spool gun help - JeepForum.com
post #1 of 8 Old 02-09-2011, 03:08 PM Thread Starter
Machinist
spool gun help
does anyone have a spool gun on either a millermatic 180 or a similar size machine.i want to know about how well it works for that size machine and what thickness material you weld with it?Thanks,i have a project that I will be welding 1/8 -1/4 inch thick stuff and need to know if my MM180 is up to the task
Machinist is offline
post #2 of 8 Old 02-09-2011, 09:19 PM
wushaw
Rockin jeep
wushaw's Avatar
wushaw is offline
post #3 of 8 Old 02-10-2011, 12:16 PM Thread Starter
Machinist
That really doesnt tell me what I need to know.Like I said I need to know if I will be able to do 1/4 material or not with it.
post #4 of 8 Old 02-10-2011, 02:09 PM
skullver
Tarpitz
1991 XJ Cherokee
Talk to your local welding supply shop? First thing I would do personally.
Blah blah blah blah.
my Jeepspeed build thread:
skullver is offline
post #5 of 8 Old 02-10-2011, 02:43 PM
dcope17
Under the specs tab on your model welder says 1/4 alum. with spool gun...
http://www.millerwelds.com/products/...p?model=M00209
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #6 of 8 Old 02-10-2011, 03:12 PM Thread Starter
Machinist
Thanks dscope thats what I was looking for.I already talked to the and he said it MIGHT do 1/8 and I thought he didnt know what he was talking about now I know.i guess i will be getting a spoolgun then!
post #7 of 8 Old 02-10-2011, 11:14 PM
wushaw
Rockin jeep
wushaw's Avatar
That really doesn't tell me what I need to know.Like I said I need to know if I will be able to do 1/4 material or not with it.
I guess you don't know that your MM180 is rated at the same amp & duty cycle as that spool gun.
If your welder won't do it then the spool gun won't either.
To say "yes" this spool gun will weld 1/4" material then yes it will.
Here's Millers picture to show the thickness of material both units will weld.
wushaw is offline
post #8 of 8 Old 02-11-2011, 05:27 AM Thread Starter
Machinist
I didn't know if a spool gun made a difference in what thickness material I could weld or not.I will never weld aluminum thicker than 1/4 so I am golden!
Spool or no spool? That is the question... XJTino Engines & Drivetrain 4 03-14-2010 05:57 AM
spool in 8.8 red87yj Engines & Drivetrain 7 05-02-2008 05:31 PM
Spool??? PacNW_87 Engines & Drivetrain 20 03-30-2007 05:53 AM
What is the difference between a mini spool, spool, and a detroit locker alex71 General Jeep & Off-Road Equipment 5 10-25-2006 11:44 PM
to spool or mini spool. that is the question. NOTQUITEMUSASHI Engines & Drivetrain 4 10-02-2006 09:15 PM
