Side To Side Overhead Console As Part Of The Cage - JeepForum.com
post #1 of 4 Old 11-12-2008, 01:52 AM Thread Starter
ex m38a1er
I think the tittle says it all.I'm keeping my tj for a couple of years more(before i go for a 4dr jk-family-).So i have to make something(you know).
My question is what size of rect tube equals the round one for the cage.
My idea is to use rect for the side to side upper and tubular for the rest.
The side to side overhead console will be drilled easily on the rect.
Thanks in advance....
ex m38a1er is offline
post #2 of 4 Old 11-12-2008, 06:51 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i'm confused...
you want to make an overhead console - ok got that.
which way? front to rear or left to right?
Are you wanting to make something like the tuffy overhead console?
The factory tubing of the windshield bars is almost 1.75" (IIRC - 1.6825" - 42-43.5mm) the factory B-pillar is 2.25" IIRC..
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 4 Old 11-13-2008, 02:18 AM Thread Starter
ex m38a1er
Sorry for the delay but i'm on the other side of the planet.(day-night).
I'd like to built a cage using the factory bars as a base.A tube will connect the windshield bar(close to the windshield) with the floor(each side)and then to the chassis.A rect tube will connect the two windshield bars(left to right,right in front of the sunvisors).What size this rect tube should be(being part of the cage)?
Then i'll make a tuffy kind overhead console(right to left) to bolt on to the rect tube.
post #4 of 4 Old 11-13-2008, 02:30 AM Thread Starter
ex m38a1er
In other words if i use 1,75x.120"DOM, as you did ,what size the rect should be ,in order to get equal strength?
Side Marker Part # !!!! 338WinMag Audio, CB & Ham Radios, GPS, & Electrical 4 12-29-2009 01:14 PM
Driver side headlight and side marker out dk02wrangler Audio, CB & Ham Radios, GPS, & Electrical 1 01-18-2009 12:51 PM
Can I rotate radials side to side??? GIJOE Tires & Wheels 1 04-29-2007 02:07 PM
tuffy overhead with side mounted cb mic? jneal Audio, CB & Ham Radios, GPS, & Electrical 8 09-14-2006 03:41 AM
Overhead console and full cage.... biffstephens Audio, CB & Ham Radios, GPS, & Electrical 1 12-24-2004 08:58 PM
