Seat spacers - Page 3 - JeepForum.com
post #31 of 76 Old 05-07-2009, 09:28 PM
Fred007
Originally Posted by JeeperDon View Post
I'm on the other end. I welded up new seat pedestals that are 2" lower. Now I look through about the center of the windshield height rather than the top 1/3.
Any pictures of your setup? I have to do the same thing and have been thinking about the design for a while now. Hacked the factory ones, but they are not square with the seat and when bolted cause the seat to bind and not be able to move forward/backwards. Thanks.
Fred007 is offline
post #32 of 76 Old 05-08-2009, 04:45 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
No photos (seat installed, can't see much), Fab procedure was easy though.
1) Made three floor plates (outside plate is flat for the two holes) and bolted them to the floor (3/16" stock).
2) Cut two lengths of steel to bolt to the bottom of the sliders, 1.5"x1,5" angle stock.
3) With the angle stock bolted to the sliders, weld two cross pieces somewhere to make a rectangle bolted to the sliders.
4) Take rectangle off the seat, make 4 struts (I used 1/2"x1/2" angle stock) to hold the rectangle off the floor and weld them in.
5) I think I also made one cross piece per seat to triangulate side to side for strength and no side flexing. The vertical parts were angled enough front to rear to eliminate flex in that direction.
Do a lot of measuring and positioning. I used small clamps and welding magnets to hold the rectangle in the right position while I fabricated the vertical struts.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #33 of 76 Old 05-14-2009, 07:28 AM
Kip03TJ
The 1" risers are totally worth it. I'm very glad I installed them. Thanks
FOR SALE
14,960 miles perfect condition
2003 Jeep Wrangler Sahara edition fully loaded 5 speed manual. Brown dog 1" motor mounts, Currie 1" body lift, jks front disconnects, 31" Goodyear Wrangler duratracs, 8 adjustable control arms, Advance Adapters HD SYE, Tom woods premium driveshaft, driver & passenger heated seats
Kip03TJ is offline
post #34 of 76 Old 05-14-2009, 09:59 AM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
Originally Posted by Kip03TJ View Post
Seat still functions completely the same
Looks good and that has to be the cleanest '03 TJ interior I've ever seen...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #35 of 76 Old 05-14-2009, 03:42 PM
Kip03TJ
Thanks Chilipalmer I take a lot of pride in my "new" Jeep. I hope to keep it nice for years and years and really enjoy it like I did my YJ.
FOR SALE
Kip03TJ is offline
post #36 of 76 Old 10-29-2009, 09:56 AM
gcrv01tj
would i be able to get all of these parts, the metal block, at the Lowes in town?
gcrv01tj is offline
post #37 of 76 Old 10-29-2009, 10:35 AM
gcrv01tj
bump for answer
want to do this tonight before my road trip this weekend.
gcrv01tj is offline
post #38 of 76 Old 10-29-2009, 12:51 PM
gcrv01tj
gcrv01tj is offline
post #39 of 76 Old 10-29-2009, 01:57 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It might work. However, I would worry about that perforated 14ga tube kind of "bulging" out on the sides over time. That would cause the seat mounting bolts to loosen up.
BESRK is offline
post #40 of 76 Old 10-29-2009, 02:07 PM
gcrv01tj
so basically i am sol... i heard someone using skateboard wheels to raise the seats. is that going to be just as strong?
gcrv01tj is offline
post #41 of 76 Old 10-29-2009, 02:10 PM
ChiliPalmer
Like Bersk I would be worried about it bulging after a while. You can use hockey pucks though...
Forum!
post #42 of 76 Old 10-29-2009, 02:51 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
They're made from Polyurethane.. would probably work okay if you can get the height you want.
BESRK is offline
post #43 of 76 Old 10-29-2009, 03:44 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
no it wont be "just as strong".
polyurethane, like most plastics, has a viscoelastic component. This means you get phenomena called stress relaxation and creep.
Ever hang a bike from the ceiling in your garage using a bungie cord?
Notice how 2 months later its like a foot lower than it was initially? Thats viscoelasticity.
I wouldn't want viscoelastic properties anywhere near a seat mount thats going to keep me alive during a crash.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #44 of 76 Old 10-29-2009, 04:48 PM
gcrv01tj
i guess i will just have to wait and get a solid block of aluminum or steel.
gcrv01tj is offline
post #45 of 76 Old 11-02-2009, 02:21 PM
lamigra
Junior Member
lamigra's Avatar
Have you thought about offering more of these for sale? I'd buy a set!!
Originally Posted by Scotch740 View Post
Well being 5' 9.5" I always felt my seat was too low. Then Jeep Forum confirmed that, then I rode in a Jeep with 1" spacers, then I had to have some. Little research showed those would run me close to $80. Too much for my cheap ***. So I designed my own.
I designed them so I would have as much area contacting the floor as possible, I have 18 sq.in. of contact with the floor vs 9 if the blocks were stood on end. I feel this is better because if I hit something, like another deer the tub is less likely to be damaged with more area for the force to be spread over.
1.5"x1.5"x12" 6061
Little CAD work, done after the job just for JF.
The front left and right blocks bolt hole location is different because I wanted as much area in front of the bolt as possilbe.
Cut on band saw, drill holes, sand with flapper disk, sand with 6" sander, paint in 27 degree weather.
Pick up bolts:
3 x 8mm 1.25mm pitch 70mm long bolts (65mm will also work) Grade 10.9
3 x Washers for above bolts
1 x 7/16 2-3/4" (2-1/2" will work also) Grade 8
1 x Washer for above bolt
Installed:
Front
Rear
Extra space under seat.
Unfortunately I spent close to $30 on one set. Thats because of $15 shipping. I could have picked up the aluminum stock for $5 locally but that required me drive 20 min and find the time to do it during the day.
I have not driven on or off road yet. But just sitting in it and moving around the Driveway is like driving a whole new jeep. The window sill is now at the right height for an arm rest and the view over the hood is much better. Looking forward to getting out in it, especially since the jeeps been laid up for a week after nailing a deer at 45mph the eve of Xmas eve. Spend all day getting it back together and now the only thing thats missing is one fog light.
lamigra is offline
seat glovers seat covers Jay12 Street Jeep Forum 3 04-21-2010 07:54 PM
Would I need spacers? Longspoon Tires & Wheels 5 07-13-2008 10:04 AM
Spacers ? jrs948 Tires & Wheels 8 03-13-2008 07:44 PM
sub in the back seat, locking the seat down? nycaubrun Audio, CB & Ham Radios, GPS, & Electrical 2 04-29-2007 06:47 PM
How about these spacers? Dozer. Tires & Wheels 0 10-23-2005 03:45 PM
