T-case linkage falling apart - JeepForum.com
post #1 of 10 Old 07-23-2007, 07:50 AM Thread Starter
Piratejonh
Piratejonh's Avatar
Morning everyone. My T-case linkage keeps comming off at the point where the lower end of the rod fits into another bracket( in the middle of the system) There is a rubber grommet that the rod presses into. The rubber piece is getting worn out. Has anyone made a better connection point?
Jeep took another piece of my finger today...
Piratejonh is offline
post #2 of 10 Old 07-23-2007, 10:41 AM
Scotch740
Scotch740's Avatar
I am having the same problem with the grommet on the Adjusting block. I though about welding a stud on there and putting a nylon lock nut on there and keep the grommet as a bearing surface.
Jeep dealership only has one in stock . Seams like a bad design. Easy and cheap but bad . Just one more thing they should had done differently from the drawing board.
Scotch740 is offline
post #3 of 10 Old 07-23-2007, 12:58 PM
Terrain Twister
X3. I'm wondering if anyone has adapted a cable system instead of the linkage that is used.
At that point where it's too much to list!
Terrain Twister is offline
post #4 of 10 Old 07-23-2007, 01:07 PM
Scotch740
Scotch740's Avatar
A cable system would be complicated because the lever must push as well as pull. If it was done correctly it would be a lot smother I bet. Just more complicated than I wish to fathom. I will be all over one as soon as someone else comes up with a design
post #5 of 10 Old 07-23-2007, 08:36 PM
Grubbi
Grubbi's Avatar
A relocation bracket will take care of this problem, it makes the bracket seperate from the body which keeps it from binding causing the linkage to pop out.
A fellow member of my Jeep Club made his own, here's a link: http://www.jeepforum.com/forum/f46/tc-shifter-bracket-394210/
Good Luck.
'99 TJ 4.0, 3" Rusty's Lift, 1" Tera Body Lift, 33"s on Cragar Soft 8's
Warn XD9000i
Grubbi is offline
post #6 of 10 Old 07-23-2007, 09:27 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Wheelin98TJ is offline
post #7 of 10 Old 07-24-2007, 12:15 AM
Terrain Twister
That sounds like a challenge!
Was thinking of trying a Morse cable and making the appropriate brackets. WHEN I get the time and if it works, I'll post the steps and final results.
post #8 of 10 Old 07-24-2007, 06:45 AM
Wheelin98TJ
JEEP FREAK
Why mess with cables?
Why not just fab a shifter that connects directly to the linkage like the one I posted a link to above?
post #9 of 10 Old 07-24-2007, 07:09 AM
Terrain Twister
That is a good idea, but doing things different is part of the fun!
Maybe I'll do both!
post #10 of 10 Old 07-24-2007, 07:34 AM
Scotch740
Scotch740's Avatar
I wish I had just sucked it up and got that novak shifter. I probably will eventually but until money is available I will just keep hacking up my AA bracket until its right.
transfer case linkage mrminnis Tires & Wheels 1 06-10-2008 09:29 PM
Body lifts - t-case linkage Pipedrummer Tires & Wheels 7 12-18-2006 02:45 PM
Transfer case linkage? imtheant Engines & Drivetrain 0 04-25-2006 03:28 PM
need help with Transfer Case Shifter Linkage goo1134 Tires & Wheels 6 08-26-2005 07:29 AM
Is there an upgrade for the T-case shift linkage?? Seirpin General Jeep & Off-Road Equipment 2 08-14-2003 08:44 AM
