#91 | |
#92 |
GROUND POUNDER
Glad I could help
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#93 |
I have a friend that lives up there that is getting ready to head this way. What could you do for me on 4 dring mounts and the hinge tube for that swing away? He might also want the same when he picks mine up.
53 willys wagon with less of rust and no more bugs. Now sporting a 1988 wagoneer frame, amc 360, dana 44's. '80 CJ-5, full width, 3 link front, 1/4 elliptical rear, 38's, and propane. |
#94 |
ok this is prolly a dumb question, but what is POR 15. IS it a heavy duty paint?? how scratch resistant is it?
Thanks |
#95 |
GROUND POUNDER
It a pretty tough paint. That rear bumper still looks like new. Checkout their website at www.por15.com
#96 |
where do i get the hinges that you used? And what size spindle did you use?
For info on outdoor adventures in South Carolina check out OffroadSC.com |
#97 |
can you describe how you put together your hinge in more detail?
#98 |
GROUND POUNDER
I got the spindle and bearings HERE . I picked up a length of 2 1/2" x 1/4" wall DOM tube with an inside diameter of 2" (just about the same size as the outside diameter of those spindle bearing races). Picked up the tubing HERE . I used a sleeve of some 2" outside diameter tube to act as the bearing spacer inside the bigger tube. I drilled four 1/2" holes around the outer tube so I could plug weld the inner tube in place. The job of the inner tube is to keep the bearing races set apart so you can tighten the spindle nut and compress the bearings.. taking out the slop. Otherwise, the bearings will just slide around inside the bigger tube. I believe, there are a couple places out there selling spindle/hinge setups complete for about $50 or so but I made mine for about 1/2 that.
#99 |
thank you so much that is exactly what i needed to know...now i just need to pick up some 2.5" DOM..
I got the trailer spindle for $7 at Northern Tool and as well as the Bearing kit for 8.99. Im on my way to a rear tire carrier, thanks man
#100 |
how long is the unmachined metal on your spindle, i just went to test fit the spindle in my bumper and the raw metal on my spendle measures 3.5"...thats .5 too short for my jeeperman bumper...if im going to be welding to raw steel top and bottom....how long is the raw steel section of your spindles?
#101 |
GROUND POUNDER
Hmmmm I just got rid of my last spindle.. I believe it was right at 4" though. I beveled the bottom. When I welded it in, the weld just ground smooth with the bottom of the bumper...
#102 |
could you make me one of these
#103 |
GROUND POUNDER
Honestly, I don't have the time right now. I just bit off a mouthful with a project Jeep for a buddy. I'm starting a coilover 4 link front and rear on his Jeep. I'm gonna have every spare moment tied up for the next couple of months to get this done before the cold weather. After that, I'm building a new frame/cage for Big Lime and doing a front 4 link coilover before next Spring. What started as a tinkering hobby has almost turned into a full-time job.. next to my full-time job.
#104 |
We finally got around to finishing the xj bumper...but didnt have a camera in the shop...we also painted my tire carrier. What do you guys think?
#105 |
GROUND POUNDER
Both bumpers are awesome!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
