Thinking of buying a welder - Page 18 - JeepForum.com
post #256 of 402 Old 07-13-2010, 05:38 PM
zachbh
Ironworker (or anyone),
I know this is probably a stupid question, but my house has a 250V outlet in the laundry room.... However, from what I've been able to dig up about the welder I've been looking at, it's able to run off of 208 230, or 460 V. Is there anyway to make this work? Besides having another outlet installed in the garage. I was planning on running an extension cord for the time being. Here is the link to the manual http://content.lincolnelectric.com//...r/im/IM315.pdf
Thanks guys.
zachbh is offline
post #257 of 402 Old 07-13-2010, 06:22 PM
thatnameisinuse
It should be wired for 230v
thatnameisinuse is offline
post #258 of 402 Old 07-13-2010, 10:23 PM
Bigbob
Bigbob's Avatar
Thanks guys.
You can probably put a voltage gauge there and see that you probably have 210-240 actual volts.
Laundry room probably =30 amp breaker for a clothes dryer. I don't think you can run the welder in your link above on a 30 amp breaker.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #259 of 402 Old 07-14-2010, 09:47 AM
zachbh
Damn, I figured as much. Thanks guys. Anyone looking at the welder I mentioned, it's in northern CO.
zachbh is offline
post #260 of 402 Old 09-09-2010, 09:52 AM
deerhunter1911
Im in a welding class now and i just talked to my instructor about the Dryer circuit; it is 230V but its a 30Amp breaker, meaning it won't run a welder. You need a minimum 50 amp breaker and there is a bit about being number 6 carrier cable (i forget the correct term). Im thinking about running a line out to the shed with a 50amp breaker; should know how to do that by the end of the semester
I am slowly, but surely fixing everything Jeep f'd up...
My super slow build:
Red Jeep Club member # 389
FLY NAVY!
deerhunter1911 is offline
post #261 of 402 Old 09-09-2010, 09:58 AM
Ironworker709
Ironworker709's Avatar
I run my Lincoln 180 on my dryer plug regularly,30 amp breaker with no problems what so ever.
I think the 50 amp they require is only to get maximum heat out of it ,i weld heavy steel with it(1/4"-1" thick with multiple passes) and yet to have a breaker go off or even the cord warm or hit the duty cycle
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #262 of 402 Old 09-09-2010, 10:27 AM
bigtim6656
I have took mig and taking arc now at my college. I think mig is the way to go unless your welding real thick stuff.
I got lucky though, our class runs high end welders and their moving the welding shop to a new building with all new stuff. So at the end of the semester their selling all the welders to the students for 100 to 200 bucks. The mig welders are miller 252 and run 2k new. Going to try and pick up a mig, tig and arc machine. The instructor said he did not think me getting one of each would be a issue.
bigtim6656 is offline
post #263 of 402 Old 09-11-2010, 01:37 PM
Jim Shanks
Jim Shanks's Avatar
I have one of the Miller 211 Autoset's as well. I really like the portability of it with the MVP plug. 220V at home, or 110V at a buddies place to work on his junk. Best of both worlds.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #264 of 402 Old 09-19-2010, 04:00 PM
thatnameisinuse
What iron worker said , same machine same setup no problems
post #265 of 402 Old 09-21-2010, 09:17 PM
Warlord2
I also run the lincoln 180 Home Depot one and am using a 35 foot 12 gauge wire from the laundry room to garage. Any longer and you will need 10 gauge. Never blown a breaker, these welders only draw about 20amps max though so a 30 amp breaker should never blow.
GREAT welder, know a lot of people that make custom roll bars and suspensions for there prerunners that just use this welder for everything. Doesnt have all the fancy controls, but the work that I do, just dont need them.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #266 of 402 Old 10-15-2010, 10:00 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Another noob looking to get a welder. i have stick welded a couple times and that's it. Too many projects on my jeep are held up because I don't have the equipment and skill.
I don't have the spare cash to get a 220, so I am going with a smaller mig. This will be for learning, fixing my shock tabs, re-doing my spring perches, cage to frame, and anything else that comes up with my jeep over the next few years.
the plan is to use flux core just to keep things simple for me.
So
Miller?
Hobart?
Lincoln?
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #267 of 402 Old 10-15-2010, 02:33 PM
Ironworker709
So
Miller?
Hobart?
Lincoln?
Anyone of them are high quality machines..i beleive the hobart and lincoln bein around the same price and the miller much higher
Never forget 9/11
post #268 of 402 Old 11-08-2010, 11:28 AM
ytowntj
So instead of starting a new thread I thought Id revive this one.
Im looking at getting a stick welder for bumpers/skids etc.
What is the general consensus on the Hobart Stickmate 205? Its 220 AC only.
Is this a good route to go? The AC only stickmate is $279 locally. For a nice AC/DC 220 stick I am looking at over $500. For that 200 dollar difference I can pick up a low power flux core welder for sheet metal/exhaust work. Would this be better than trying to do the sheet metal on DC with a 220 stick?
Thanks!
ytowntj is offline
post #269 of 402 Old 11-08-2010, 05:21 PM
wushaw
Rockin jeep
wushaw's Avatar
I have one and it works just fine, I don't use it much since I have a Hobart 230 but it does work good for what I have used it for.
wushaw is offline
post #270 of 402 Old 11-25-2010, 05:45 PM
jose_p_adams
I'm planning to buy a MIG welder pretty soon here. My budget should be about $1000 but I don't have to spend that much. I'd like to be able to get the machine, tank and probably a cart on the budget. Plans for use include welding brackets on axles, bumpers, other miscellaneous stuff.
Is it worth the extra cost to buy the 210 amp machine over a 180 amp machine? Worth the extra cost for the Miller?
jose_p_adams is offline
need help w/buying new mig welder rodjr Fabrication Shop 15 10-20-2009 11:31 AM
Thinking about buying a welder to learn on... C-Mil Fabrication Shop 5 09-17-2009 10:17 AM
Thinking of buying a welder... (i read the sticky ) jamoka3 Fabrication Shop 12 01-14-2009 11:27 AM
Buying a welder, is this a decent deal? Millermatic Vintage raskull Fabrication Shop 13 09-29-2008 09:50 AM
Thinking about Buying.... cjtaylor0103 Engines & Drivetrain 0 09-04-2008 01:08 PM
