Thinking of buying a welder - Page 27 - JeepForum.com
post #391 of 402 Old 02-26-2014, 08:08 AM
Brut4ce
2010 JK Wrangler
Just unplug your wife's dryer and run a miller 251 or 252!!!!
Lol
"There's plenty of time to rest when your dead or knocked out!"
BUILT FOR THE ROCKS BUILD
Brut4ce is offline
post #392 of 402 Old 05-13-2014, 05:47 AM
96_zj_laredo
Has anyone used the northern tools st80i 115 arc welder? http://www.northerntool.com/shop/too...2862_200512862 I'm getting into welding and I have arc welded a few times before and I want something for my house that I can use on various things such as my tractors, my jeep, etc. but I don't have a 220v outlet, so I need something for 115. Does anyone know if this seems to be a good deal?
All I need in life is my Jeep, my guns, and my wrenches... And maybe some fine women too
96_zj_laredo is offline
post #393 of 402 Old 05-13-2014, 09:38 AM
Bigbob
Bigbob's Avatar
It's a good deal at the price, but not much you can do with it. The 20% duty cycle will drive you crazy. And they even say in the video "up to 1/8". If it's impossible to get a 220 volt 30-50 amp circuit put in I'd look at a good brand name 110 volt Mig. But even those have a terrible duty cycle. I have a 110 volt Lincoln and a Hobart 220 volt AC/DC stick. I use the Mig for sheet metal and 1/8" and below metal. The stick comes out for everything else. The bottom line is, if you want to weld a lot and good without frustration you need 220 volts. A 180 amp and above 220 volt brand name Mig is what you really want. Not cheap but what you need. I intend to get rid of both my welders and get a Hobart 220 volt 190 amp mig one day.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #394 of 402 Old 05-13-2014, 10:16 AM
96_zj_laredo
So if I was going to be welding here and there for mostly fabrication stuff but maybe also sheet metal, all while on a high school students budget, what would you recommend? I could probably convince my parents to let me put in a 220v outlet if need be. Also I'll be doing all my welding outside as I don't have a garage
post #395 of 402 Old 05-13-2014, 10:35 AM
Bigbob
Bigbob's Avatar
Get a brand name 110 volt Mig. I have a Lincoln 140 but also check out Miller and Hobart. Sometimes the Hobart's (basically the same as Miller) can be on a great sale at Tractor Supply Company. Many say the Lincolns they sell at Home Depot and Lowes are junk, but I got mine at Home depot and it has been very dependable. 140 amp is as big as 110 volt Migs come so get that. You can start out just using .30 flux core until you come up with the $$$ to buy a gas setup to do .25 mig. On anything over 1/8" you want to do flux core anyway. I have welded 3/16" and even 1/4" metal flux core multi pass with my little Lincoln. The duty cycle can drive you nutz! On 3/16" and 1/4" stuff I can weld a lot better and extremely fast with my big stick welder.
Another option, (that I will get flamed on!), is to get a lincoln 220 volt buzz box 210 amp AC stick welder. They sell them at Home depot and Lowes in the $300 range. With the money you save over the 110 volt mig you can have a 220 volt 50 amp plug installed. The buzz box welds are not near as pretty as Mig welds, but you can weld anything with convenience except thin sheet metal. I have worn out 3 of those buzz boxes in the last 40 years. Great dependable welders.
6 Speed, Hardtop
Bigbob is offline
post #396 of 402 Old 05-14-2014, 10:03 AM
96_zj_laredo
Get a brand name 110 volt Mig. I have a Lincoln 140 but also check out Miller and Hobart. Sometimes the Hobart's (basically the same as Miller) can be on a great sale at Tractor Supply Company. Many say the Lincolns they sell at Home Depot and Lowes are junk, but I got mine at Home depot and it has been very dependable. 140 amp is as big as 110 volt Migs come so get that. You can start out just using .30 flux core until you come up with the $$$ to buy a gas setup to do .25 mig. On anything over 1/8" you want to do flux core anyway. I have welded 3/16" and even 1/4" metal flux core multi pass with my little Lincoln. The duty cycle can drive you nutz! On 3/16" and 1/4" stuff I can weld a lot better and extremely fast with my big stick welder. Another option, (that I will get flamed on!), is to get a lincoln 220 volt buzz box 210 amp AC stick welder. They sell them at Home depot and Lowes in the $300 range. With the money you save over the 110 volt mig you can have a 220 volt 50 amp plug installed. The buzz box welds are not near as pretty as Mig welds, but you can weld anything with convenience except thin sheet metal. I have worn out 3 of those buzz boxes in the last 40 years. Great dependable welders.
