Quantcast Rear Bumper w/Swingout Tire Carrier Follow Along - Page 6 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Rear Bumper w/Swingout Tire Carrier Follow Along
Old 03-31-2005, 06:22 AM   #76
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I got my 3/4" chuck 1 hp press from Northern for like $300 or so.. love it.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 04-04-2005, 12:08 AM   #77
speedfreak
Mac tools sells them also I don't know how big they go I will have to check my tool box. I think 1 inch?? Well thinking about it it might be strap-on. I will check
speedfreak is offline   Reply With Quote
Old 05-07-2005, 10:48 PM   #78
mrgeoff
have you guys herd of msc. they have everything. Im a machinist and use them alot. if you sign up on there internet and request a catalog and CD, thell send you a book about 4 inches thick of cool stuff. its not jeep stuff but industrial supply and tooling, if you can think of it they got it or will have stuff to build it.
mscdirect.com
93, 4 bangin, gutless yj that is ready to crawl this summer.
mrgeoff is offline   Reply With Quote
Old 05-10-2005, 05:19 PM   #79
penguinland
Did you happen to weigh this project, I'm curious how much it weighed. I think this is my next project but it will only be 3/16" wall tubing
Bone Stock
penguinland is offline   Reply With Quote
Old 05-10-2005, 07:29 PM   #80
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The bumper without swingout weighs about 55 lbs. I would imagine the other stuff added another 40 lbs or so.. let's call it an even 100lbs or a little less...
When I start making more bumpers, I think I'll go with 3/16" wall too... Also, I plan on building an entire frame out of 3/16" wall 2x4 sometime in the next year. Might do it this Fall when I do the front 3 link on Big Lime. Must get a tubing bender too....
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Old 05-10-2005, 08:14 PM   #81
penguinland
Tube Bender Too bad you don't live closer, you could be my new best friend
Bone Stock
Old 05-10-2005, 09:30 PM   #82
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
That's funny, I'm everybody's best friend around here... when they need something welded..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Old 06-23-2005, 01:30 PM   #83
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Man, I bought a couple of those Hougen Rotabroach Annular Cutters for drilling the clevis mounts... they are awesome.. drilled a 1" hole thru 3/4" thick stock in about 30 seconds...
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Old 06-29-2005, 11:34 AM   #84
xj-boonie
When do you think you'll start making bumpers again? As I'm in the market for one for my CJ with a tire carrier and yours looks great!
Thanks,
Mike
[SIZE=1]1996 XJ Sport, 3" OME lift, 31" BFG AT's, Tom Woods SYE & DS, Amsoil flat filter, Amsoil fluids, Kolak ignition & exhaust, Hidden Hitch hitch, IPF e-codes & Magic-J bulbs, T-case & Gas tank skids, AJ's super rails, C-rok brace, JKS disco's, ARB Bull Bar w/ Warn M8000.
1979 CJ5, 258 I6, T18a, glass tub/fenders/hood, 4" BDS lift, 33" BFG MT's[/SIZE]
xj-boonie is offline   Reply With Quote
Old 06-30-2005, 05:12 PM   #85
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Thanks,
Mike
Shot ya a PM.. Eddie
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Old 06-30-2005, 08:17 PM   #86
Tom Gralewski
yea im interested to ive got a 93 xj and i like the look of the bumpers. If your not makin them could i get some dimensions so I could see about having one built for me locally, and I just want the reg bumpers no tire carrier.
1993 Jeep Cherokee Sport, 4.0HO,Aw4,Np231,
D30 with 98 tj axle shafts and spicer 297x's
8.25 with factory limited slip, 4inch springs in front, s10 pack in rear, 31x10.50x15 Continental Sportiva Ats
Long Arms Done; 6" Lift and 35s in spring
Tom Gralewski is offline   Reply With Quote
Old 07-03-2005, 10:06 AM   #87
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
nice skills! thanks for the post!
Reelm n Rubi is offline   Reply With Quote
Old 07-05-2005, 10:41 PM   #88
dwilliams35
Told ya! They are badass, aren't they? Keep the slugs: I've found all kinds of uses for them.
dwilliams35 is offline   Reply With Quote
Old 07-06-2005, 06:18 AM   #89
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
They go thru that thick metal like it was warm butter! I always keep my slugs.. I have hole saws up to about 5" I keep the slugs for those too. Especially when I cut thru 1/4" thick stock.. they make good seal drivers, spacers.. etc.
One question.. how long do they stay sharp? I bought two so I can send one in for resharpening when needed. I use lots of cutting oil to keep them lubed and cool too...
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Old 07-06-2005, 10:55 PM   #90
dwilliams35
To be honest, I don't think I've seen one "dull out": we've got a few yahoos working there, and we do occasionally end up with broken bits, but I haven't really seen them go dull. We did buy the official hougen sharpening fixture, but I haven't really used it. Of course, this is a fully equipped machine shop, so the guys that know how to use the things really know how to get the most life out of them. One other thing we've got for them that's pretty handy: a mandrel that's got a connection to pump coolant down the MIDDLE of the bit: it's on a bearing, just hook a hose to it and go to town. Not sure how much all those extra toys cost, as I didn't have a part in buying them. I'd say that as long as you're using a drill press, with the work clamped down, (assuming mild steel or light alloy) they'll last a heckuva long time. Think of the number of cutting edges you're looking at, and how wide the kerf is, compared to a 1" drill bit. Also: don't know if it has a bearing on the tool life, but ALL of the stuff we've got from Hougen is set up for water-based coolant: the magnetic drill press has a coolant tank, the drill-press mandrel, etc. etc. etc. I don't know whether they're just assuming that like most machine shops, we'll use water for such things, or if they're trying to tell us something!
Glock Forum
