sliders with no bender - JeepForum.com
post #1 of 27 Old 04-04-2012, 09:06 PM Thread Starter
jasonswelding
I got done early today and went by a steel supply that was on the way home. I was going to buy some 2x3x3/16 tube, weld in 90's and 45's. They would only sell the tube in a full 20' stick, so I left with nothing.
I came home and decided to make it work with what I had. The longer pipe is 1 3/4", the "step" part is 1 1/2", the plate is 3/16".
jasonswelding is offline
post #2 of 27 Old 04-04-2012, 10:13 PM
Treton
Very nice job! I really like what you did with the half piece of tube and the plate
Treton is offline
post #3 of 27 Old 04-05-2012, 04:46 AM
Ironworker709
Ironworker709's Avatar
Awesome Job!
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #4 of 27 Old 04-05-2012, 09:53 AM
squire_wj
That looks really good. I like that design better then the pipe being bent to meet the plate
squire_wj is offline
post #5 of 27 Old 04-05-2012, 01:29 PM
cutngut
Very kool! very different!
cutngut is offline
post #6 of 27 Old 04-05-2012, 03:33 PM
ZJFABN
Looks slick!
I'm assuming your planning to mount them flat with looking at the angle that you cut the ends of the long tube. I would suggest angling them up as close to the body that you feel comfortable with. If doing this, make sure the doors will open. Also, leave a gap in case they bend up a little over time
My work, http://www.virtualjeepclub.com/showthread.php?70963-JW-Fabrication&highlight=Jwfabrication
ZJFABN is offline
post #7 of 27 Old 04-05-2012, 06:01 PM Thread Starter
jasonswelding
Thanks for the compliments. I'm glad y'all like it because it is pretty time consuming.
I was planning on mounting them flat. I can't anlge up much because of the fender flare thing that is mounted behind the actual fender flare, but I'm always open to suggestions.
post #8 of 27 Old 04-05-2012, 06:12 PM
Treton
remove that flare thing
Treton is offline
post #9 of 27 Old 04-05-2012, 06:57 PM
AKGeo
x2. The only reason not to is aesthetics with the bolt holes and the weird hole with plastic covering it from the backside.
AKGeo is offline
post #10 of 27 Old 04-08-2012, 06:53 PM
RedlegWJ
That's great! I thought I was gonna open this and see something ghetto....
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #11 of 27 Old 04-16-2012, 06:33 AM
Skerr
Did you mount these up yet? I'd like to see how you did it.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #12 of 27 Old 04-16-2012, 09:49 PM Thread Starter
jasonswelding
Been out of town. Last week in TX panhandle. This week I'm in New Mexico. Unfortunately it still looks just like those pictures.
post #13 of 27 Old 05-05-2012, 11:04 PM Thread Starter
jasonswelding
Got some time this weekend. I'm still going to make a few changes. I think I'll make some cuts in the angle to lighten it up and put a gusset under the square tubing where it ties to the angle.
Theres a floor jack under the pipe. It lifted the front tire off the ground without much flexing.
post #14 of 27 Old 06-03-2012, 03:59 PM Thread Starter
jasonswelding
Okay, finally done. Work has been really busy both close to home and going out of state, so it's taken awhile.
I used 3x5x1/4 angle, and sandwiched it between the frame and the skid plate that holds the transfer case. The 5" leg of the angle had to be cut down a little. I mounted the pipe to the angle with 1 1/2" square tubing turned 45* for added strength. I welded a small gusset on the underside of the tube. Finished it with rattle can bedliner.
post #15 of 27 Old 06-04-2012, 01:10 PM
04WJny
1987 YJ Wrangler
Those look great! Good job
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
Tubing Bender ("Spring Bender") 19OlllllllO41 Cheap Tricks & Fixes 4 07-29-2011 08:28 PM
Bender jeepsta Fabrication Shop 2 02-22-2010 09:33 PM
has anyone ever used this bender? 157061 Fabrication Shop 1 05-12-2008 12:17 AM
Bender?????? Stan99 Fabrication Shop 39 03-03-2008 11:33 AM
Where Can I Buy A Bender? bigsteve3184 General Jeep & Off-Road Equipment 16 02-16-2003 05:09 PM