Do they sell an extension cord for a 220v outlet? I could run a cord from my dryer's hookup in my basement out the bulkhead to outside (don't wanna weld in the basement) that buzz box sounds like a good deal if I can get better access to 220v. How is the duty cycle for the buzz box?
post #397 of 402 Old 05-14-2014, 10:38 AM
Krooser
I have a 25' extension cord for a 220V welder… but I now only have a 110V Hobart.
With your budget and experience I'd buy a good Hobart, Lincoln or Miller 110V MIG unit. I've owned about a dozen machines over the years and I love the newer MIG welders.. both 100v and 220V.
Duty cycle is important to guys in production shops but really has never affected my work in my shop. After all how often are you going to weld 12 minutes in an hour without a break? every time your welder is idling your welder cools allowing more welding time. I have fab'd race cars, trailers, a frame jig and hundreds of other projects with a 20 or 30% duty cycle welder. I have never had an issue… if you find the arc starting to get erratic just take a little break to let it cool down.
I can recommend the Hobart 175 which I now own. The previous unit I had was a Miller 175 (220V)… before that I had three Miller 35's (old technology) and a Lincoln 250 (220V). I also owned a little Lincoln 100… great 90 amp welder. Any of the brand name machines will do fine. Don't buy any Chinese MIG machine… junk with little aftermarket support.
Krooser is offline
post #398 of 402 Old 05-14-2014, 11:58 AM
Bigbob
Bigbob's Avatar
Depending on the length of the cord an extension works just fine. You want at least a 10 gauge wire size. The buzz box has virtually a 100% duty range on most all welding you will do. You rarely weld over 120 amps with it. Usually in the 90-110 range with 1/8" rod. The dryer plug is 30 amp and even though the buzz box calls for a 50 amp you should have no problem.
The buzz box (Lincoln 225) runs about $300 right now at most places. The Lincoln 140 amp 110 volt Mig runs about $525 sans gas tank.
6 Speed, Hardtop
Bigbob is offline
post #399 of 402 Old 05-14-2014, 08:10 PM
96_zj_laredo
Thanks for the help guys, I'll mull it over an let you know what I end up with! Final question tho, will a 110 mig be enough to weld up 3/16" and/or 1/4" steel?
post #400 of 402 Old 05-16-2014, 09:22 AM
96_zj_laredo
Ended up deciding on this one, it's on sale and the only one that really fit my budget, northern tool seems to have a good reputation too http://www.northerntool.com/shop/too...3263_200403263
post #401 of 402 Old 03-17-2015, 04:03 PM
Boover
Anyone been able to get their hands on the new Lincoln 210 multi process???
85' CJ7 Laredo, 258 I-6, T-176, Dana 30, AMC 20
99' WJ Laredo 4.0L NP242, RC Long Arm, 44a vari lok
Boover is offline
post #402 of 402 Old 03-17-2015, 04:24 PM
mtrdstuck
1975 CJ5
I got one 210mp in feb its a great little unit. for the price cant beat it
mtrdstuck is offline
need help w/buying new mig welder rodjr Fabrication Shop 15 10-20-2009 11:31 AM
Thinking about buying a welder to learn on... C-Mil Fabrication Shop 5 09-17-2009 10:17 AM
Thinking of buying a welder... (i read the sticky ) jamoka3 Fabrication Shop 12 01-14-2009 11:27 AM
Buying a welder, is this a decent deal? Millermatic Vintage raskull Fabrication Shop 13 09-29-2008 09:50 AM
Thinking about Buying.... cjtaylor0103 Engines & Drivetrain 0 09-04-2008 01:08 PM
