Six two component epoxies tested and results - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Six two component epoxies tested and results
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS HD TJ Replacement HingesPoison Spyder JK LED Taillight & Wiring Harness Kits
Unread 07-05-2015, 06:37 PM   #1
Splinter
1980 CJ5
I don't know if this is the place to post this, but I thought that it was worth posting somewhere.
I watched a presentation on testing the strength of 6 popular two part epoxies. This machine shop bought 6 brands of epoxy. Then they sand blasted a steel piece of rectangular bar as well as 12 - 3/8 x 6 inch bolts. They used the epoxies to glue the bolt heads to the bar. Two bolts per brand of epoxy. After 24 hours they clamped the bar so that the bolts extended horizontally. They started with a 15 lb. weight and hung it on the end of the bolts. Gorilla epoxy failed at the 15 lbs. As they increased weight the others failed as well. The last on holding was the Locktite Metal. It held 27 lbs. for one minute. Here is how they rated
1/ Locktite metal (Best)
2/ Quicksteel
3/Devcon Fast Metal
4/ Locktite Instant
5/ JB Weld
6/ Gorilla (Worst)
Thought this might interest some of you. It sure did me.
Splinter is offline   Reply With Quote Quick reply to this message
Unread 07-11-2015, 04:21 PM   #2
rjbruzan
Thanks Splinter
Very intresting but I wish they would have included 3M autobody adhesive. These epoxies are terrific.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline   Reply With Quote Quick reply to this message
