Sheet metal top for roll cage - JeepForum.com
post #1 of 9 Old 07-30-2013, 12:46 AM Thread Starter
outbackmatt
So what gauge material is everyone using to make the sheet metal top for a custom roll cage and whats the best way to mount it so it doesnt rattle?
I'm going for something simple like this.
outbackmatt is offline
post #2 of 9 Old 07-30-2013, 12:06 PM
AtTheHelm
Depends on how much weight you're willing to put up there.
If it were me I'd put bolt it to tabs with countersunk machine screws.
Here is a chart for weights and thicknesses of sheet metal. Hopefully this helps.
AtTheHelm is offline
post #3 of 9 Old 07-30-2013, 02:11 PM
1222
RIP John
1222's Avatar
Originally Posted by AtTheHelm View Post
...If it were me I'd put bolt it to tabs with countersunk machine screws...
Thatís exactly how I would do it too although I would use aluminum instead of sheet metal; probably 1/8-inch.
1222 is offline
post #4 of 9 Old 07-30-2013, 02:24 PM
Jim1611
Jim1611's Avatar
^^^^Good idea.
Jim1611 is offline
post #5 of 9 Old 07-30-2013, 03:18 PM
AtTheHelm
Aluminum would be better.
post #6 of 9 Old 07-30-2013, 04:25 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Get some UHMWPE, doesn't rust, rattle, corrode or transfer heat to you hand when you touch it and puncture proof. Oh and easily machinable.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #7 of 9 Old 08-01-2013, 09:12 AM
WSS
WSS's Avatar
1972 CJ5
There is a guy who builds cages for these utv things next to my welding supplier and he uses aluminum and this insulator underneath the aluminum. He says it stops rattles and lowers the heat from the sun. It looks like foam sandwiched between two layers of some thin plastic. the insulator is probably 3/16" thick and the aluminum is probably 14ga (.080" ish)
WSS
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is offline
post #8 of 9 Old 08-02-2013, 06:31 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've also used expanded mesh. Easy to form and you can tack weld it to all the tubing. It allows a good overhead view while still casting plenty of shade from the sun.
BESRK is offline
post #9 of 9 Old 08-02-2013, 02:03 PM
schitzangiggles
King of Macastan
Cool idea!
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
