Reparing/beefing up rear of YJ frame with square tube (PICS) - JeepForum.com
post #1 of 3 Old 01-14-2013, 05:42 PM Thread Starter
CDW_327
My Yj has a little bit of Rot at the very back of my frame, not as bad as most but it's there. What I usually see people do to fix the shackle mount rot is cut out the bad and weld in plates, which works but doesn't gain you any strength over stock. Does anyone have a pics of replacing the back like 14" of the frame with square box tube? My plan is to cut the frame off about 14" back from the back end, but weld the new square tube in and weld fish plates over the seam. The only tricky part would be the bend in the frame right around the shackle mounts. I'm planning on welding a 2x4x3/16 square tube in for a rear crossmember with d ring mounts and 2" receiver, so I am looking for added strength. It just seems like totally replacing the back section of the frame with square tube would be way better then piecing it in with 1/8" plate...
CDW_327 is offline
post #2 of 3 Old 01-14-2013, 08:46 PM
Ironworker709
Ironworker709's Avatar
People generaly use at least 3/16" plate for replacement patches on the frames,at least one's who want a little extra security it is strong enough and better than stock.That would be much better than stock and more than stong enough for a 2" receiver crossmember.
Sounds like you have it well planned out to me,as far as the bends,i would just go with cutting the plate sides according to the bends and box it in and weld it up.as long as it's 3/16" plate and welded correctly it will be alot better than stock.
If all done the way you want,the only place of concern would be where it all ties into the existing factory frame,weld it 100% pen and then added fish plates or AKA diamaond plates,,make sure your fish plates have no sharp edges or sharp corners,round everything off,sharp corners are an area prone to crack and tear later from stress risers from the opposite sharp turns in the welded area.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 3 Old 01-16-2013, 12:10 PM
fyrfyr
http://www.greatlakes4x4.com/showthread.php?t=241476
I have a few pics on the link above showing how I did it. Fish plates were added after the photos.
fyrfyr is offline
