Shrinking Metal - JeepForum.com
post #1 of 19 Old 09-20-2010, 09:46 PM Thread Starter
Bigbob
Bigbob's Avatar
Shrinking Metal
I am building a trailer and I used 18 ga cold roll on the tailgate. I have it all tacked in and don't need anymore welding done to it. I have some warpage. Not bad, but I want to straighten it as much as I can. So, to lower the high spots can I heat it and quench it with a wet rag to shrink it? Any advice would be appreciated.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #2 of 19 Old 09-20-2010, 09:48 PM
g4x4xgeoff
go out and grab some "auto body shapers and hammers"
using them together will shrink, and some expand steel where necessary.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #3 of 19 Old 09-20-2010, 10:10 PM
dodger889
Unless you have a rosebud tip on a gas torch you would be fight a losing battle. Heating the high part of the bubble or wrapped part. Then quick cool the the back side will draw it some not alot but some would come out. This is why you tack and move (couple of inches), tack and move untill you get all the way around till you have it welded in.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #4 of 19 Old 09-20-2010, 10:40 PM Thread Starter
Bigbob
Bigbob's Avatar
No continuous welds. It's all tacked in about every 2-3 inches or so. Around the perimeter it's welded continuously, but I tacked it all first then just kept tacking around till it was complete. It's in the center between the supports I have an issue.
I'll try a mapp torch and wet rag before I do the rosebud. This is slight warpage and I think the rosebud is gonna put down too much heat on that 18 ga.
6 Speed, Hardtop
Bigbob is offline
post #5 of 19 Old 09-21-2010, 12:39 AM
Netpackrat
Getting oil can out of the middle of a flat panel is tough. I've seen it done with a power hammer, but those aren't exactly common, and quite expensive. Might almost be easier to turn your oil can into an actual dent, and shrink it down using a wide headed body hammer, and a big shot bag. I think you will find the results from using ANY torch and quench method less than satisfactory.
Netpackrat is offline
post #6 of 19 Old 09-21-2010, 06:58 AM Thread Starter
Bigbob
Bigbob's Avatar
Oil can?
6 Speed, Hardtop
Bigbob is offline
post #7 of 19 Old 09-21-2010, 11:09 AM
TJ06WRANGLER
There are some outfits that make a shrinking disc. Can't remember the names off the top. It goes on your disc grinder and apparently works very well.
TJ06WRANGLER is offline
post #8 of 19 Old 09-21-2010, 11:35 AM
jpony645
There is also a "shrinking" hammer. Basically just like the other body hammers but with a waffle face. Use it along with a dolly to pull the metal in and flatten it out.
jpony645 is offline
post #9 of 19 Old 09-21-2010, 12:09 PM Thread Starter
Bigbob
Bigbob's Avatar
Originally Posted by TJ06WRANGLER View Post
There are some outfits that make a shrinking disc. Can't remember the names of the top. It goes on your disc grinder and apparently works very well.
I've seen those. I've never used one. I've done the heat and quench deal before but never on something this minor. I may try to see if I can find a disc.
6 Speed, Hardtop
Bigbob is offline
post #10 of 19 Old 09-21-2010, 12:12 PM
BigBass
depending on what kind of torch you have you might not need to buy a rose bud, though there good to have, a #3 or 4 cutting tip will put plenty of heat in there turn that 18g in to puddle. The shrinking hammers might be your best bet though.
All Long Islanders Check out OutLawedOffroad.com throw my user name BigBass in the referral box
BigBass is offline
post #11 of 19 Old 09-21-2010, 02:08 PM Thread Starter
Bigbob
Bigbob's Avatar
LOL. It is 18 gauge. It don't take much heat to get it to stretch or shrink. I sure ain't looking for any "Cherry Red" action here.
I am ordering a Wolfe 4.5" shrinking disc. Looks like a cool toy. I'd rather have the larger size, but I don't have a large grinder. You can search "Shrinking Disc" on you tube and see some cool how to videos. I think they have videos on the Wolfe site as well.
Bigbob is offline
post #12 of 19 Old 09-21-2010, 06:24 PM
Netpackrat
Originally Posted by Bigbob View Post
Oil can?
When you have a stretch in the middle of a panel, so that when pushed it will flex and snap like an old style oil can.
The meat tenderizer hammers, and the so-called "shrinking" dollies with a similar surface are just a gimmick and won't shrink anything; about all you can count on them to do is chew up the surface of your metal. Best thing to do with one of those hammers is to grind and polish it flat into a regular hammer.
post #13 of 19 Old 09-21-2010, 06:38 PM Thread Starter
Bigbob
Bigbob's Avatar
Thanks, I figured that out watching video on the shrinking wheel. Very good descriptor phrase.
Ditto. I don't see how you can shrink something by hitting it? I can hit this wave, which is basically a "oil can" deal, all I want and it may pop the other direction, but the metal has to be shrunk to get it out. Small dents can be dollyed and tapped close. This is a 4-5 inch area that will just spring from one side to the other. If measured, I'd say it sticks up maybe .050 or less. In bare metal form you can't see it. You can feel it and it'll stand out like a sore thumb once painted. I will need some filler on this panel and a couple other places. But all I want to fill is pinholes and imperfections from welding.
6 Speed, Hardtop
Bigbob is offline
post #14 of 19 Old 09-21-2010, 11:44 PM
Netpackrat
These links probably won't be a great deal of help with your specific problem, but they do show somebody shrinking metal just by hitting it with smooth faced tools:
YouTube - Shrinking Metal with a Plastic Mallet
YouTube - Air Power Hammer - Shrinking Steel (14-gauge, hot-rolled)
Bottom line, large, flat spans of thin sheet are hard to keep from distorting, and even harder to return to flat.
post #15 of 19 Old 09-23-2010, 04:11 PM
Jason_alex
18 GA. Is thin enough, heat the back side of the low spot and just let the air cool it it will expand at first but then pull back down farther than before.
Jason_alex is offline
brackets, tubing or metal insert fill gap b/t bumper and metal so lamps dont shake osd Fabrication Shop 4 06-13-2010 02:40 PM
how to cut metal. ksheffer08 Fabrication Shop 14 10-27-2009 06:19 PM
What to use to cut metal? GrantTJ Fabrication Shop 43 09-12-2009 07:09 PM
Rust due to metal on metal beeper General Jeep & Off-Road Equipment 5 04-15-2009 11:24 AM
soft top is shrinking! benjaminaz General Jeep & Off-Road Equipment 8 09-06-2008 10:03 PM
