Spare tire mount, will this work? - JeepForum.com
post #1 of 16 Old 06-25-2010, 08:27 PM Thread Starter
jdub36
i put a new set of rims on my jeep today and when i got around to the spare tire mount the studs coming off of the rear plate were not long enough (apparently the offset on the new rims is different) So i thought the easy fix was to knock out the wheel studs and just replace them with longer ones but i could not find a length that would work. Can i just use a grade 8 bolt and tack weld the back of it then use a flat washer and lock washer on the wheel side to tighten it down? I could get a bolt that would match my 4 way lug wrench so i could get it off in a pinch, but will that be strong enough and will it stay tight without backing off? By the way my tires are 35x12.50 if that makes a difference.
thanks,
jw
jdub36 is offline
post #2 of 16 Old 06-25-2010, 10:08 PM
timatoe
timatoe's Avatar
I used three grade 8 1/2x20 bolts on my carrier, pushed them through the holes and welded the head on the plate. It uses regular lug nuts to hold the tire on.
timatoe is offline
post #3 of 16 Old 06-25-2010, 10:25 PM Thread Starter
jdub36
that is exactly what i was thinking. How hard is it to find 1/2 x 20 bolts or is that something i can find at any hardware store?
Thanks,
JW
jdub36 is offline
post #4 of 16 Old 06-25-2010, 11:03 PM
timatoe
timatoe's Avatar
Should be able to find them at about any hardware store.
timatoe is offline
post #5 of 16 Old 06-26-2010, 07:41 AM
Area.3.Fiftyone
1/2-20 is not going to be so easy. Most hardware stores only carry them in 1/2-13.
Go to Fastenal or a specialty nut and bolt place if you can't find them at the local hardware store.
Grade 5 is more than enough as far as sheer strength is concerned.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #6 of 16 Old 06-26-2010, 08:14 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Fastenal is a very good place to look. I can also find 1/2" X 20 at my local ace hardware of all places.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #7 of 16 Old 06-26-2010, 03:11 PM
prd_cdn
prd_cdn's Avatar
:edited
prd_cdn is offline
post #8 of 16 Old 06-26-2010, 03:36 PM
TSEJEEPERS
Ace Hardware around here has a great selection of fine threaded bolts.
I just got done making a spare tire carrier for my trailer.
Took the lug nut in and matched it to the bolt. If I remember right they went all the way up to 4 or 5".
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 16 Old 06-26-2010, 05:00 PM
rustywrangler
Originally Posted by prd_cdn View Post
Are you serious??? Your using 20" long bolts???
You mean 1/2 x 2"(for example) - 20 pitch?? Which is a fine thread (UNF)
1/2 x 2"(for example) - 13 pitch is a course thread. (UNC)
heck even princess auto here has fine and coarse thread bolts.
best bet, is you have one, take it to the counter and get them to match it for you if you dont know what it is.
Wheel lug bolts for just about every jeep, XJ, YJ, WJ, ZJ, are going to be 1/2" X 20 pitch with varying lengths.
post #10 of 16 Old 06-26-2010, 05:08 PM
HELMET
Is this on the stock carrier on the tail gate? Or is this an after market carrier? The tail gate will not hold a 35x12.5 tire and wheel.
HELMET is offline
post #11 of 16 Old 06-26-2010, 08:20 PM
Area.3.Fiftyone
Oh no? Then how did I get my 35x12.50R15 BFGoodrich KM2 to bolt on to my tailgate with factory hardware just fine?
I wouldn't recommend heavy wheeling with it like that, but it WILL fit.
post #12 of 16 Old 07-20-2010, 10:49 PM Thread Starter
jdub36
This is not on my tailgate. I ran a 32x11.50 on the tailgate for awhile and that did not work out for me so i would not even try a 35. I got some bolts and got them tacked on there and so far it seems to be working out just fine.
jw
jdub36 is offline
post #13 of 16 Old 07-21-2010, 10:29 PM
HELMET
I did not say it wouldn't fit, I said that it would not hold it. I guess I should have said that it will fit but rip off your tail gate eventually.
HELMET is offline
post #14 of 16 Old 07-22-2010, 11:04 PM
NEVADAGARY
Lowes has 1/2-20 grade 8 bolts. That's where I bought the ones for my tire carrier.
Gary D.
Old but having fun
Real Americans drive Real American!
NEVADAGARY is offline
post #15 of 16 Old 07-23-2010, 09:47 PM
JWMII
1978 CJ7
Grade 8 bolts in that application are over kill. Save a buck or 2 and go with grade 5.
JWMII is offline
spare tire mount venturaf Tires & Wheels 10 04-20-2010 12:08 AM
Spare tire mount help jmc543 General Jeep & Off-Road Equipment 2 03-30-2010 08:52 PM
max tire size for a stock spare tire mount?? G-MANtj Tires & Wheels 11 05-13-2009 06:40 PM
Spare tire mount? GPEWETT General Jeep & Off-Road Equipment 1 07-09-2008 01:09 PM
Spare Tire Mount Dizzle Fabrication Shop 2 12-19-2007 11:21 AM
