receiver mounted tire carrier - my take - Page 2 - JeepForum.com
post #16 of 29 Old 09-05-2010, 08:25 PM
2kbeep
Why not just weld a bead on one side of the hitch part that slides in and do away with the u bolt. Just grind bead down till it slides in perfect. I've had to do this a couple of times with the cheap receivers.
2kbeep is offline
post #17 of 29 Old 09-05-2010, 08:26 PM
HeightsTuff01
ty very much for the info, ive never seen or heard of that retailer in my life
HeightsTuff01 is offline
post #18 of 29 Old 09-12-2010, 07:09 PM
MustangJAB02
I love it! I was trying to come up with something like that for my ZJ but couldn't picture anything. Nice work man!
1995 Jeep Grand Cherokee Laredo
4.0L 201k+ miles (no rebuild yet)
Everything original except the normal replacing of mufflers, tires, spark plugs, but all done with stock replacement.
MustangJAB02 is offline
post #19 of 29 Old 09-13-2010, 12:45 PM
KDog223
Can you post some pictures of the tire mount area without the tire mounted? I really like the simplicity of this carrier and I want to build one myself like it.
KDog223 is offline
post #20 of 29 Old 09-23-2010, 07:04 PM Thread Starter
CJ7Pilot
1982 CJ8
Sorry it took me so long... here are photos of the top end.
I had previously cut the spare tire mount off my utility trailer, so I had it laying around, and decided to use it for this. If I were building one from scratch, it would be a little heavier, but I'll have to admit this one is holding up just fine.
I hope this helps!
Now I must hurry on... for there they go, and I am their leader...!
CJ7Pilot is offline
post #21 of 29 Old 09-24-2010, 10:22 AM
KDog223
Originally Posted by CJ7Pilot View Post
[/IMG]
I hope this helps!
It does, thanks. I was curious what the mounting plate looked like.
KDog223 is offline
post #22 of 29 Old 09-29-2010, 09:18 AM
GregB_00XJ
I have been looking at doing something like this for ages. This is probably the best and most useful design I have seen yet. I would like to honor your design decisions by totally copying the hell outta it, and making my own (with Props to you of course). lol
If only I could weld?
Thanks for the detail pics, if I ever get this done (project 44 of 365 or so) I will post up some pics!! Nice work man!
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #23 of 29 Old 09-29-2010, 04:28 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Looks great! how does it hold up with rough wheeling?
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #24 of 29 Old 09-29-2010, 06:54 PM Thread Starter
CJ7Pilot
1982 CJ8
Well, by my standards "rough wheeling" is fire roads, and the occasional dry stream bed with bowling ball sized rocks... and for that it's held up just fine.
I haven't made my heavy duty replacement for that u-bolt setup yet, and surprisingly, it's still rock solid!
I think this carrier could handle more rough wheeling than I'm ever likely to do.
CJ7Pilot is offline
post #25 of 29 Old 01-20-2011, 11:39 PM
85jeepcj7
any write ups on how you made it?
85jeepcj7 is offline
post #26 of 29 Old 02-03-2011, 03:14 PM
00JGC00
Originally Posted by Kettles View Post
You can do the commercial style route for that clamp, which is essentially a bolt though the hitch pin hole, with a threaded insert. It just tightens the hitch to the side of the receiver. I have one, and it locks too. Of course I lost the insert, but made one (5/8" nut welded to a 1.5" square piece of tubing).
Would be harder to make from scratch so it locks though.
Pics of that? I'm in the process of a hitch carrier as well and I'm trying to figure out a good way to eliminate the wobble.
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #27 of 29 Old 02-04-2011, 10:49 AM
Kettles
We had bought a kit that locks it down, but my dad left the hitch with the aluminum insert in it in the reciver without the pin and drove away. We never saw the hitch or the insert again, so I made my own insert. However I am sure you could make a similar setup without too much effort. Minus the locking part.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #28 of 29 Old 02-04-2011, 11:04 AM
00JGC00
How well did that work? I've seen those before, but I'm not sure how much weight they'd handle.
00JGC00 is offline
post #29 of 29 Old 02-04-2011, 01:59 PM
Kettles
Well I have used it for a 4 bike rack, towing a 3000lb boat, and with a hitch rack. The bike rack didn't move at all for 1340 miles (round trip on a vacation), or else it would have driven me insane rattleing. Hitch rack was secure. It usually keeps the hitch from clunking with the boat on too, on harder stops it may slide a tad, but 99% of the noise is eliminated.
I wouldn't want to tow without something like that to keep the clunking down.
I don't know what it is rated to handle.
Here is the one I have http://www.amazon.com/Valley-76820-Silent-Hitch-Pin/dp/B000BO8VG0.
I use a full size wrench to save my hands, and get it tighter.
If your receiver has the double hole you can use a J pin too. Same concept, no insert needed.
_=====o000o
Kettles is offline
Rear Tire carrier without a receiver hole BeerNut0875 General Jeep & Off-Road Equipment 5 05-23-2010 09:46 AM
Tongue mounted motorcycle carrier JustKidding09 Fabrication Shop 2 10-02-2009 12:10 PM
curt hitch mounted tire carrier aircruiser Cheap Tricks & Fixes 2 09-15-2009 02:55 PM
2" receiver tire carrier Runnerboy Tires & Wheels 13 01-19-2006 08:55 AM
receiver mounted cargo 'rail' Vacant Stare Fabrication Shop 0 06-08-2004 01:51 PM
