Quantcast Sanden On Board Air - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Sanden On Board Air
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 11-08-2003, 12:17 PM   #1
E_ROCK
Sanden On Board Air
The first step is acquiring an A/C compressor. I limited my junkyard search to a stock compressor that came out of a ’91 to ’95 Wrangler or Cherokee. Compressor of those years will bolt directly into the A/C mounting bracket.
If you are buying a compressor, you will need to get an additional idler pulley, pulley bushing, bolt, and belt. The Figure 1 shows the location of the pulley (1) and bushing (2).
Figure 1
If you are using your stock A/C, you are one step ahead. But you will need to purge the A/C system of all the Freon. You will not need to buy a new belt or pulley.
The next picture is a schematic of the system. I could not get the picture any larger due to Imagestation. If you PM me with your email address, I will send you the drafted schematic in PDF format.
Figure 2
Figure 3 show the intake side of the compressor. (3) is the air filter. (4) is the air tool lubricator. The air filter is a crankcase filter. The air tool oiler can be bought at harbor freight.
Figure 3
Figure 4 shows the fitting used on the suction and discharge ports of the compressor. (5) is a 1/4" NPT elbow. (6) is a 3/4" to 1/2" NPT (female to female) fitting. (7) is a 1/2" to 1/4" NPT (male to female) fitting.
Figure 4
Figure 5 shows what is needed after the discharge port. I chose to mount everything to the scissor jack mount. (8) is the oil/air filter. (9) is the check valve. (10) is pressure gage. (11) is pressure sensor switch.
Figure 5
Figure 6 show the location of my front quick connect.
Figure 6
Figure 7 show the location of my rear connect.
Figure 7
Figure 8 show the location of my tank. I drilled up through the tub and used 4 bolts.
Figure 8
Result:
See for yourself. Figure is a picture of my 31" Xterrian aired down to 12psi. Figure 10 is a picture of my Jeep at Holy Cross in Colorado.
Figure 9
Figure 10
Garage Monkey, Wheeling Junkie
www.rockfrogs.org
E_ROCK is offline   Reply With Quote
Old 11-08-2003, 08:11 PM   #2
Swamp Boy
very nice.. Setup..
By the way.. If you copy the link location of the diagram...
and add.. .orig.jpg to the end of it.. IT will take you to the
original that is quite large..
Thanks for the write up..
carl
OH yeah.. I have just gotten a scuba tank to use as my air tank..
I cant wait to get started on mine.. Gonna be cool...
Just another soccer moms Grocery getter....
[Url]http://www.jeepforum.com/gallery/files//8/5/6/5/hatt034.jpg[/url]
Swamp Boy is offline   Reply With Quote
Old 11-09-2003, 01:28 PM   #3
E_ROCK
Originally Posted by Swamp Boy
very nice.. Setup..
carl
I tried putting the .orig.jpg on the end. It gave me a messege that said:
“Sorry,
You are trying to access an image from outside of Imagestaion.com"
I don't know how to get around that.
Cool idea using a scuba tank. I think that will work well. I spent countless hours at truck (big rigs) junkyards and shops trying to find a cheap tank. I finally had to breakdown and buy a new one.
Have you decide how you are going to mount the tank. Just to let you know, you can run the system without a tank for awhile until you figure it out. I doesn't work as well, but it gets you by.
www.rockfrogs.org
Old 11-09-2003, 06:47 PM   #4
Swamp Boy
I think I am going to go to a dive shop and just buy a tank rack and use that.. I think it would look cool. On the inside by the back window...
Not sure about the .orig.jpg not working it works for me..
I even did it again just now just to make sure..
Carl
Old 11-09-2003, 09:38 PM   #5
Dembones
Best airtank available: Beer Keg.
Blue '94 Wrangler, 2.5L: Under monsterization
37" Claws/teralow/HPD44/Trussed HI9/5:38s/detroits/SOA, shackle reversal on rebuilt waggy and XJ springs.
Blue Jeep Club member 2
Much more info here
Dembones is offline   Reply With Quote
Old 11-10-2003, 08:05 AM   #6
E_ROCK
Right on. I have a couple extra of those hanging around. I should have been thinking.
I could just see that conversation.
"No officer, its for my OBA system. It really doesn’t have beer in it.”
www.rockfrogs.org
Old 11-10-2003, 06:01 PM   #7
Dembones
Except mount a tap on the bottom- 1/2 booze 1/2 compressed air. Just imagine, at 150+ PSI, fill your tankard from 30 ft. away
Anyway I like your setup, there's more Volvos than Jeeps in junkyards around here, I'll probably end up going York.
Much more info here
Old 01-26-2004, 03:17 AM   #8
jwtrapper
I know this is kind of an old post but just had to add my $.02 and some more pics. Who could get tired of on board air? Its great dont know what I ever did with out it.
I have moved my air chuck to the front of the jeep where it comes out just below the head light but other than that its the same. I have ran it up to over the 160psi that the gauge shows and have used my compressor to run my blasting cabinet and with a little bit of throttle it'll keep up okay.
And for PaxtonTransAm why do everything to your jeep that you have done if you are not going to wheel it? If you just want the Bling Bling go find a ricer. If where to ever get your rig out of the mall parking lot you might just see how on board air is real a usefull tool to have.
99 XJ 6" TnT Y-Link 8.8 4.56 Detroit, True Turd in the Dana Turdy. York w/retractable hose reel!
jwtrapper is offline   Reply With Quote
Old 01-26-2004, 08:00 AM   #9
E_ROCK
Very nice setup. Is that a u-bolt that goes around the oil/water filter? If it is, where does it bolt to? Did you make mounting bracket for the second compressor or is that a kilby product?
I notice you are from CO also. I viewed your jeep pictures and noticed Medano Pass in your pictures. Are you located in Southern Colorado?
www.rockfrogs.org
Old 01-26-2004, 08:34 AM   #10
igofshn
Locked @ both ends
igofshn's Avatar
I'd say a beer keg would take up a little too much space.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
Old 01-26-2004, 08:37 AM   #11
igofshn
Locked @ both ends
igofshn's Avatar
This has been in the TJ FAQ for quite a while. It is what I used when I did my oba.
http://www.off-road.com/jeep/cherokee/2001/05_may/onboard-air/onboardair1.html
[Jeep Pics
Old 01-26-2004, 08:58 AM   #12
Quan
This is a good thread, great writeup.... maybe we should move it to the projects section to help some others out.
[b]There comes a time... In every mans life, when decisions... have... to be made. Whether to toil, to labor, or just plain piss your days away.[/b]
[b][COLOR=green]Green[/color] Jeep Club Member #15[/b]
[b]My Jeep Made Me Broke Club Member #2[/b]
93 YJ I-6 w/ stuff
Keep the [COLOR=blue]greasy[/color] side down
[URL=http://members.cox.net/quanno/ford88.html]FORD 8.8 INFO HERE![/URL]
Quan is offline   Reply With Quote
Old 01-26-2004, 08:59 AM   #13
E_ROCK
That is fine with me. Are you a mod Quan?
www.rockfrogs.org
Old 10-12-2005, 02:26 AM   #14
schitzangiggles
King of Mac-istan
schitzangiggles's Avatar
Doesany body know how many CFM the stock Sanden will do? (yes I have searched)
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote
Old 10-12-2005, 06:28 PM   #15
Swamp Boy
I dont know but I ran mine at high idle and it would run an impact gun.. At 2000 RPM's I was able to run a cut off tool and it did OK...
Glock Forum
