Stripped Torx Bolts... Now What? - Page 2 - JeepForum.com
post #16 of 19 Old 04-02-2013, 02:27 AM
athos76
Originally Posted by edpszczolkowski View Post
I agree with using a torch to heat up the bolts to a nice glow, then trying the bolts after they cool a bit. Also a lot of thread-lock is deactivated by heat. That's how I got the Torx bolts holding the flex plate/flywheel onto my 2.8l CRD engine off without ruining them.
I usually torch the bolt till its a dark cherry then as it cools, spray some Sili-kroil or pb blast on the threads. When it cools, it will wick the penetrant down the threads.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #17 of 19 Old 04-02-2013, 06:24 AM
edpszczolkowski
I always figured that when you spray anything onto a hot bolt like that, it would just evaporate from the high heat. Maybe I'll give it a shot next time a bolt really fights me.
edpszczolkowski is offline
post #18 of 19 Old 04-02-2013, 09:56 AM
rjbruzan
Also the heat and cool cycle will often break the bond the rust has created.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is online now
post #19 of 19 Old 04-03-2013, 04:49 AM
kjg26
kjg26's Avatar
I tried the easy out method, that was a spectacular fail. Finally ground off the liner that was on the bolts and welded a nut or bolt to the top and ran it out that way. Got them all out yesterday. Replaced with grade 8 hex in the stock location until I get the chance to fit the cage sitting in my basement.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
