#1 | |
Seat spacers
Well being 5' 9.5" I always felt my seat was too low. Then Jeep Forum confirmed that, then I rode in a Jeep with 1" spacers, then I had to have some. Little research showed those would run me close to $80. Too much for my cheap ***. So I designed my own.
I designed them so I would have as much area contacting the floor as possible, I have 18 sq.in. of contact with the floor vs 9 if the blocks were stood on end. I feel this is better because if I hit something, like another deer the tub is less likely to be damaged with more area for the force to be spread over.1.5"x1.5"x12" 6061 ![]() Little CAD work, done after the job just for JF. The front left and right blocks bolt hole location is different because I wanted as much area in front of the bolt as possilbe. ![]() Cut on band saw, drill holes, sand with flapper disk, sand with 6" sander, paint in 27 degree weather. Pick up bolts: 3 x 8mm 1.25mm pitch 70mm long bolts (65mm will also work) Grade 10.9 3 x Washers for above bolts 1 x 7/16-20 X 2-3/4" (2-1/2" will work also) Grade 8 1 x Washer for above bolt ![]() Installed: Front ![]() Rear ![]() Extra space under seat. ![]() Unfortunately I spent close to $30 on one set. Thats because of $15 shipping. I could have picked up the aluminum stock for $5 locally but that required me drive 20 min and find the time to do it during the day. I have not driven on or off road yet. But just sitting in it and moving around the Driveway is like driving a whole new jeep. The window sill is now at the right height for an arm rest and the view over the hood is much better. Looking forward to getting out in it, especially since the jeeps been laid up for a week after nailing a deer at 45mph the eve of Xmas eve. Spend all day getting it back together and now the only thing thats missing is one fog light.
#2 |
what a good idea. i am gonna copy you.
1998 Sahara TJ 4.0 5spd RE 3.5 SF f/r trackbar - 32x11.5 BFG AT - DANA 30/44 4.11 - CURRIE sye/custom DS - OX locker rear - XRC8 winch gen 2 (free!) - OR-FAB tire/gerry can carrier - Yaesu/Kenwood vhf/uhf |
#3 | |
Post your pics and any other ideas you incorporate into it. I want to do a lock box but thats going to have to wait till summer. |
#4 |
I am going to be doing this next weekend when I install the inseat heaters..
I have about 30' of 3/4"X1" tube laying around... Do you think 1" will be wide enough? Im 6'1" and the G/F is 5'7" so I dont want to go to high...Im thinking 3/4 will be a nice improvement... |
#5 |
Those look really nice. I probably would have just chopped some 1"sq stock and eyballed it.
#6 |
GROUND POUNDER
Scott.. should've gave me a hollar.. I think I've got a 10ft stick of 2" diameter 6061 aluminum laying on the shop floor somewhere. I could've just tossed it in the bandsaw and hacked you off 2" pieces. Could've even drilled and polished them on the lathe for ya.. they'd be blingin'
Those square ones are nice looking though.. especially black. I like that.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#7 | |
Besrk, Thanks for the offer that would have made it much cheaper. I might get you to cut some if I do the passenger side. |
#8 |
ΜΟΛΩΝ ΛΑΒΕ
wow that is the most detailed blocks i have ever seen
'99 Gunmetal TJ Blue Jeep Club Member #256 4" RC X-Series, 1in BL Rokmen Armor KC Day Lighters, 33 BFG M/T with more to come OlllllllO |
#9 |
Did the above Seat Spacers - Super!
I did the seat spacers with 1 1/2" solid steel stock exactly like the above measurements. They worked out perfectly and Boy do I have great visibility now! I am 5' 10" and everything worked great and feel terrific! I recommend this to everyone! Wild Thing.
#10 |
She has her top off!!!
I did mine several years ago on my TJ got them off ebay... my buddy did the hockeypucks on his CJ both options work great and never had a problem with the seats or safety... quick and easy mod to give you a lift lol...
J33p'r "Right tools for the Right Job produce Right Results" |
#11 |
So one of the seat bolts is completely different from the rest? 3 are metric and one is SAE?
2005 TJ Rubicon 2dr. Khaki Dual top, 4" OME springs w/33" BFG MTs on 16" MotoMetals, Superlift rear adj. Trackbar & JKS front adj., Currie currectlync steering setup, Russel braided Stainless 4" extended brake lines, ARB bull bar w/ Smittybilt XRC8 winch, Garvin Wilderness swing away tire carrier/bumper system w/ trailrack and gas can holders, KC slimlites 130W windshield mounted, Outlaw door hinge mounted mirrors, JKS sway bar discos, TW doublecardan DS, JKS Adj. CA., 4-Hi locker switch mod. 2012 Jeep JK Sport 2dr. Sahara Tan 6sp. Past Jeeps: 78 Golden Eagle CJ7 304, 85 CJ7 4.2L and 95 YJ 4.0L |
#12 |
Got my eye on you.....
Yes one is standard, I belive it is because the right rear of the drivers seat supports the seatbelt mounting frame thus the larger bolt
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#13 | |
#14 |
Looks good, very professional looking.
#15 |
Copied you and I freakin love em. For those interested I got my aluminum from speedymetals.com (they cut it there) then had a local shop drill the holes because I needed them to be straight so the bolts would fit and I didn't have that equipment at home. All in all it ended up costing me like 80 bucks (including bolts)...could definitely be done cheaper if you have access to the tools to do it.
P.S. I liked this design as well because it gave more contact with the tub. Pics...second pic the passenger seat had them installed, drivers side didn't. This is one of the best things I've done to my Jeep so far, seats feel much more natural being an inch and a half higher. ![]() ![]()
SPECIAL OPERATIONS WARRIOR FOUNDATION- PLEASE DONATE A FEW SHEKELS! Quiet Carpeted Hard Top Writeup - by Me TJ Boot Camp OnA PARTY ROCK! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
