Im very much a newbie to the world of welding, but I would really like to get into it since it opens up alot of fabrication doors for me.
I have welded once or twice with a mig welder (wire), it was a hobart handler, ran on 120v
I would like to purchase something with a little more capability, since I hope to build up bumpers and basic bull bars, along with being able to fix up my exhaust.
I am looking into purchasing a lincoln 220v stick welder (since they seem very cheap and have a good reputation)
I do not, however, know how to stick weld, though I have been watching videos.
I am just confused on one thing really, I though you needed argon (or some other gas) being exhausted onto the weld pool, but from the looks of it, with a stick welder, you just put the stick into the stinger, and attach the other end to your work, and just go at it by making an arc. how can this be? How do you give it an arc sheild? Do you need an arc shield?
That is the whole point of stick welding, you do not need any gas. The coating around the stick is what burns and gives the sheild to the puddle. I think you are thinking tig for argon.
Stick welding is just set, clamp, throw your sheild down and strike an arc. Personally, for home use, a mig is going to get you further than stick will.
i've been using a friend's Lincoln Electric Pro-Mig 175. So far we've made a big steel rack to hold scrap & 20 ft lengths, a hard top hoist for my jeep and a 4ft x 4ft steel welding/workbench. We haven't used Argon once yet, all done using flux-core. I've gotten pretty good at the flux-core and I'm looking into getting an Argon bottle & solid wire to get a nice weld on the next project - a tire carrier.
You don't need Argon to weld, you can do it with flux-core, the shielding is inside the wire. Only bad part is you get some porosity and a yellowish residue you need to wire brush off. Sometimes you need to cap the weld or grind a bit to make it look good.
If cost is any consideration the stick welder will be king in your book. I have had 3 different Lincolns, 2 in the 225 A/C version and 1 of the 225 A/C-D/C flavors. The A/C-D/C is by far a more versatile welder. If I were to buy one today I would get the Hobart 230/160 A/C-D/C stickmate as is is more compact and has a better amp adjustment system. It runs in the neighborhood of $440.00-$475.00. TSC seems to have the best price on these.
If you want to go Mig the Handler 187 or 210 are good welders. With gas tanks and a carrier they do run about twice as much as a stick welder.
The advantage to a stick welder is;
1. You can weld heavy stuff very well on the cheap.
2. If the metal is a little dirty or has some rust the stick does not care.
3. Duty Cycles are almost always better with a stick welder.
4. You can change rod size and amps very easy.
The advantage to a Mig is;
1. Very nice looking welds if you have a big enough machine.
2. For some it is easy to learn. (I'm still trying to figure out Mig after welding stick for 30 years)
3. Most 180 amp size mig rigs require 30 amp instead of the 50 amp service for stick.
4. You can say you have Mig and razz the stick guys! :teehee:
Seriously speaking. If you want to weld gas shielded MIG on heavy gauge(3/16"-1/4") metal with some confidence you will need a large Mig. The 180 amp 220 volt units are about as small as you can go IMHO. Flux core welding you can do with them very confidently. But flux core and stick welding are about equal in looks to me. Stick welds do not look as good as gas shielded Mig welds. But as far as strength goes they are the same. BTW, whether gas shielded or flux core anything you weld with a mig rig needs to be really clean. Zero contamination or rust.
I have the Lincoln 140 amp mig and it can weld gas shielded up to 1/8 pretty good. The specs for it only say up to 10 gauge metal, but I am confident in my gas shield welds on 1/8" stuff. With .030 flux core you can weld up to 3/16" single pass if everything is squeaky clean and you max out the amps. I have done 1/4" multi-pass, but I don't like it and don't trust it. Just not enough heat. And the duty cycle sucks big time. I can only weld about 12"-18" of bead on 3/16" material before she shuts down for a breather. A 225 Stick machine can weld 3/16" all day without a hiccup.
I currently do not have a stick welder. But I will get one one day. For as much as I weld I am having a hard time justifying $575.00-$650.00 it would cost me to buy the welder and get 50 Amp power to the garage.
now i have another question. I like the idea of the stick welder, since I really dont care about asthetics of the weld, Since i would likely sand and paint anything I weld.
So, can you tell me, is a stick welder delicate enough to weld exhaust, but also strong enough to build a bullbar?
Yup. It takes a little practice welding sheet metal on A/C. If you get an A/C-D/C unit it is duck soup. The A/C only rigs will need to be turned way down and use a 3/32 rod. It will be similar to a flux core weld.
Bullbar is no problem at all. Even the Lincoln buzz box 225 can weld 1/2" multi-pass pretty darn good.
Once you get the drift of welding D/C stick the welds with 7018 will look almost as good as gas shielded Mig.
The 2 welders I listed above, the A/C-D/C Lincoln and Hobart, can weld 1/4" steel with great confidence using D/C 7018 in one pass.
If you can swing it the A/C-D/C units are the way to go. They usually will cost about $150.00 more.
Same welder. A/C = Alternating current D/C = Direct current. It will use a 50 amp 220 volt circuit. Technically what and why they work different is best left to some smarter than me to explain. But I do know on the D/C setting there is better control and the action is much smoother.
