Tie Rod vs. Track Bar....who will win? - JeepForum.com
post #1 of 5 Old 03-10-2011, 09:41 PM Thread Starter
rizingf3nix
The patient: 97 TJ with Skyjacker 6" longarm lift and 35" tires.
The issue: Trackbar bolt and tie rod end are meeting.
Provoked by: Adjusting the +10 caster back to +5 caster. Can't go back either, as the two components were already too close. Going to have to fix this one quick before there is a meltdown.
Options so far:
1. Rebuild the track bar bracket (running out of room already from the diff truss).
2. Replace the tie rod end with a heim joint (don't really want to drill out my drag link).
3. Replace the track bar end with a heim joint (wow...that's alot of work).
4. Replace the stock TJ drag link and tie rod with stock ZJ components and see if new hardware affords a little space (cool but kinda pricey).
I need some help deciding on this one. Any thoughts on the options or other options? Also, I'm not a master fabricator, but know how to do a little welding and have a saw. I can Bridgeport like nobody's business, but I'm short the Bridgeport, so simplicity wins the day.
Pics to follow
rizingf3nix is offline
post #2 of 5 Old 03-10-2011, 10:08 PM Thread Starter
rizingf3nix
post #3 of 5 Old 03-11-2011, 06:10 AM
dodger889
Why not move the track bar mounting?? Yes it would require you to do some cutting and welding. But on the KISS program seems to be the easiest to do.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #4 of 5 Old 03-11-2011, 06:56 PM Thread Starter
rizingf3nix
Well, space in that area is at a serious premium. It's tucked right next to the coil spring on one side, and the diff truss on the other. I have about 1/2 of shift going backwards, but where the bold is, it would require the bar to be shortened in order to get it past the spring.
I was talking to someone today at our local tie rod shop (Rod End Supply http://www.rodendsupply.com). The tie rod is stock, so aftermarket tie rods for it are rare because of the 11/16 shaft size, but they directed me to Speedway Motors in Lincoln - http://www.speedwaymotors.com. They sell a stud kit that fits into a tapered hole. Rod End Supply has a radial riviter that can swedge the stud into the bie rod end, and I can convert the rest of the tie rod to non-stock.
In the mean time, I cut a notch into the bolt so the tie rod doesn't continually rest on the head. Not a long term solution, since there is still a minor amount of contact, but I'll probably end up converting the tie rod to custom with heim joints.
If I win the lottery, I'll convert to an HD sterring solution.
post #5 of 5 Old 03-11-2011, 07:08 PM Thread Starter
rizingf3nix
So as an update, after setting the caster on the front end to the correct setting, I *enjoyed* a day of driving my jeep with no forward tracking whatsoever, and some serious thrust angle problems.
After getting home early, my trusty sidekick and I measured the distance between the two axles and found that there was a 1/4 inch diff between the driver and passenger side. After all was said and done, We put about another degree of + caster on it, adjusted the 1/4 difference out using the control arms, and found/reduced the 1/2 " toe in to 1/16. Only took two tries, but now Roxy is tracking like a champ.
drag link , steering , tie rod , tj , track bar
Narrow track vs. wide track c17load83 Engines & Drivetrain 5 10-20-2010 09:20 PM
New track Bar jstanford General Jeep & Off-Road Equipment 0 01-23-2009 02:45 AM
track bar roachy20 Tires & Wheels 1 03-26-2006 02:02 PM
track bar FLYJ95 Tires & Wheels 4 12-14-2005 10:22 AM
track bar ? FLYJ95 Tires & Wheels 2 12-14-2005 08:55 AM
