TIG on aluminum - JeepForum.com
post #1 of 10 Old 06-08-2013, 03:38 PM Thread Starter
Dumpsterfish
TIG on aluminum
First try...Whaddya think?
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
Dumpsterfish is offline
post #2 of 10 Old 06-08-2013, 06:24 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Better than my "first try".. Second from the bottom doesn't look too bad..
BESRK is offline
post #3 of 10 Old 06-08-2013, 07:19 PM Thread Starter
Dumpsterfish
Thanks! Spent all day since then reading up on/watching videos of technique. Can't a
Wait to grab some more scrap and try again.
I was amazed how fast the puddle can get rolling on aluminum. Fun stuff.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #4 of 10 Old 06-11-2013, 08:27 PM
Motobilt
I've been TIG welding for years. It takes time and you will constantly learn. I still go pick up scrap from time to time to simply try new things. What rig are you welding with?
-Dan DuBose
Dan DuBose - I Build Stuff!!!
Motobilt
Motobilt is offline
post #5 of 10 Old 06-12-2013, 12:09 AM Thread Starter
Dumpsterfish
We have a diversion and a dynasty 200 in the shop. These were done on the dynasty. Can't wait for some down time so I can get some more time on it...I'm a decent hand at TIG on mild/stainless, but for some reason Al makes me nervous.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #6 of 10 Old 06-12-2013, 01:57 AM
rebelbowtie
Dont be nervous aluminum is easy to weld its just a little harder to read the puddle. Once you figure it out you wont want to weld anything else ever again, TIG is my favorite process and aluminum is my favorite material.
rebelbowtie is offline
post #7 of 10 Old 06-12-2013, 10:20 AM Thread Starter
Dumpsterfish
Thanks. Does anyone make something like Millers iPhone weld settings app, only specific to AC TIG? Like recommended wave shape and frequency for various thicknesses?
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #8 of 10 Old 06-12-2013, 06:46 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
TIG is something i just can't get the hang of. try and try again i can't pick it up consistently. I can put two pieces together, ok with mild steel, and aluminum is probably my best, but stainless is the hardest for me.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #9 of 10 Old 06-16-2013, 01:31 PM
hmantractors
2004 KJ Liberty
Tig
Like anything it takes practice. Stainless is quite simple. If you can do carbon proper then you can do stainless. Most people turn up their gas to high. Turn up the heat to high. Do you know how to purge pipe or back purge. You have to keep the atmosphere away from the material. If you don't the back side of the weld will (sugar) turn an ugly non weldable problem. You will have to grind it out to weld properly. Good luck and have fun.
hmantractors is offline
post #10 of 10 Old 06-16-2013, 03:52 PM
youngjeepr
Not bad! I weld aluminum all day at work. Once you get the basics down the rest is easy.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
