Remote control windshield light - JeepForum.com
post #1 of 12 Old 01-09-2012, 04:50 PM Thread Starter
beefcake3
what i want to do but havent yet started any sketches for is to take the motor and switch from a car mirror and mount it to the drivers side windshield light.
has anyone done this before and any suggestions and ideas would be appreciated.
beefcake3 is offline
post #2 of 12 Old 01-09-2012, 05:21 PM
RockMonster
i wouldent see why it wouldent work, might have issues with weight and wind resistance pushing the light a certain way how are you planning to mount? personally i would try to mount with the light putting as little leverage as possable on the motor.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #3 of 12 Old 01-13-2012, 01:36 PM Thread Starter
beefcake3
im thinking of a U shaped bracket the has a motor inside of it that attaches to windshield bracket and has the light mounted on top of it and the motor spins the bracket that the light is attached to
post #4 of 12 Old 01-13-2012, 01:59 PM Thread Starter
beefcake3
Sketch:
Material:
The stepper motor and a zoom switch the i took off a video camera:
post #5 of 12 Old 01-13-2012, 02:03 PM
rdsk8ter
1982 CJ7
very interesting idea I would love to see how this turns out. What about a window motor? seems to me that youll need two motors one for up down one for side side I would think a mirror wouldnt go side to side up and down sure but wheres the side to side
here is my build threads
http://www.jeepforum.com/forum/f104/randys-offroad-trailer-1164102/
rdsk8ter is offline
post #6 of 12 Old 01-13-2012, 02:44 PM
Ironworker709
Ironworker709's Avatar
I was going to do this i would scrounge around the junkyards and find a powered mirror from something an F250...mine has them and it will adjust everyway you can think of,up,down,side to side,just get the switch and motor and the lil harness that comes with it..this way you'll have full adjustment all around and plus the motors in them i would imagine are sealed from weather since they just sit inside a plastice box in the mirror...
Just a thought......
and thats a GREATt idea..there's been many a times i was runnin the long back stretch of roads here in Ga and wishing i could adjust them on the fly looking for deer on the sides of the road way ahead............
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #7 of 12 Old 01-13-2012, 08:54 PM
webdog
1990 XJ Cherokee
Interested to see how this turns out!
I just installed some A Pillar Police lights on my XJ for this same reason of adjustability.
webdog is offline
post #8 of 12 Old 01-14-2012, 07:38 AM Thread Starter
beefcake3
i decided to not to use a door mirror motor because i didnt think it would give me the full 180 degree rotation i wanted
post #9 of 12 Old 01-14-2012, 08:41 AM
Ironworker709
Might want to check a lil closer into those power mirror motors,if i run mine all the way to one side the motor still runs but the mirror kind of clicks like its just slipping on some kind ratcheting system
Never forget 9/11
post #10 of 12 Old 01-14-2012, 01:18 PM
timatoe
timatoe's Avatar
At a stop or while crawling slowly the motors should hold fine. I'd highly recommend you have whatever spotlight pointed down or at least where the back teardrop area is facing forward for highway driving. We had an entire fleet of inoperable motorized spotlights from the wind catching them and flopping them back. I've seen motorized ones on boats that work great, but for some reason (likely do to smaller size availability) car ones seem to break easily. I think the best or at least easiest to use are the old standard pillar mounted light with the handle inside the cab.
timatoe is offline
post #11 of 12 Old 01-14-2012, 07:37 PM Thread Starter
beefcake3
i have thought about this and im thinking of putting a solenoid to lock it into holes that a drilled in the windshield bracket at desired positions
(the purpose of the second hole on the back of the bracket on the picture of sketch)
post #12 of 12 Old 01-15-2012, 10:37 AM
zooby
I would use small power window motors and mount it on the bumper. Ive had to repair a bunch of power mirrors working with GM over the last 30 years and I don't think they would hold the load very long.
So here's my idea.
Mount the motor in a small box to the light housing, lay it on its side. This will be your "up/down". Mount the next motor/box under. This will be your "side to side"
Mount the whole thing in the center of your front bumper. Add something to cradle the light when not in use (face down onto a stop or ledge)
The problem with my idea is the side to side motor is carrying a bit of a load. Possibly reinforce the box it's in and use a bearing on the shaft.
The easy way would be go buy the ones they mount on the top of motor homes (probably the same mentioned earlier for boats)
This idea just got added to my never ending list of things to build for my Jeep.
zooby is offline
Remote control windshield light beefcake3 Fabrication Shop 3 01-26-2012 04:44 PM
standard Winch 12' Wired Remote Control Calven727 General Jeep & Off-Road Equipment 10 05-09-2010 04:32 PM
Remote Control..? shunt Audio, CB & Ham Radios, GPS, & Electrical 14 01-07-2008 04:56 PM
What are the advantages/disadvantages of Integrated Control Pack vs Remote on a Winch DINOCAVE General Jeep & Off-Road Equipment 13 03-24-2007 09:58 AM
rancho remote control shocks gunthagunth Tires & Wheels 6 03-27-2006 07:40 AM
