receiver mounted tire carrier - my take - JeepForum.com
post #1 of 29 Old 08-30-2010, 08:57 PM Thread Starter
CJ7Pilot
1982 CJ8
A Jeep needs a spare tire mounted on the back,so here's what I came up with for a receiver mounted tire carrier.
The only things I bought were the hitch extender and the latch, everything else was scraps left over from other projects. It's mostly 2x2x1/4 tubing, which is a little heavy, but it's what I had in my garage.
Most of what I weld is 1/8", and the 110v wire welder is great for that... but for this 1/4" tubing I had to fire up the 220v stick welder. What fun! I forgot how satisfying it is to really burn metal together.
The tire carrier is very solid, but the whole assembly wobbles around in the receiver. There are several fixes for that, I just haven't decided which one I'm going to use yet.
Also, as you can see, I still need to re-locate my license plate.
Now I must hurry on... for there they go, and I am their leader...!
CJ7Pilot is offline
post #2 of 29 Old 08-31-2010, 08:06 AM
Jim1611
Jim1611's Avatar
Very nice.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 29 Old 08-31-2010, 03:39 PM
250psd
Like that a lot better than the one's that fold toward you. Great job!
250psd is offline
post #4 of 29 Old 09-02-2010, 08:39 PM
CraigWK
2005 WK
Got enough scraps left to build me one of these? I've never considered that design before, but it makes alot of sense!
CraigWK is offline
post #5 of 29 Old 09-03-2010, 06:17 AM
ex m38a1er
Great!Like it a lot...
Maybe adding a gas strut from underneath...
" H TAN , H EΠI TAΣ"
'WHO DARES,WINS'
ex m38a1er is offline
post #6 of 29 Old 09-04-2010, 05:54 PM Thread Starter
CJ7Pilot
1982 CJ8
Thanks for the nice comments! Folding to the side gives much better access to the cargo area than folding to the rear does.
Today I folded it down in a crowded parking lot, and the tire was completely within my space, and didn't even come close to the car next to me (I was a little worried about that when I built it).
A gas strut would be pretty cool, or even some sort of torsion spring assist, but a 30" tire really isn't too hard to manage on a pivot like this.
Here's my fix for the wobble in the receiver. It's not very elegant, but it works really well. Essentially, it pulls the tire carrier tightly to the flat bottom of the receiver.
The u-bolt setup is more of a proof of concept for me... pretty soon I'll make a more substantial unit out of 3/8" flat bar and bolts.
CJ7Pilot is offline
post #7 of 29 Old 09-04-2010, 06:56 PM
Kettles
I like your design, much better than a fold away. This way you can still flip the tire down even if you had a trailer attached.
You can do the commercial style route for that clamp, which is essentially a bolt though the hitch pin hole, with a threaded insert. It just tightens the hitch to the side of the receiver. I have one, and it locks too. Of course I lost the insert, but made one (5/8" nut welded to a 1.5" square piece of tubing).
Would be harder to make from scratch so it locks though.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #8 of 29 Old 09-04-2010, 07:10 PM
jeepin ruby
Pretty cool! I like it better than those Ive seen that fold straight down. Id keep that lighter wheel on there though. A 33MT on a steelie would get heavy to lift after a while lol!
2012 JKU Altitude Edition... under construction!
2005 WK limited... The wifes.
jeepin ruby is offline
post #9 of 29 Old 09-05-2010, 05:48 AM
dodger889
Make a bracket for your license plate and mount it in the middle off the wheel. Make sure to use a disconnect for the light wiring.
Or do something like this V
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #10 of 29 Old 09-05-2010, 08:19 AM
HeightsTuff01
hey, where do you get the red handle assembly? thanks nice work btw
HeightsTuff01 is offline
post #11 of 29 Old 09-05-2010, 08:24 AM
jerryjeeper
Good idea with the "flip to right" swing away. I built a swing down hitch mout carrier and it works well but has some limitations. Nice job.
jerryjeeper is offline
post #12 of 29 Old 09-05-2010, 12:13 PM
webdog
1990 XJ Cherokee
McMaster sells them...
webdog is offline
post #13 of 29 Old 09-05-2010, 04:11 PM
jatepper
I'll answer for him.... It's a De Sta Co latch. Available for McMaster Carr or just do a search. Really nice latches though.
Nice tire carrier! Semper Fi!
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #14 of 29 Old 09-05-2010, 08:19 PM Thread Starter
CJ7Pilot
1982 CJ8
Jatepper's right, it's a De-Sta-Co 341R, Amazon.com, $36.60, free shipping. Semper-Fi!
I ended up moving my license plate to the left. It's too bad it covers up up the Jeep emblem... but if someone doesn't know this is a Jeep, then fk'm, they don't need to know.
I have a light to mount over it, I just haven't had time to install it yet.
CJ7Pilot is offline
post #15 of 29 Old 09-05-2010, 08:25 PM
silbotta
thats pretty damn cool
94 YJ
06 Cummins
silbotta is offline
Rear Tire carrier without a receiver hole BeerNut0875 General Jeep & Off-Road Equipment 5 05-23-2010 09:46 AM
Tongue mounted motorcycle carrier JustKidding09 Fabrication Shop 2 10-02-2009 12:10 PM
curt hitch mounted tire carrier aircruiser Cheap Tricks & Fixes 2 09-15-2009 02:55 PM
2" receiver tire carrier Runnerboy Tires & Wheels 13 01-19-2006 08:55 AM
receiver mounted cargo 'rail' Vacant Stare Fabrication Shop 0 06-08-2004 01:51 PM