On D/C you can change the polarity. Negative or positive ground. This helps with penetration which comes in handy while welding sheet metal.
Great for that guy with loads of cash sitting around collecting dust. But a little over the top for someone who welds in his garage every once in a while. :laugh:
It's kinda like buying a Kenworth dump truck to haul your trash to the dump 3 times a year.
Q for you experienced guys talking about thickness - I have a Lincoln 175 and was under the assumption I could really go as thick as I wanted as long as multi passes are made. Is this not true? I would think as long you make enough passes to burn it all together, then all would be good. Does the 175 limit me to thickness even if multi passes are made? Great Sticky by the way.
Yes and no. How thick are you talking? I think the 175 is rated for 5/16" thick. I am sure that is flux core. The first pass is usually the important pass. You want to get as deep of penetration as possible. Then the rest of the passes are going on either side of the first pass. Again you are wanting to go as deep as you can on these secondary passes. Once done with the first pass you will need to clean the bead and area of all slag. A wire wheel on the grinder works well for this, but that wire gets to flying do cover any body parts you don't want wire stuck in. I find on my flux core welding a chipping hammer is not needed as the wheel gets it all clean and ready for pass #2.
I thi8nk the 175 can do 1/2" multipass without an issue. Someone on here will chime in.
No thickness in mind, just trying to fully understand the concept.
The rating is basically a single pass rating right? My thought process was that since you are really only welding say 1/4 inch or so thickness at a time, that once you get to a thickness that requires multi passes, then thickness really becomes a mute point, and you are really talking about number of passes instead of thickness. I have only used gas, no flux core yet. So if I can only go 3/16 or so with gas, then I should be able to do 3/8 as long as I make 2 passes, and 3/4 as long as I make 4 passes, etc.
Your concept is correct but the number of passes is wrong. For the best welds durring multiple passes, you want to weld in a beveled area. Usually both sides cut at 45* angles so your first pass (root pass) bonds the metal then your next few passes cover and fill. If you were to weld 1/2 plate 3/16 at a time you would need 3 total layers but 6 beads. root pass, 1 bead then next layer run one bead on each side of root pass then top layer you would run 3 overlapping passes to finish it off. All while cooling ALOT in between.
And always clean out as said above after each pass.
As for the machine rating, to give an idea. My 1/2 structrual steel test was done at 174amps using flux core.
They show single pass only up to 3/16" on your welder for shielded gas welding. They don't show multipass shielded gas weld specs. 1/4" single pass with flux core, and up to 1/2" multi pass if you go to .045 wire.
No it is not a math equation. Here's a mind picture. Say you have 2 pieces of 3/16" plate you want to butt weld. You would bevel or Vee the edges and weld them together. Now flip the plate over and looky see how deep the weld went. With that 175 it probably went all the way through. Now take 2 pieces of 3/4" plate and do the same. The gap at the top of the Vee/Bevel you had to grind out will be pretty wide. It will take a lot of welding to fill that Vee. So, if 3/16" = 1 pass that does not mean 3/8" = 2 passes. To butt weld 3/8" I'd say at least 3 passes will be needed to get full penetration.
I understand the bevel and multi pass concept. Now, looking at the pdf, does the fact that it doesn't list multi pass for mig mean that I should not attempt that and always go flux core for multi pass requirements? or is using gas Ok as long as adequate passes are made?
Thanks for the help guys - If this has somewhat gone beyond the scope of this thread please let me know, but I guess this can help out when considering a welder as well.
Hopefully some expert with gas shield welding will chime in. I only have a 140 welder and it will only do 10 gauge gas shield. I never have tried multi pass with it. It does do multi pass with flux core very well.
You can do mulitpass with just gas but it does not have as good results as flux core.
That being said, I have done several practices with multi pass on 1/2 plate with MIG and passed bend tests. My main tests were Flux core only because that is what the steel co's want in this area.
A wider selection of rod can be run with having both, or should I say, all three polarities. D/C has a better looking weld and can do fairly thin work as well. It is hard to weld A/C on real thin metal.
scotch740 said:
Also if someone has some good charts to the differences in stick electrodes that would be cool. And maybe discuss the applications.
Good table, kinda what I was looking for. I was more wondering what the numbers stood for. Are the first few after the E the tensile strength? My teacher said the first numbers are the tensile strength, ie E6011 has a tensile strength of 60KSI? What are the last 2 numbers for? I found a good chart over the summer but can't seam to locate it any more.
stick welder uses no gas...i just picked one up a couple weeks back. i like it a lot and it welds 1/8" metal on about 80 or 85 amps and goes up to 100 amps...which should weld 1/4" (with multiple passes) or 3/16", both of which are fine for bumpers. it will be fine for thinner stuff like sheetmetal thin. just make sure you turn the amperage down or it will burn holes through it
by the way, if you've never stick welded don't expect to pick it up on your first try...you will stick the electrode to the metal many times before you learn it. when it sticks this requires you to give a little jerk to get it unstuck from the metal (it welds itself to the metal).
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
