Swingout tire carrier question...........
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
The swingouts that I have seen all have a bearing/race type setup for the pivot. Is this really necessary? Wouldn't a shaft welded into the bumper work and just use a piece of pipe to slide over the shaft and weld the carrier to it? It would be easy to drill a couple holes in the pipe and put in grease zerks if one was worried about it not operating smoothly......... Tell me how you made yours if you didn't use bearing/race........
Thanks!! John
88' Wrangler, 4.2 .30 over with Weber 32/36, AX 15, sye, 4:10 gears, Ford 8.8 and Dana 30 with 4:10's out of a 2.5, 3.5" BDS springs with MORE 5/8" shackles, no trac or sway bars, 33x12.5r15's on 15x8 American Racing Baja's. |
#2 |
Well i think its one of things where a lot of ideas will work but you need to ask yourself if you want to do it right. I get what your saying but its like you said it just wont work as smooth and will probably vibrate and rattle around til it or something breaks.
im no engineer but thats my input. |
#3 | |
I have been Fabricating for 11 years, and I have built several swing out tire carriers, and they all used the bearing/race idea. I think you could do it your way but I would at the very least use a 1-1/4 or larger rod, and I would recommend using bronze bushings instead of steel on steel. If you want to Fab our own bumper but not the Bearing type hinge, there are several suppliers out there. Below is my personal Photobucket page. see toward the end I have a WJ I built for myself with a removable 1750 pound spindle hinde tire carrier. God Bless Pictures by AnthonyPadgett-weldfab - Photobucket |
#4 |
I tried that years ago and it did work, not very well but it did work. It will not fit as tightly as it needs to be in order to work. There are companies that sell the parts to build your own swing out, that is what I would do now.
#5 |
Why bother building one when you can buy one for $30 from a trailer parts store? Hell for stout and cheap. no reason to reinvent the wheel.
The build for mine is in my signature.
81 Cherokee on Tons build 2004 LJ, 4.0l, Auto, 35x12.50x15 BFG MT KM2's, 4" superlift, RE SS brake lines, 4.56 Yukons, D44/Detroit Rear, D30 Front, Custom Tire Carrier Bumper, Custom Front Bumper, Smitty Xrc10, Hi-lift extreme |
#6 |
Warn uses a bushing instead of a tapered bearing. FWIW.
Guns kill people like spoons made Rosie O'Donnell fat. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
