tig newbee - JeepForum.com
post #1 of 11 Old 08-30-2013, 07:03 AM Thread Starter
zboss86
tig newbee
I'm a Tig newbee. Tried joining some mild steel. Yeah, it's ugly... Believe it or not, I cleaned the metal, but obviously not enough.
What getting me is I'm burning crater along the top edge of the weld.
guess I'll keep on playing...
Cleaning out the garage... check what I have for sale here:
http://midsouthjeeps.com/forum/index.php?/topic/20693-jeep-parts-for-saletradebumper-2-spacers-relocation-brackets/
zboss86 is offline
post #2 of 11 Old 08-30-2013, 05:57 PM
squire_wj
Your burning the top edge, which type of tungsten are you using and wjat size, what's your polarity? Also make sure your tungstin isn't getting contaminted. If you touch the filler metal to it you have to re sharpen it same goes if you touch the base metal.
squire_wj is offline
post #3 of 11 Old 08-30-2013, 08:13 PM
AGDubyaJ
I'm no TIG expert so correct me if Im' wrong, but you wanna run 10% thoriated tungsten, your gas at 10 CFM, and like Squire said- make sure you don't touch your tungsten to anything, and try adding a bit more filler into your weld puddle- your getting a little undercut and underfill at the toe of your weld and I would bet thats why your getting those little "craters". other than that, it looks like your consistency is there, and your getting it! Keep up the good work!
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #4 of 11 Old 08-30-2013, 09:21 PM
AtTheHelm
I'm not a tig welder, but I suspect not enough shielding gas is protecting the puddle. Looks similar to my mig welding beads if a strong breeze blows by.
AtTheHelm is offline
post #5 of 11 Old 08-30-2013, 10:31 PM
Ironworker709
Ironworker709's Avatar
That crater is called Undercut...
Your burning too hot and/or not putting enough filler in the puddle
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #6 of 11 Old 08-31-2013, 04:07 PM
youngjeepr
You are using to much heat.. Everyone exaggerates about contaminated tungsten to much, yes if it is contaminated (when apparent metal sticks to your tungsten) then you need to re sharpen it but a lot of times you don't need to re sharpen them.. You can see in the left side of your picture where you contaminated your tungsten (the orange smoke) on your material. You don't HAVE to use any certain type of tungsten it's really the welders preference. I use 2% thoriated on pretty much every type of material, from aluminum, mild steel, stainless, chromoly, magnesium and even titanium. Just keep practicing and you will start to be able to "read" your puddle and decide wether your using to much heat, not enough and even if your travel speed is correct.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #7 of 11 Old 09-14-2013, 08:33 PM Thread Starter
zboss86
3/32" - 2% thoriated tungsten, 1/16" ER70S-6 rod, #7 cup,
16 gauge sheet to 16 gauge tubing
I was welding outside with a slight breeze. I should have cleaned it better and the outside corner isn't as hard for me as an inside corner.
zboss86 is offline
post #8 of 11 Old 09-15-2013, 08:57 AM Thread Starter
zboss86
For some reason, I'm having problems welding laps joints. The top piece tends to pull away from the bottom as it heats up, especially with aluminum.
zboss86 is offline
post #9 of 11 Old 09-15-2013, 09:51 AM
youngjeepr
That last pass started good but then you got to hot.
When your doing the aluminum laps are your tacking both sides?
post #10 of 11 Old 09-15-2013, 11:32 AM Thread Starter
zboss86
Yeah, I think your right, guess I need to take some heat out of it. I was focusing on keep the puddle the same width and I made it too hot which took the dimes out of it.
On the aluminum lap joints, I sheared some 2"x6" strips of 1/8". I tack the edges and center. I start the puddle and form the "C" to bridge to the two pieces and as I start moving the along the seam, the top tends to peel back.
I guess I just need to play with it some more.
zboss86 is offline
post #11 of 11 Old 09-15-2013, 12:03 PM
youngjeepr
Try putting a bigger tack on both ends it shouldn't move more than maybe 1/16th"
