Quantcast Sanden On Board Air - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Sanden On Board Air
Old 10-21-2005, 01:06 PM   #16
admar2
what kind of hose is that?
My OBA keeps popping hoses because of the heat.
admar2 is offline   Reply With Quote
Old 10-21-2005, 05:32 PM   #17
E_ROCK
I am really not sure. I went to Home Depot and picked up a 300psi hose. I haven't had a problem yet. Sorry, I am not much help on that problem
Garage Monkey, Wheeling Junkie
www.rockfrogs.org
E_ROCK is offline   Reply With Quote
Old 11-09-2005, 04:43 PM   #18
18to80DDC
Built Not Bought
18to80DDC's Avatar
How is your tank holding up under the tub, I was thinking about putting one there the other day after I realised how much wasted space was down there but was worried about boulder puncture.
2001 4.0L Wrangler Sport - 3.5" lift on 33's
1973 CJ5 360 - 4" lift on 35's
1982 CJ7 360 - 2" lift on 32's
1971 Series III E-type Jaguar V12 - no lift...
18to80DDC is offline   Reply With Quote
Old 11-09-2005, 05:04 PM   #19
E_ROCK
Nope problems to date. It looks like a scary place, but no rocks really get up there.
www.rockfrogs.org
Old 11-10-2005, 12:24 PM   #20
schitzangiggles
King of Mac-istan
schitzangiggles's Avatar
My wife just told me I have to keep the stock AC, so after searching around, I found a Mopar "V" twin piston ac compressor for free (everything is perfect on it). I can find 0 info on it, so if any one knows anything about it... I'll post pics as soon as I can find that fricken cord to hook the camera to the comp... Thanks.
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote
Old 03-27-2006, 12:46 PM   #21
Mr. Tobes
How long does it take for the compressor to fill up the tank and what pressure are you running?
Mr. Tobes is offline   Reply With Quote
Old 03-27-2006, 09:37 PM   #22
Swamp Boy
It takes me about 3 minutes at idle and about 2 mins at 2000..
I run 120# regulator on mine...
Just another soccer moms Grocery getter....
[Url]http://www.jeepforum.com/gallery/files//8/5/6/5/hatt034.jpg[/url]
Swamp Boy is offline   Reply With Quote
Old 03-27-2006, 10:43 PM   #23
grandman97
hey swamp boy! where ya been? whatever happened to the zebra???
grandman97 is offline   Reply With Quote
Old 03-27-2006, 11:37 PM   #24
TellyDSP
Poland and PPV!!!!
Originally Posted by schitzangiggles
Doesany body know how many CFM the stock Sanden will do? (yes I have searched)
I know it's late, but here's the info I gained when I was doing my research back when. The sanden 508 is a 5 piston compressor that puts out 8cfm. the Sanden 709 is 7 piston putting out 9cfm. I've seen that the 709 does not require an external oiler. Dont know the truth. These figured compared to the popular York 210, which puts out 10cfm IIRC. I went with the 508 cause it was a direct bolt-in. Now if only I could muster the determination to actually install it.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote
Old 04-09-2006, 02:41 PM   #25
Tessie
What models came with the Sanden 508? I am planning on using one on my truck (air ride). How much am I looking to spend on one if I have to go to the junk yard?
Tessie is offline   Reply With Quote
Old 04-09-2006, 08:11 PM   #26
TJVigilante
You may want to consider using stainless braided air hose for the first few feet out of the compressor to stand up to the heat...otherwise you'll start melting and blowing your hose after a little while.
TJVigilante is offline   Reply With Quote
Old 04-09-2006, 08:58 PM   #27
TellyDSP
Poland and PPV!!!!
I dont know exactly which models they're in. I just looked for ones that had the same mounting holes/setup. I got mine from an XJ at my local P'n'P for $30. There's a ton of XJ's floating around that are old gov't vehicles. I'm assuming you can find them on wranglers, if you're lucky enough to find on intact at the JY. On car-part, a search for compressors for 95 Wranglers also yields 94-96 XJ's, so I'm assuming thats a safe range for a bolt-in. I guess it would depend on the year of your rig. Make sure it's in good shape and has a working clutch.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Old 11-21-2007, 11:35 AM   #28
joe's_yj
how did you wire in a switch?
my build up http://jeepforum.com/forum/showthread.php?t=427353
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline   Reply With Quote
Old 11-21-2007, 01:44 PM   #29
E_ROCK
Take a wire from a fused iginition switch "on" source over to a on/off switch at the dash. Wire from the switch over to the pressure switch. The pressure switch is mostly a DPDT switch, so wire the hot wire to the terminal marked "C" or common. Take the other terminal that is marked "N/C" or "NC" or normal closed to the compressor. The compressor most likey has multiple terminal. Just keep testing the leads until you hear one that engages the clutch. Wire the lead that engages the clutch to the "N/C" of the pressure switch.
www.rockfrogs.org
Old 09-25-2008, 05:37 AM   #30
rockstedy
where does one find these pressure sensor switch ?
sorry if i missed it
92' YJ, 5.0 Mustang,Dana 60 rear , dana 44 front, 3:56, 4.5" lift kit.,SOA,rhino lined tub,40x17x16.5 cut gumbo mudders on rear and fun country on front,rear driveshaft brake
98' TJ 2.5 lift 4.0 liter raise fenders 31' mudd terrains
2002 Grand cherokee bone stock
rockstedy is offline   Reply With Quote
Glock Forum
