Soft Top in Winter - JeepForum.com
post #1 of 15 Old 10-15-2013, 09:23 PM Thread Starter
steamer44
Just curious if anyone had any tips about using the soft top in winter. I don't have a hard top and can't afford one. Any tips would be great. Thanks
steamer44 is offline
post #2 of 15 Old 10-15-2013, 10:08 PM
Holder350
1995 XJ Cherokee
Buy a good coat
Sent from my phone where correct grammar is difficult.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 15 Old 10-15-2013, 10:39 PM
rchase559
I've used both. A hard top for a few years and a soft top after that. I honestly didn't notice much if any difference in the heating ability going from the hard to the soft top.
The major downside is that you cannot scrape the soft top windows as they get brittle in the cold. Just let the interior warm up and the ice will melt away. Make sure you clean and lubricator the zippers in the spring as they will get some corrosion if there's salt in the roads.
Be sure to clean it off often to prevent excess weight. I usually cleaned mine everyday it snowed, sometimes multiple times a day depending on how much snow we were getting.
rchase559 is offline
post #4 of 15 Old 10-16-2013, 07:25 AM Thread Starter
steamer44
I have heard that about the zippers and keeping them lubricated and it'll make a lot of difference.
I appreciate the info.
Cheers
post #5 of 15 Old 10-16-2013, 08:15 AM
thantos858
1974 CJ5
Jeeps have tops? Like said keep the snow off it and lube the zippers. I would lube them before we really move into the cold season.
thantos858 is offline
post #6 of 15 Old 10-16-2013, 09:31 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
When temp is below freezing, avoid trying to zip the windows down. I've actually cracked plastic windows in the cold.
BESRK is offline
post #7 of 15 Old 10-16-2013, 12:17 PM
dodger889
Park your Jeep under cover. Some have used some pvc pipe to keep the top from sagging from snow and melting snow that changes to ice puddles. You could add a layer of plastic to help with the heating across the top.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #8 of 15 Old 10-16-2013, 12:21 PM
FLATFENDER54
FLATFENDER54's Avatar
Where are you at? My heater works fine in oklahoma. We get down in the teens and twentys here sometimes.
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #9 of 15 Old 10-16-2013, 12:56 PM
Holder350
1995 XJ Cherokee
With a CJ7 I found in winter a hard top is a requirement. Haha.
post #10 of 15 Old 10-16-2013, 05:16 PM
rchase559
Originally Posted by Holder350
With a CJ7 I found in winter a hard top is a requirement. Haha. Sent from my phone where correct grammar is difficult.
This is a good point. I have a TJ and it's fine. I can't speak for the effectiveness of other models.
post #11 of 15 Old 10-16-2013, 09:51 PM Thread Starter
steamer44
I'm in SW Ontario. It gets cold. I'm sure I'll be fine just have to stay on top of it if it snows.
post #12 of 15 Old 10-22-2013, 08:34 PM
gojeepgo
1981 CJ7
I got rid of my CJ hard top a long time ago and just use a soft top and soft doors year round. To keep the heat up front I installed one of those dividers you would use to make like a half cab with a bikini top in the summer. I cant remember the name of the thing. It basically makes it like a two seater and installs behind the front seats from the roll bar to the floor. Works great. Heat stays up front.
And dont try and open or fold the windows when its cold.
gojeepgo is offline
post #13 of 15 Old 10-23-2013, 04:57 PM Thread Starter
steamer44
Just curious as to what part of the country you live in. I'm in SW Ontario and we can get some cold weather.
post #14 of 15 Old 10-26-2013, 10:56 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
I use this stuff as a liner http://www.lowes.com/pd_13358-56291-...3D1&facetInfo=
It makes a huge difference in how cold the jeep gets when you are driving. I would take a some pics, but I don't have any from last year and the cat destroyed it in the shed, using it as a scratching post.
I used the industrial adhesive backed velcro strips to secure it to the soft top where the soft top frame doesn't.
Cut out for the windows.
http://www.reflectixinc.com/images/u...pps%200910.pdf
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #15 of 15 Old 10-26-2013, 11:35 AM
Itstime
I live in ND and I think I am going to put the hardtop on. :/ I was going to leave the soft top on but I like me rear heated Window. It gets like -40 here -60 with windchill.
Itstime is offline
