storage compartment/trunk box - JeepForum.com
post #1 of 10 Old 03-05-2009, 03:55 PM Thread Starter
bluox3
has anyone made a storage box or trunk type lid behind the rear seat made of a thinner tpye wood less than 1/4 and covered it in glass resin on cloth to give it a more finished look? i hate the "wood look" type boxes... this is a jeep and not a kitchen. i have thought of bending up some steel and welding one together but at the present time i do not have access to a brake
bluox3 is offline
post #2 of 10 Old 03-06-2009, 08:03 AM
Bigbob
Bigbob's Avatar
If you have a welder you can have 16 ga steel sheared and broke into the shapes you want pretty cheap and build it that way. Mine is made of 3/4 plywood and I like it just fine. I would have used 16 ga, but the plywood was free. I think fiberglassed panel would be nice, but if anything was on top it it;d eventually break.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #3 of 10 Old 03-06-2009, 10:29 AM
muddy93
1987 FSJ Wagoneer
I also made mine out of 3/4" plywood, and sprayed with bed liner. it was cheap and easy to build, and has been holding up very well for the last 3-4 years.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #4 of 10 Old 03-08-2009, 11:34 AM Thread Starter
bluox3
does the bedliner spray make it look less like wood? or can you still tell its made of wood? not looking for kitchen cabinets lol.
bluox3 is offline
post #5 of 10 Old 03-08-2009, 11:47 AM
shu2kill
not behind the rear seat, but under it....
shu2kill is offline
post #6 of 10 Old 03-08-2009, 12:53 PM
muddy93
1987 FSJ Wagoneer
here's a link the the write up about mine,http://www.jeepforum.com/forum/f37/yj-modular-storage-system-write-up-596248/
I used rattel can bedliner, so there isn't much texture to it, which gives it a little bit of a "cabinet" look, however, if you use a liner with more textrure, I think you'll get the look you're going for.
and as I mentioned, it seems to be holding up well. I have only had to respray one spot on the top of the tonneau cover, and that was my own fault. I was moving a tiller, and had it strapped on top of the tonneau cover. when I was unloading it, one of the tines on the tiller dug into the cover.
muddy93 is offline
post #7 of 10 Old 03-11-2009, 07:39 AM Thread Starter
bluox3
any other ideas
bluox3 is offline
post #8 of 10 Old 03-19-2009, 10:59 AM Thread Starter
bluox3
i am in the process of making a rear trunk type box for behind the rear seat right now. 1/4 ply epoxyied together . then i am going to cover it with fiberglass cloth for strengh and to get rid of the "kitchen cabinet
" look. the best part if it s..cks the wood was only $5.00 at lowes.
bluox3 is offline
post #9 of 10 Old 03-19-2009, 11:05 AM
Contra
i am gonna start mine today, but with steel/metal, probably...
Ever Gone Geocaching?
Contra is offline
post #10 of 10 Old 03-19-2009, 11:24 AM Thread Starter
bluox3
thats what i wanted to do. but it was easier to cut wood at home for me right now than get metal/ bend and weld. and its cheaper to mess up.
bluox3 is offline
Here's a good option for trunk / storage / cab lighting - battery powered LED kpauley Audio, CB & Ham Radios, GPS, & Electrical 2 10-23-2009 08:49 PM
Another storage/trunk question. mike481 Fabrication Shop 1 01-29-2008 01:04 PM
Need some advice on speakers for trunk compartment.. jesse977 Audio, CB & Ham Radios, GPS, & Electrical 7 03-23-2006 03:08 AM
secret compartment chrisvr6 Audio, CB & Ham Radios, GPS, & Electrical 8 09-06-2005 03:54 PM
Installing Sub in Armrest storage compartment...... _RT_ Audio, CB & Ham Radios, GPS, & Electrical 6 07-26-2003 11:07 PM
