Steel thickness ? for custom skid plate - JeepForum.com
post #1 of 14 Old 02-02-2010, 02:26 PM Thread Starter
motiv8ya
1979 CJ7
I'm looking to make a flat skid plate / crossmember for my current CJ7 build and I need advice on what kind of steel to use (tubing round or square, wall thickness etc). I am brand new to welding and have only built a stand for my blasting cabinet and a welding cart so far (I used 1 inch square tubing 1/8 inch wall for both and I still have over 40 feet of it laying around). If you've built your own what materials did you use and what's too light weight for this application, thanks.
motiv8ya is online now
post #2 of 14 Old 02-02-2010, 03:45 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
For my CJ5, I used 1.75"x.120" wall DOM for the framework and skinned it with 3/16" thick mild steel plate.
BESRK is offline
post #3 of 14 Old 02-02-2010, 03:58 PM Thread Starter
motiv8ya
1979 CJ7
Thanks BESRK. Would the 1 inch square x 1/8 wall steel that I have be strong enough or should I stay away from using it?
post #4 of 14 Old 02-02-2010, 06:48 PM
quiksilverj
its hard to say what kinds of loads that the mount would experience due to torque and weight but that seems pretty small to use there to me.
quiksilverj is offline
post #5 of 14 Old 02-02-2010, 07:01 PM
Roadymi
1982 CJ7
that depends a lot on how hard ur gonna hit what ur gonna hit
Roadymi is offline
post #6 of 14 Old 02-02-2010, 07:36 PM
wushaw
Rockin jeep
wushaw's Avatar
What Besrk used is a little bigger in diameter but 1/8" is .120 for the thickness.
I would use it, it is pretty strong stuff, the worse that can happen is you bend it, well you hit anything on the Jeep hard enough and your gonna bend something.
I have built several things out of that 1" square tube, it is great for lots of projects.
wushaw is offline
post #7 of 14 Old 02-03-2010, 05:28 PM Thread Starter
motiv8ya
1979 CJ7
Thanks for all the input guys!
post #8 of 14 Old 02-03-2010, 05:33 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Honestly, 1" square is a bit too small for my taste. If I were going to make skidplate framework out of square tubing, it would probably be 2" square. I don't think 1" square tube would hold up well to hard hits.. too easy to bend. Tubing diameter is what resists bending.. tubing wall thickness is what resists dents.
BESRK is offline
post #9 of 14 Old 02-03-2010, 06:21 PM Thread Starter
motiv8ya
1979 CJ7
Thanks BESRK, that is just the info I was looking for. 2 inch square tube it is..
post #10 of 14 Old 04-30-2010, 11:07 PM Thread Starter
motiv8ya
1979 CJ7
I took a shot at making one out of the 1 inch square .120 wall and I didn't feel comfortable with it when I set the drivetrain down on it.
I bumped up to 1 1/2 inch square .188 wall and I'm in the process of making another crossmember. I don't have access to a tubing bender so I have to stick with the square tubing. The 1 x 2 .120 wall looked too small and the 2 x 3 .120 was too big of an outside diameter. I'll post a pic when I'm done with it.
post #11 of 14 Old 06-13-2010, 05:26 PM Thread Starter
motiv8ya
1979 CJ7
Here's what I wound up with....
Unfortunately I decided against using the transmission combo that I built it for so it will go unused.
post #12 of 14 Old 06-18-2010, 12:01 PM
CoryA
Nice what size tube did you end up using?
couldn't you just grind off the beads thats holding that plate on?
CoryA is offline
post #13 of 14 Old 06-18-2010, 05:41 PM Thread Starter
motiv8ya
1979 CJ7
It's 1.5 x 1.5 sq. .180 wall, I'm working on version#2 to accomodate a t176/Dana 300 now
post #14 of 14 Old 07-22-2010, 04:39 PM Thread Starter
motiv8ya
1979 CJ7
Here's version #2, it bolted right up, nice and easy.
Law Restrictions on bumper steel thickness? mickmeister Fabrication Shop 21 10-21-2009 01:00 AM
Steel thickness?? melius Fabrication Shop 1 04-05-2009 10:10 AM
Need some help with sliders (steel thickness, price, etc.) ksander Fabrication Shop 4 04-01-2009 04:09 PM
What thickness of steel? LOCAL Fabrication Shop 5 11-19-2008 12:58 AM
Steel thickness melius Fabrication Shop 5 10-28-2008 01:10 PM
