SWAG tailgate and tub mounted tire carrier - JeepForum.com
post #1 of 21 Old 04-03-2011, 04:54 PM Thread Starter
AstroZombie
A few days ago I installed my SWAG tailgate, the installation is pretty straightforward so I won't get into that. I needed a place to haul my tire, and got the idea from another forum member to reuse the latch that came with the kit for the tire carrier.
After a few days planning in my head I decided to go for it. I had a useless engine stand that I've been cannibalizing steel from, and I "saw" my hinges in the square tubing. Here is a photo walk through of what was done.
I will end up remaking the hinges so they're a bit beefier and I'm able to use bushings. Right now they are 1/2" grade 8, but I'd like to use bronze bushings to reduce the resistance. The whole assembly does not rattle one bit, but later I will install the rubber bumpers to the carrier to make things tighter.
The SWAG kit is awesome, and Troy is a great guy to deal with. Hopefully in the future he can produce something like this.
(Don't mind the camo... I'm working on suppressing my inner redneck!! )
Anyway, here are the pics
2004 Black Rubicon. Locker mod and a few other things...
USN Jeep Club Hull # 199
AstroZombie is offline
post #2 of 21 Old 04-03-2011, 05:06 PM
pdangerp
pdangerp's Avatar
I would be worried about the stock tire carrier (looks like you bolted it onto your tire carrier frame) being made from Pot Steel and not being able to actually carry the 35" tire without cracking. The frame looks great though. How did you handle the latch?
pdangerp is offline
post #3 of 21 Old 04-03-2011, 06:40 PM
rnorma1
Nice!!
I haven't started on mine but I do have the steel sitting in the garage!
I ended up getting 1x2 stock like you used but for the hinge shells I got 2x3 by 1/4" thick. It's way over kill for the application but the 2" wide tubing will fit in the 3" wide outer hinge and leave 1/2 inch of free play inside. Then you can use standard 1/4" thick bronze bushings on each side of the 2" wide stuff. Should make for a very solid hinge. Plus, you can pick the bushings up at any hardware store.
Yours looks great!!
As far as the stock tire hanger being weak...it is but the cool thing is that you can pick up stronger ones that are designed to bolt into the stock holes for pretty cheap. So if this one starts cracking up, you can put a new one on without having to drill new holes!!!
Great job man!
rnorma1 is offline
post #4 of 21 Old 04-03-2011, 08:25 PM Thread Starter
AstroZombie
Thanks! The tire is just a 31" factory spare. I have 33's on the Jeep now but will be going back to 31's the next set of tires I get. The carrier is pretty strong, but I'll be checking it often for cracks or distortion.
The latch was what came with the swag tailgate kit to hold the passengers side of the tailgate. Mine fit tight so I decided to reuse it for the carrier. The end of the tube is capped and I pressed a bronze bushing in that the latch slides into.
Originally Posted by rnorma1 View Post
Nice!!
Yours looks great!!
Great job man!
Exactly! I bought bushings but my scrap tubing for the hinges wasn't big enough. I'll do them over soon, this just allows me to carry a tire now. It is plenty strong, I can sit on it and it doesn't sag (180lbs) Thanks again for the kind words, I appreciate it.
post #5 of 21 Old 04-04-2011, 03:46 AM
Ironworker709
Ironworker709's Avatar
Looks good!
I wouldn't worry about the stock tire carrier bracket,they are pretty stout the way they are bent and designed..it's not the bracket that was weak on these jeeps,,it's the tailgate itself that takes a serious beating and bending with bigger tires on them.
For a little insurance you can add another 2 bolts to it on the carrier bracket..1 in between the 2 already there.
I would aslo maybe add some stiffener bracketry on the inside of the tub where the latch and hinges are so it will prevent any possible stress and bending on the tub itself.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #6 of 21 Old 04-04-2011, 11:07 AM
rlockwood
EXACTLY the design I have in mind, except planning on an aluminum frame. Did you do anything to tie the upper hinge to the roll cage? Or figure you're within weight limits having lost the tailgate weight?
rlockwood is offline
post #7 of 21 Old 04-04-2011, 01:03 PM
Hotshot
Nice work.
Hotshot is offline
post #8 of 21 Old 04-04-2011, 01:17 PM Thread Starter
AstroZombie
Thanks everyone, I appreciate the kind words. After driving to work and hitting a bunch of bumps, there are some rattles, but once I get some rubber bumpers back there all will be well. I'm also thinking of boxing in the stock tire carrier and using it as storage for my tow strap (if I can roll it to fit in such a small space)
rlockwood, Yeah I figure I'm within the limits of the tub since I lost the weight of the tailgate. Any larger of a tire and I'd add some material to the tub.
post #9 of 21 Old 04-05-2011, 08:11 PM
rnorma1
Thanks for the update about the rattles. I picked up a bunch of 1" tall rubber bumpers to put in place of the giant rubber bumpers already on the tail gate. I'll space the frame away from the body in such away that when closed, it will be pressed firmly against the bumpers. Hopefully that will keep the rattles away.
Here's the bumpers I bought.
http://cgi.ebay.com/ebaymotors/Repla...#ht_2593wt_754
rnorma1 is offline
post #10 of 21 Old 04-10-2011, 05:22 PM
bobdog
Have you thought about adding a basket over the top for a small can of gas, or other light things? It might be welded to the top rail...????
Black Jeep Society
New Mexico Jeep Club
Atheist Jeep Society
Micro-Trailer Club
bobdog is offline
post #11 of 21 Old 04-15-2011, 10:31 PM
bobdog
bump for others
Black Jeep Society
Micro-Trailer Club
bobdog is offline
post #12 of 21 Old 04-15-2011, 11:49 PM Thread Starter
AstroZombie
Thanks for the bump, I have been busy with my hot rod addiction recently and haven't been following this thread. I do want to add something that will allow some sort of storage. I made a hitch mounted rack that I use if I'm camping with the family and need to put the seat in the Jeep. But until I remake the body side hinges to accommodate the bronze bushings I'll keep it like it is.
Also, everything is still holding up well, for those of you thinking about going this route.
post #13 of 21 Old 04-23-2011, 09:55 PM
nniemczyk
I like the camo.
Originally Posted by ajf1994 View Post
You sound like a *****.
Edit: The word censored is a synonym for a cat.
nniemczyk is offline
post #14 of 21 Old 07-19-2011, 12:26 PM Thread Starter
AstroZombie
It's been awhile since I've been on this forum. I recently had back surgery and am on the mend right now. Just wanted to report that the tire carrier is still holding up well! Has anyone else gone this route? If so, please post pictures! I won't take offense to the hijack, I'm interested to see what others have come up with.
post #15 of 21 Old 07-19-2011, 07:07 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Don't have much to add about the carrier but just wanted to wish you a speedy recovery from the back surgery..
BESRK is offline
receiver mounted tire carrier - my take CJ7Pilot Fabrication Shop 28 02-04-2011 01:59 PM
Solution for a loose, hitch mounted cargo carrier NonRubicon Cheap Tricks & Fixes 7 11-22-2010 08:37 AM
Tongue mounted motorcycle carrier JustKidding09 Fabrication Shop 2 10-02-2009 12:10 PM
curt hitch mounted tire carrier aircruiser Cheap Tricks & Fixes 2 09-15-2009 02:55 PM
Tire Carrier attached to tailgate bigwill5o Fabrication Shop 13 11-06-2005 04:44 PM
