Something to be aware of when welding. - JeepForum.com
post #1 of 29 Old 04-13-2010, 06:00 PM Thread Starter
meadz
Found this thought it would be a good lesson without learning the hard way.
Chemical reactions with heat can be deadly
Please read artical
Brake Cleaner = Phosgene Article
meadz is offline
post #2 of 29 Old 04-13-2010, 06:05 PM
jgorm
jgorm's Avatar
It was posted once, but its always good for more people to know. I would have probably titled it Welding over Brake Cleaner cleaned parts will KILL YOU! (cleaner cleaned, does that make sense. haha)
jgorm is offline
post #3 of 29 Old 09-13-2010, 02:57 PM
MustangJAB02
I never knew that, I am very glad I came accross this! Thanks
1995 Jeep Grand Cherokee Laredo
4.0L 201k+ miles (no rebuild yet)
Everything original except the normal replacing of mufflers, tires, spark plugs, but all done with stock replacement.
MustangJAB02 is offline
post #4 of 29 Old 09-13-2010, 03:30 PM
Chili4me
1979 CJ7
Me too!!!
Never heard of it. That is scary as hell that such a small amount will screw you up that bad.
Chili4me is offline
post #5 of 29 Old 09-14-2010, 01:56 AM
91YJRockCrawler
shouldnt this be a sticky?
The P.O.S: 91 wrangler locked on 33s
Daily Driver/tow rig: 01 F150
its mind over matter.. I donít mind and the sheet metal donít matter
Originally Posted by JeepnBlake View Post
It's JF's very own little slice of Pirate :rofl:
91YJRockCrawler is offline
post #6 of 29 Old 09-14-2010, 03:34 AM
ImpactFabWorks
good to know. Just kind of crazy since I have been watching people burn and spray brake cleaner on hot metal for years. Maybe it's just certain brands that use that chemical? I personally use acetone because it all evaporates so fast
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #7 of 29 Old 09-14-2010, 05:55 AM
Netpackrat
Phosgene gas is nasty stuff; the Germans used it during the Great War to kill people.
It isn't the heat that turns brake cleaner into it. The CFCs in brake cleaner will decompose into phosgene in the presence of arc rays from welding. Been there, done that, made the ER visit. Luckily, didn't get enough to do any lasting harm, and from what I read at the time, the experience of the guy in the article is abnormal, because it is one of those things that if you survive at all, you generally make a full recovery. It's possible he already had problems he didn't know about yet, or that he was exposed to more than just the phosgene.
The scary thing is the way phosgene kills you; once you have evacuated the area where you were exposed, your breathing goes back to normal. Then, if you got a bad dose, somewhere between something like 12 and 72 hours, your lungs fill with fluid and you die from drowning. About all they can do is try to make you comfortable. It made for an uneasy few days after I was exposed.
There are other ways you can get exposed as well. It sometimes happens to welders in autobody shops, making sheet metal repairs to vehicles with leaking A/C systems. Same deal, CFCs being exposed to arc rays. It also happens in structure fires, because there are some foams that will emit phosgene when burned.
Be careful. I don't use anything more aggressive than rubbing alcohol as a wipe down prior to welding anymore. Waiting until you think all of the brake cleaner has evaporated, or even spraying it down outdoors isn't enough (I did both). It only takes a miniscule amount.
Netpackrat is offline
post #8 of 29 Old 09-14-2010, 07:42 AM
Warlord2
DAMMNN that is scary! I use brake cleaner on just about everything I weld to get the grease off. I will start using carb cleaner now if I have to weld something. That brake cleaner evaporates really fast, I cant see how he managed to get so much, that it stayed a liquid. That is curtainly something I will start watching out for. Thanks for posting!
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #9 of 29 Old 09-14-2010, 08:34 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
If you blow it off with air first, it won't be a problem. But it's safer to just not use brake cleaner. Use carb cleaner, instead.
It IS the heat that turns brake cleaner into Phosgene, a.k.a. Mustard Gas, not the UV arc itself. I guess you could make a case for the arc doing in, since the arc is HOT, but it's not the light itself...it's the heat.
Spray brake cleaner down a running engine and you'll get phosgene that way, too.....I got a couple days of breathing difficulty from some idiot doing that inside a shop years ago.
Pacfanweb is offline
post #10 of 29 Old 09-14-2010, 09:08 AM
BigBass
I've done that countless times, really dodged a bullet on that one. That is some really scary Sh*t. Is there any advantage to brake cleaner over carb cleaner?
All Long Islanders Check out OutLawedOffroad.com throw my user name BigBass in the referral box
BigBass is offline
post #11 of 29 Old 09-14-2010, 02:04 PM
Netpackrat
Double checked, and apparently it is both:
CHLORINATED HYDROCARBON SOLVENTS
Various chlorinated hydrocarbons are used in degreasing or other cleaning operations. The vapors of these solvents are a concern in welding and cutting because the heat and ultraviolet radiation from the arc will decompose the vapors and form highly toxic and irritating phosgene gas. (See Phosgene.)
PHOSGENE
Phosgene is formed by decomposition of chlorinated hydrocarbon solvents by ultraviolet radiation. It reacts with moisture in the lungs to produce hydrogen chloride, which in turn destroys lung tissue. For this reason, any use of chlorinated solvents should be well away from welding operations or any operation in which ultraviolet radiation or intense heat is generated.
From OSHA:
Welding Health Hazards
post #12 of 29 Old 09-14-2010, 06:58 PM
monkers
2010 JK Wrangler
thanks for posting this, good idea to make it a sticky.......I heard a couple years ago something about this but didnt get the full story...........so Ive been using rubbing alcohol before i weld, used to use lacquer thinner also..... Do they make a certain cleaner to remove grease oil etc.....that is safe???
monkers is offline
post #13 of 29 Old 09-14-2010, 09:35 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Nothing wrong with carb cleaner. It works about the same as brake cleaner...evaporates quickly, but doesn't turn into a chemical weapon when you burn it.
post #14 of 29 Old 09-22-2010, 10:29 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Great now I am gonna have to show 9 forms of ID when I buy some brake cleaner because Al *****da might use it for nefarious purposes.
Don't forget about welding on the Zinc/Cadmium coated parts as well, that crap is really nasty as well. AFSCME - Welding
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #15 of 29 Old 09-22-2010, 11:25 PM
Netpackrat
Cad fumes are scary dangerous, but zinc isn't so bad. You don't want to breathe zinc fumes, and should take pains to avoid it, but while it will make you sick, your body is able to get rid of it without doing any permanent damage. This is why virtually all hardware store hardware these days is zinc plated instead of cad.
Something to be aware of, is aircraft hardware is still almost exclusively cad plated, and a lot of aircraft bolts resemble grade 8 bolts, and some have similar markings (the gold color of each is from the conversion coating process, not the plating itself). So, unless you are absolutely certain that what you have is grade 8 (like didn't come out of a bucket of unknown bolts), it is best not to weld on it at all no matter how careful you are to remove the plating first.
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-12-2011 12:48 AM
MIG welding. charlescho Fabrication Shop 18 08-01-2007 01:58 PM
Welding - Day 2 Dogman Fabrication Shop 31 06-28-2007 04:32 PM
welding jimaug87 Fabrication Shop 16 12-02-2006 07:55 PM
Welding - full penetration vs. welding both sides Matt in TN Fabrication Shop 11 01-21-2006 08:03 PM
