-2014, 09:58 PM
XJTexas
A friend uses his torch rig to take that nasty coating off of coat hangers when he needs one. Just get it red hot for a second but don't breath the fumes as who knows what that stuff is??? Probably OK for general repairs but not structural welds IMHO. We mainly use ER-70S & ER-80S rods on 4130 metals.
XJTexas is offline
