Removing a snow plow - JeepForum.com
post #1 of 5 Old 09-13-2012, 05:32 AM Thread Starter
MrGeepers
1960 CJ5
I have just purchased a 1960 Jeep CJ5 for a frame up restoration. It has a Western snow set-up welded to the frame. I would like to remove it and I do not have a welder. What is my best option? Should I use an angle grinder with a cutting wheel? Should I cut directly at the welds or at the metal above them? What is the best method to remove the weld residue from the front bumper? Thanks in advance....
"If you always do what you have always done, you will always get what you always got."
1960 Jeep CJ... This thing was built while JFK was still president! WOW...
MrGeepers is offline
post #2 of 5 Old 09-14-2012, 03:17 PM
Diamond-x
1991 XJ Cherokee
Your project is going to take a lot of fabrication. Not only to cut off the plow/attachment but to return the front-end to it's normal function.
Your idea of using the angle grinder should work, that and a sawzall. Try to grind and cut directly through the welds, or just on the plow side. Then use a grinding wheel to remove the remaining material back to the original steel. I'm going to guess that you have a lot of modified and removed steel from the original front end. You may want to research a wire fed welder.
A quick note here on eye, nose and ear protection. Please use them.
Also, if you can get the plow off in one piece you can sell it to fund your fab equipment. Looks like a fun project.
Diamond-x is offline
post #3 of 5 Old 09-14-2012, 05:00 PM
festerw
festerw's Avatar
That's definitely a disaster, like said above cut through the welds if you can. That's for sure a 'custom' deal and a poor one at that.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #4 of 5 Old 10-09-2012, 11:28 AM
Diamond-x
1991 XJ Cherokee
Were you able to make any progress on this?
post #5 of 5 Old 10-13-2012, 08:58 AM
RedlegWJ
Sawzall won't be real fast but it'll do wonders for you with cutting oil if you take your time.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
Snow plow recommendations for my TJ CheesyD General Jeep & Off-Road Equipment 16 10-21-2011 08:58 AM
YJ Snow Plow Mount oct7brian Fabrication Shop 13 02-01-2011 04:00 PM
I want to get a snow plow for my CJ penjrav8r General Jeep & Off-Road Equipment 5 12-09-2010 04:42 PM
Snow Plow on Jeep? JEK3 General Jeep & Off-Road Equipment 14 02-14-2010 10:21 PM
Snow Plow Tech? Oldbill51 General Jeep & Off-Road Equipment 2 10-13-2009 04:04 PM
