rear strech advice - JeepForum.com
post #1 of 7 Old 02-27-2011, 07:51 PM Thread Starter
NBFarmboy
rear strech advice
my starting point
98 tj, 4" short arm, 15 gallon fuel tank with stock skid, rubi dana 44, 2" body lift
and making new fuel lines for the 5.3 swap
i already cut off the rear crossmember, and want weld my bumper on as a crossmember, move the gas tank up and more to the rear, to make room for a 4" stretch and outboarding the shocks
i want the advice and design help of others on this
i am contemplating either one of these
1 cutting off the crossmember the rear shocks mount to and making a new one two inches higher and making even more room for the gas tank
or 2, cutting the frame and the bend and making the whole frame from factory crossmember back two inches higher so i can eliminate the body pucks in the back and make the bumper and everything else higher
anybody have some thoughts about this??
RAYS 4X4, an Official MCE dealer, Pm me for prices
"Redneck Rooster" 98 TJ with 5.3 Vortec, 4 speed, 37"s
Wifes "Ladybug" 95 YJ 2.5, 3.5" fenders, 33's, 1" body lift, 1" deep skid pan, york OBA 1" shackle lift
"Bullfrog" 88 XJ 4.0, Doorless, 2" lift, 33-10.5 tires, very cut fenders...
NBFarmboy is offline
post #2 of 7 Old 03-02-2011, 07:00 AM Thread Starter
NBFarmboy
nobody has any thoughts about these methods ???
post #3 of 7 Old 03-10-2011, 10:28 AM Thread Starter
NBFarmboy
i don't know why i bother asking, no one ever responds...
post #4 of 7 Old 03-10-2011, 04:46 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It's not that nobody wants to respond.. but more likely that not too many here have done that particular mod.
I don't have a TJ to look at as a reference so I'll generalize..
You mention raising the gas tank and moving it reaward to make room for your stretch. If I were going to do that, and already had the rear crossmember cut off.. I would probably just drop the tank loose, scoot it up against the body and back as far as I wanted, and then fab up whatever I needed to suppport it. If that means cutting/moving an existing crossmember, so be it.
I've done a stretch on a YJ before.. we just cut the frame off at the highest point of the bend (above the axle) and replaced everything with 2"x4" rectangle. It was basically a straight shot back where we welded a 2"x4" bumper directly to the ends... Since we were free to reposition the frame rails, we moved them inboard a bit to clear coilovers. You could probably do something similar.
BESRK is offline
post #5 of 7 Old 03-12-2011, 08:24 PM Thread Starter
NBFarmboy
thanks beserk that the kinda thoughts i needed
when you cut the frame and replaced it with 2x4 did you cut the body at all??? how exatly did you do that???
also did you put the gas tank through the floor or what??
one of my limits is that the rear floor has to stay intact for passengers, and cargo, so having the tank through the floor is kinda out of the question unless i get really creative..
as for moving the frame inboard i do like the sound of that as a am outboarding the shocks during this process...
trying to make this a very interesting fun project that turns a few heads now and then
but mainly i was a stretch, good departure angle and a sweeter rig lol
all that for a daily driver lol
post #6 of 7 Old 03-12-2011, 11:58 PM
E_ROCK
I know this may be a little apple to oranges, but I stretched my yj using the genright tank and a new rear cross member. I also outboarded the shocks with the poly pro towers. It may not help you but here is the link anyway.
http://www.jeepforum.com/forum/f12/e.../#post10756552
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #7 of 7 Old 03-13-2011, 05:17 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Here's a link to all the work we did on that YJ. YJ BUILD
For this rig, we used a 15gallon fuel cell in the bed of the rig. You could probably get by with a small flat cell under the bed if you have to keep the back seat.
BESRK is offline
Need new front rear speakers..install advice please? TJforlife Audio, CB & Ham Radios, GPS, & Electrical 4 03-06-2009 08:50 PM
tire strech 265-75-15 1989yjeeepnj Tires & Wheels 3 02-03-2009 09:47 AM
axle swap/strech frumpy General Jeep & Off-Road Equipment 7 11-30-2006 06:35 AM
Rear axle advice kristof2 Engines & Drivetrain 2 07-12-2006 12:03 AM
Advice on wheeling with a rear locker... Tirith General Jeep & Off-Road Equipment 12 02-26-2005 04:52 PM
