Recovery tabs out of Tool Steel? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Recovery tabs out of Tool Steel?
NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD15 x 8 Black D-Window Steel Wheels Set of 4ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 09-29-2014, 03:06 PM   #1
Domaso
I'm planning to fabricate and add some recovery shackle/D-ring tabs to the front of my Jeep WJ. I found a guy who sells just the right size flat bar I need, but it's Tool Steel... (he said it's hardness T10 or something..). He said it's hard but drillable.
I wonder if this steel is suitable for recovery tabs, not too brittle? The shackles are going to be WLL 3.25T (0.7" pin) and the tabs I'm going to make are shown in the picture. As you can see there is 0.5" of "meat" around the pin (not sure if that's enough).
Any thoughts if this tool steel would be good, or should I just buy the regular "mild"/"carbon" steel?
2004 ✮ Jeep Grand Cherokee ✮ Overland Black Pearl Special Edition ✮ 2.7 CRD Diesel
Domaso is offline   Reply With Quote Quick reply to this message
Unread 09-29-2014, 03:27 PM   #2
AtTheHelm
You could just get those tabs premade with similar dimensions. There is a well known member on here who sells them, but I'll let him chime in if he's selling them at the moment.
Or you can just get Fawkes Fabrication's stand alone shackle mounts or Mini Max front receiver and be done with it...
AtTheHelm is offline   Reply With Quote Quick reply to this message
Unread 09-29-2014, 03:34 PM   #3
Domaso
It's a bit different in my case, check the location under my username
Unread 09-29-2014, 07:16 PM   #4
thantos858
1974 CJ5
For strength they will work but the bigger question is the alloy type of the steel. Some tool steels would be to brittle to deal with a jerking motion of a recovery point while others would be just fine. From what info you have given I'm guessing its a high speed tungsten base tool steel that's rather brittle for your intended use. T-type and M-type tool steels are used for cutting tools where strength and hardness must be retained at temperatures up to or exceeding 760 C. Personally I think it would be better and cheaper to get mild steel over tool steel.
thantos858 is offline   Reply With Quote Quick reply to this message
Unread 09-29-2014, 11:59 PM   #5
AtTheHelm
Whoops.. Yeah shipping would be big $$$ to Lithuania. I'm using the JF iphone app so locations don't show up.
As Anthos said, they'll be brittle which isn't good for shock loads. I've never welded tool steel, but my guess is you'd really have to preheat it before welding them to the brackets you make.
Good luck!
Unread 09-30-2014, 12:18 AM   #6
Domaso
You're right guys, that tool steel probably isn't a very good choice.. (that was just an idea as I could've gotten a perfectly shaped blank probably for even cheaper than mild steel).
I'm thinking that tool steel would probably be ok in normal conditions, but we sometimes get down to -10F or colder here in winter, so I wonder if the tab wouldn't crack off on a good tug... Plus it would be a pain to drill/machine/weld..
I guess I'll just go with the regular mild steel.
Unread 10-11-2014, 09:09 PM   #7
dwilliams35
I think it'd work, but it'd be a boogerbear to drill unless you've got a mill or something, and you're going to weaken any strength it's inherently got as soon as you put a welder to it anyway.
dwilliams35 is offline   Reply With Quote Quick reply to this message
