Thinking of buying a welder - Page 10 - JeepForum.com
post #136 of 402 Old 03-26-2009, 07:06 PM
XJaggerated
Thanks fatman, I went ahead and bought it, with the exact reasoning you stated!
:Cheers:
'99 XJ Sport 4.0 4x4 @ 155k
AW-4
NP-231
C8.25 -22inches from hub to fender. how big is my lift?
XJaggerated is offline
post #137 of 402 Old 03-26-2009, 08:29 PM
Bigbob
Bigbob's Avatar
Originally Posted by XJaggerated View Post
I'm interested in learning to weld.
I'm going to take a class this summer. Would this unit be something that would work for a new guy?
It's $50 by the way.
Yeah, if it works. Like said before, you may be tossing $50.00.
The duty cycle is extremely bad on that machine. I'd stick to 3/32 and 1/8" rod as it appears at 130 AMP AC the duty cycle is only 10%. Most rod for the Jeep is 3/32 or 1/8 anyway.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is online now
post #138 of 402 Old 03-26-2009, 10:07 PM
69cj5
Already have a lincoln ac/dc 225 stick welder for the heavy stuff. I have been thinking about what I should get next. mig or tig? I want to be able to weld aluminum, sheet metal and Use it to build my roll cage. I borrowed a friends miller 185, 220v mig to do the floorboards in the jeep and it worked well. But I really like the look of a good tig weld. Lets say the budget is 3k which way would you go tig or mig and which machine. Thanks
BEsrk I just drain the fluids, attach a strap to the top of the cage and pull the vehicle over in the backyard.. strap only costs $15. Or.. I just drive up a tree with one wheel until the rig flops on its side.. too easy and that one's free.
69cj5 is offline
post #139 of 402 Old 03-26-2009, 10:20 PM
LordEnki
2006 WK
$1700.00
miller diversion 165 tig
http://www.millerwelds.com/products/tig/diversion_165/
maybe?
LordEnki is offline
post #140 of 402 Old 03-28-2009, 06:03 PM
dbennett48
1946 CJ2A
I recently bought a MillerMatic 180 with the Auto Set feature. It works very well. I have played with it in several of the manual settings and the Auto setting. Auto works as well or better than anything I manually set. I like this welder.
Dave
Jeepless at the moment
dbennett48 is offline
post #141 of 402 Old 04-22-2009, 04:13 PM
Jeepguy1977
Jeepguy1977's Avatar
Dave
Yeah, I am thinking I may go a similar route when I buy one finally. I miss the old syncrowave 250 where I used to work.
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline
post #142 of 402 Old 04-23-2009, 08:59 AM
pmccoy9876
OK, I saw this on craigslist, and I want to look into it, but it seems a little fishy. Has anyone seen/used a MATCO welder before? I know they have a great reputation for tools, but I've never heard about their welders.
Here's the link to the ad, the guy doesn't include much info, but $450 seems really low for a 230 Volt MIG.
http://orlando.craigslist.org/tls/1135133166.html
Originally Posted by MrNate View Post
Are you insane? Do you have any idea how many slip-and-fall accidents are caused by carelessly discarded banana peels? This is a crime of Vaudevillian proportions and must not be tolerated in a civilized society.
Originally Posted by RyanCJ2A View Post
I have no input of any value to this thread but those are awesome.
pmccoy9876 is offline
post #143 of 402 Old 04-23-2009, 09:31 AM
Bigbob
Bigbob's Avatar
I know nothing of their welders.
http://www.matcotools.com/Catalog/to...ype=T&cat=2420
6 Speed, Hardtop
post #144 of 402 Old 05-07-2009, 12:44 AM
Firedog13
I'm looking to buy a welder probably this month. I have narrowed down my search to the Millermatic 180 Auto-Set and the Millermatic 211 Auto-Set. I'll be using it to hobby weld. Shop carts, tables, roof-rack, brackets for under-body lights, etc. I don't intend to weld bumpers as the Jeep already has the ones I want. I'm probably buying a welder larger than I initially need, but I'm sure that once I get the hang of it, I will want to start welding larger things. I will most likely be welding together some pipe fence in the future. Just don't want to buy something and then find that it ends up being too small for future projects. I like that the 211 can run on 110 or 220 current. I will need to get someone to install a 220 line. Anyone have any comments on the comparison. Leaning towards the 211, but I hear people speaking highly of the 180.
Firefighters Jeep Club
All gave some, some gave all.
Firedog13 is offline
post #145 of 402 Old 05-07-2009, 01:35 AM
OldFatGuy
How many amps does that thing draw on 110V? Seems like it would be an awful lot.
OldFatGuy is offline
post #146 of 402 Old 05-07-2009, 02:06 AM
Firedog13
90 amps at 20% duty cycle. 150 amps at 40% on 220. The 180 draws 130 at 30% and it runs on 220.
By the way, I love the name - OldFatGuy - very funny.
post #147 of 402 Old 05-07-2009, 06:14 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
20 amps with 110V output range: 30 − 140
24.3 amps with 220V output range: 30 − 210
Looks like they built in some safety features.
rustywrangler is offline
post #148 of 402 Old 05-07-2009, 11:39 AM
OldFatGuy
Gotcha. So the full rated output is not available on 110V. That makes more sense.
post #149 of 402 Old 05-11-2009, 03:15 AM
cliffbong732
Ive been looking into doing some custom fab work from home with a basic garage set up. Im pretty new to welding, and still trying to figure out what will work best for me. Learning wont be to difficult for me, as it runs in the family and ill have all the help I need. Im trying to stay away from gas. I would also like to be able to make decent welds with the machine. Ill be doing bumpers, racks, and re-enforcement on the frame. Basically anything I want to weld on the jeep I would like to be ready for. Im looking into the range of $400-$600. Any suggestions? Thanks for the help.
cliffbong732 is offline
post #150 of 402 Old 05-18-2009, 06:03 PM
Brads_nky_yj
What do you guys think about the Hobart Handler 187? The local Tractor Supply has em and I know some people down there so I can get a decent discount. I plan using the gas mixture with it. I will be using it for everything from all the welding for my SOA conversion this summer, to boatsides, to tube fenders, trusses and to some sheet metal work. Anyone have this welder and what do ya think?
And all you guys who reccomend Miller, I understand what you are going to say, but Im in college and dont have an unlimited amount of money. Plus we have a Hobart Stickmate here at the house and it has never let us down one bit, so getting another Hobart would be fine.
BTW this would MY first welder and I plan on keeping it for a while, until I get my own place and what not. Thanks
93 YJ - SOLD
Brads_nky_yj is offline
need help w/buying new mig welder rodjr Fabrication Shop 15 10-20-2009 12:31 PM
Thinking about buying a welder to learn on... C-Mil Fabrication Shop 5 09-17-2009 11:17 AM
Thinking of buying a welder... (i read the sticky ) jamoka3 Fabrication Shop 12 01-14-2009 12:27 PM
Buying a welder, is this a decent deal? Millermatic Vintage raskull Fabrication Shop 13 09-29-2008 10:50 AM
Thinking about Buying.... cjtaylor0103 Engines & Drivetrain 0 09-04-2008 02:08 PM
