Thinking of buying a welder - Page 6 - JeepForum.com
post #76 of 402 Old 01-18-2008, 12:17 PM
jonzer12
Save your money. Clarke is probably the best of the el-cheapo welders if there is such as a thing but if you actually plan on getting in to welding it is a poor investment. You will just end up trading up in a year or two. I have used a clarke 110v mig welder before and it was fine for heavy sheet metal but that is about it. On paper it should have been able to do more but it just didn't produce enough heat.
In North America there are only two real options for the home welder, Lincoln and Miller (Hobart is made by miller).
If money is tight save up a extra $150 and buy a lincoln or miller off ebay. You can get a Lincoln or Miller 180 for around $500 sometimes new. I did.
jonzer12 is offline
post #77 of 402 Old 01-25-2008, 06:28 PM
Zlake
Zlake's Avatar
Ok after reading through this entire post I am still unsure. I see stick this or MIG that but I am still unsure.
I have only welded stick and I have taken a few intro. welding classes with stick. I would like to stay around $500 for a welder.
I am looking at being able to fab my own things like bumpers and skid plates. I am also going to need to be able to do things like repair rust spots on my body and fix exhaust hangers and the like. I really want an all around machine but I want to be able to weld 1/4" for bumpers. What do you guys think??
I have been looking at the Lincoln Pro-Mig 180's and the Lincoln 220v stick welders. Opinions?
Zlake is offline
post #78 of 402 Old 01-25-2008, 08:08 PM
Bigbob
Bigbob's Avatar
$500.00 and 1/4" don't mix with Mig IMHO. Duck soup with stick.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #79 of 402 Old 03-01-2008, 05:14 PM
OldFatGuy
That Miller 251 reminds me a lot of my Lincoln Power Mig 255 (which isn't really very visible in this picture).
OldFatGuy is offline
post #80 of 402 Old 07-14-2008, 07:30 PM
f3x
Well if you HAVE to stay at 500.00 then get the largest machine (highest Amps) mig you can and run fluxcore wire. Not as clean as Mig but it's a stronger weld, and with fluxcore your machine will easily run 1/4.
You can shop around a lot but this may be a good deal http://www.northerntool.com/webapp/w...2924_200342924 Under 500.00! 175 Amps and Northern will stand behind it. this one comes with gauges so you can run gas no issues.
f3x is offline
post #81 of 402 Old 07-16-2008, 08:56 PM
shinerm02
Does anyone have any experience or know anything about the hobart rc-256? Would this be a good welder for jeep projects ( body repair/ bumpers etc.) I did a search but can't find any info.
shinerm02 is offline
post #82 of 402 Old 07-16-2008, 09:31 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
That is way overkill. From what I can find online, that is also a 3 phase machine.
Where are you finding this machine???? Gonna be expensive as hell to get 3 phase in your garage.
So in short, OVERKILL. It prolly wont go "low" enough to sheet metal anyway.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #83 of 402 Old 07-17-2008, 04:34 AM
shinerm02
I have a variable frequency drive that makes three phase power for some of the woodworking tools I have already. I found that welder at a Industrial surplus place for $129.00. I just did not know if it would do the sheet metal work.
Last edited by shinerm02; 07-17-2008 at 04:42 AM. Reason: better way of saying what i meant
post #84 of 402 Old 07-17-2008, 04:37 AM
shinerm02
The same place has a miller CP-200 for sale as well. Would that one be any better for the body panels?
post #85 of 402 Old 08-04-2008, 06:56 PM
hardrockwyo
1987 YJ Wrangler
Just bought the Hobart 187H very impressed on the amount of wire it can put down and purty beads. A whole lot better than the old Campbell Housfield 90 I burned up. Also have the Hobart 235 A/C- D/C Stickmate
hardrockwyo is offline
post #86 of 402 Old 08-07-2008, 09:20 AM
guitarZERO
That Powermig 255 is a killer machine...it's the machine that I primarily used in industry from everything from 20 gauge mild steel to 3/4" plate. For a general home fab setup this is definatly the way I would go. Stay away from the stick welders and the flux core wire...for less experience welders and what you want to do (make Jeep toys!) generally a machine like this ran with .035 solid wire and 75/25 shield gas will do everything you ever want and more. They do run about 2500-2700 new...but they do pop up used on craigslist now and then.
Man what a great machine...I run two of them, plus an old reliable ESAB Mig in the welding classes I teach...
-"If you are afraid to "fly" then don't expect to go very far..."
-"Your mistakes do not define you, they tell you who you are not..."
-"Mercy is for the strong."
guitarZERO is offline
post #87 of 402 Old 08-11-2008, 07:47 PM
yjcrawler
Im looking to buy my first welder as well. but im in a bit of a predicement, i can only get a 110v and ive only got $500. I was looking at the clarke 110v stick machines which say they can weld up to 1/4 inch but not sure thats true, but i was also leaning towards the hobart handler 140. I need some experienced welders advice as to what i should do. thanks
Soon to be SOA with 14 Bolt SF rear, D44 front and 38's
Early YJ Club, Member # 33
yjcrawler is offline
post #88 of 402 Old 08-11-2008, 08:47 PM
Bigbob
Bigbob's Avatar
Between the 2 I'd go Hobart. You can weld 1/4" on flux core, but from my Lincoln 140 amp experience I would trust the welds like a wet fart.
6 Speed, Hardtop
Bigbob is offline
post #89 of 402 Old 08-12-2008, 08:59 PM
yjcrawler
what is the main difference in capabilities of the lincoln ac/dc vs the hobart ac/dc besides the 100 dollar price difference. i found out today that 50 amp power is available in my garage.
post #90 of 402 Old 08-13-2008, 12:30 AM
Bigbob
Bigbob's Avatar
I have used both. I wore out 2 Lincoln AC DC 225 welders over the years. Both were very dependable. I recently bought the Hobart AC DC 235 stickmate which is basically the same as the Miller Thunderbolt 235/160. It is much more compact and instead of notching through the amps it has an infinite crank adjustment. As far as work goes the Hobart has a better adjustment feature. As far as dependability I can't say much for the Hobart as I have only had it a short period of time. I have run tons of rod through Lincolns with little or no problems at all. I think the Hobart is noisier when running on AC.
What prices are you looking at? Which one is $100.00 more? They used to be about the same price.
6 Speed, Hardtop
Bigbob is offline
need help w/buying new mig welder rodjr Fabrication Shop 15 10-20-2009 11:31 AM
Thinking about buying a welder to learn on... C-Mil Fabrication Shop 5 09-17-2009 10:17 AM
Thinking of buying a welder... (i read the sticky ) jamoka3 Fabrication Shop 12 01-14-2009 11:27 AM
Buying a welder, is this a decent deal? Millermatic Vintage raskull Fabrication Shop 13 09-29-2008 09:50 AM
Thinking about Buying.... cjtaylor0103 Engines & Drivetrain 0 09-04-2008 01:08 PM
