Steering and stretch witha 1 ton swap - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Steering and stretch witha 1 ton swap
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-24-2014, 08:34 AM   #1
Showjyr
Showjyr's Avatar
I'd like to get some options in regards to the axle swap I'm doing this winter...it's an 06 TJ
I'm swapping in a Dana 60 (GM kingpin) and I'd like to stretch the front as much as I can without moving the steering box.
Planning on H1 wheels and a high steer. I'll be going PSC assist eventually as well.
What steering arms will work with the H1 wheels in stock form? Can I realistically do a behind the axle tie rod?
How far can I move the front axle forward? I'm going with ORI struts so spring buckets are a non issue.
What's the best trac bar frame side mount to use?
Thanks in advance!
Showjyr is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 11:13 AM   #2
jason m
Nothing but the facts
jason m's Avatar
Thanks in advance!
H1 rims on SRW hubs without a small spacer means you have to get high steer arms that are angled in and chopping off your OEM steering arms as they will rub or hit and bind.
You can run them behind but again they need to be angled arms, but watch out behind axle steering and a linked axle it gets busy back there.
Any plans on hydro assist or full hydro? Now is the time to plan for the stretch and full hydro, you can always swap in a Astro van box for forward steering as a temp ( year or so ) till you go full hydro later on.
Can't wait to see this done, I got some rocks that need testing done to them lol.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt....
jason m is offline   Reply With Quote Quick reply to this message
Unread 11-29-2014, 03:48 PM   #3
Showjyr
Showjyr's Avatar
Who makes angled arms? And ya that's what I was concerned about if I went behind the axle.
I plan on hydro assist but I don't ever plan on full hydro...as much as I would like to. It will never be a trailer queen and full hydro would mean no street driving.
Unread 12-08-2014, 08:57 AM   #4
mattamd_xp
http://www.fourwheelsupply.net/colle...ears-h1-wheels
99 Wrangler Project Detroit Mongrel 5.3/4l60e/Atlas HPD60/14B coilovers etc...
mattamd_xp is offline   Reply With Quote Quick reply to this message
